mort stoll
Everything posted by mort stoll
  1. hi kevin, quick question. i noticed on p 42 on the upper deck A7 #33 of mckay he mentions a steam trunk. any idea what it is? thanks and keep up the great work. mort
  2. hi kevin, the rudder looks great. pardon my ignorance but what is holding the outer part of the rudder chain? is it another eyebolt? thanks, mort
  3. hi paul, the hull steps I think look fine. the entry port is nicely done. where did you get the sheve. keep up the great work, mort
  4. hi, i am still researching and organizing as far as the victory is concerned. i intend starting her in 3 weeks or so. thanks, mort
  5. hi peter, could you post a picture of the spectacle plate? thanks, mort ps I love your build and hope to build a 74 one day
  6. perfect, great thank you. did not do a build log for the diana. if you send me your email in a pm I will be happy to send you some. thanks very much, mort
  7. hi paul, i have a question if you can recall. on 3/23/16 post #2 are parts # 105 and 106 the stern inner and outer extensions even with the ends of the gunport patterns #270 etc? they appear to be and I would think they would be. thanks, mort
  8. hi paul, just discovered your build log - very impressed - and having just completed the diana am about to start on the caldercraft victory. question about the stern fascia. you built the entire piece on your work table and then glued it onto the stern? thanks, mort
  9. hi, when I built my snake - about 4 1/2 years ago i moistened the middle of the deck and gently and carefully with the aid of my plank bender was able to fold the false deck and slip into place. others have cut the deck in half and glued in both halves. hope this helps, mort
  10. check siren ship models site. they sell monograms. used them on my Diana. worked out very well. mort
  11. hi have you tried cornwall model boats? they sell becc flags. keep up the great work, mort
  12. happy birthday many many many more
    mort
    1. Dan Vadas
      Dan Vadas
      Thank you Mort ).
      :cheers:  Danny
  13. i bought a copy on amazon a few months ago. it's great book, and was very reasonable. looking forward to more posts. mort
  14. no I can't thank you enough for sharing your build. I hope to build this kit one day this is an amazing practicum. keep up the great work, mort
  15. hi david forgot to mention i put painters tape around the gun ports before filing mort
  16. hi david, i used a 1mm drill bit. made lots of holes and then used mini files to finish the job. took time but in the end i felt it was worth it. your deck is great. thank you for sharing the deck jigs. all the best mort
