hof00
Posts posted by hof00
  1. Hi Chap,
    Looking very "Sharp." (Pardon the pun.... 🙂)
    Pedestals look the part. Agree, the Stand provided is not worth the time or effort.
    If I had it over, I'd turn a couple of wooden pedestals. (Which I now do for my builds.)
    I went with 6.0mm, (From memory), Brass Rod, looks o.k.
    IMO Spray Putty is an excellent solution for that really smooth surface!!
    I had heaps of "Fun" painting my Hull, I used Vallejo Acrylics, no problem, I then thought I'd be clever and try to get that "Mirror" finish and sprayed with automotive lacquer, looked really good until after 24 - 48 hours afterward when it all started to Craze.
    I had to sand everything back and start again.... and again as I had not managed to get rid of some of the lacquer the first time around.
    My error, I had not tested the Paint/Lacquer combination properly.
    In the end, I just left the paint with a satin finish.
    I am sure that you wouldn't make the same dumb mistake as I, a learning for myself, character building? 🙂
    Cheers....HOF.
  2. 1 minute ago, Mirabell61 said:
    nice build Hof,
    did you scratch build the boats, they also look good ?
    Nils
    Thanks Nils,
    The Boats were in the kit, A/L instructions stated they were "Art Wood" (MDF?)
    In my instance they are White Metal castings that I was not initially, very happy with but with a bit of "Love" and the addition of some Gunwales they looked a bit better.... 🙂
    I chose a Green Nylon fabric for the covers which are glued to 1/6 Ply.
    (I like the Green as it gives the model a bit of life. 🙂)
    Cheers and Regards,
    Harry.
  3. 4 hours ago, Diver said:
    Love the look of your build.  I recently purchased the up dated version of the Sanson.  When I finish rigging my Syren Medway longboat I will be staring on the Tug.  I was going to omit the lighting but seeing yours I have changed my mind.  Bravo Zulu on you build
    4 hours ago, Knocklouder said:
    That looks like a lot of fun time, nicely done,  and amazing work.   :cheers:      Congratulations .
    3 hours ago, Glen McGuire said:
    Excellent build!  The working lights are a very nice effect!
    Thank you, Gentlemen,
    Yup, was a "Fun" build.... 🙂
    I think that the only real issues I had with lighting was routing the Nav. Light wiring and the Mast Lighting required quite a bit of thought and a couple of prototypes.
    @Driver if you are thinking of lighting with your build, I may be able to assist with my method anyway.
    Cheers and Regards,
    Harry.
  4. Hi All,
    Small update:
    The two front Decks, (Focsle/Tween?) are now in reasonable condition, Re-planked, Tree-Nailed and sanded. (Needs a coat of Polyurethane.)
    I figured the Poop Deck did not require a re-do.
    (Re-paint also on inside of Bulwarks.)
    Photos posted below also show Hull Planking that needs to be re-done below the Whales, I have the Materials so will get busy on this soonish.
    Cheers....HOF.
    Photos:
  5. 6 hours ago, rvchima said:
    Lots of nice details on the lifeboats!
    Thanks Rod,
    Lifeboats are White Metal with Wooden Gunwales added and some nice Green Nylon Fabric glued on to a piece of ply.
    I had to extend the Davits in height by about 6.0mm as the Handles/Pullies were pushed out by the Boats.
    Last of the Fenders to be installed hopefully today.
    Cheers....HOF.
  6. Hi there,
    Maybe you could remove the broken Ring, (Carefully as they are White Metal, File?), Drill a small hole and replace with an Eyebolt attached with CA.
    To add strength the Eyebolt could be attached after the fitting is attached to the Mast so the Shaft of the Eyebolt penetrates the Mast also.
    Another idea, if the thickness of the fitting is too thin to drill, you could always mount an Eyebolt immediately under the fitting attached directly to the Mast.
    My guess is that these rings are for Stays so you want something that ca withstand a bit of tension.
    (My two cents worth. 🙂)
    Cheers....HOF.
  7. Hi All,
    It has been more than a few years since I posted on this particular thread.
    (Good things take time? 🙂)
    So, I have almost completed Sanson, something that I started in 2014.. While casting around for a subsequent build, I pulled out the Endeavour. (It was a toss-up between this and the Mamoli Flying Cloud.)
    I decided to re-boot Endeavour.
    An inspection first to ensure all the bits and pieces were there, they appear to be and second to inspect the Hull thus far.
    Not too much wrong, the two front Decks needed re-Planking to be completed and sanded and the Mahogany second planking, below the Whales needs to be re-done.
    Today I finished the two front Decks, sanding and will drill and install the 400 or so Treenails starting tomorrow.
    The Mahogany Planking requires approx. 25 full Planks per side, I did not have quite enough so ordered some from a NZ Website. The only problem is that the Kit calls for 5.0mm wide Planks, all good, but the only stuff that I could get my hands on was 3.0mm wide. Never Mind.... My plan is to Alternate 6.0 with 3.0mm wide Planks as I move down the Hull. I also plan to cut the planking to a more "Scale" Length rather than to lay the entire length of the Hull.
    I am also in the process of studying "Banyan's" Build, I think that this is something to really aspire to. 🙂
    So, that's the plan moving forward with this. I think I'm looking forward to completing this build.
    (Photos after I complete the tasks above.)
    Cheers....HOF.
  8. Hi All,
    Bit of an update....
    • Mast and lighting complete (Not wi9thout issues and a re-build 🙂)
    • Lifeboats complete
    • Rigging complete (Lashings for Lifeboats the exception here
    • Last six Port-Lights added
    • All-over Satin Polyurethane
    Stuff to do:
    • Lifeboat Lashings X4 each consists of 2 Double Blocks Ring-Bolts, Etc.
    • Davit Mounting (I may need to lengthen the mounting shafts by two or three mm I can see if this is necessary after the Lifeboats are lashed down
    • Hull Buffers/Bumpers
    • Towing Rings (These are the slightly curved pieces that span the Rear Deck, they will be interesting 🙂 A/L supply a reasonably heavy Brass rectangular section strip for the two "Rings." I am still pondering how to accurately form these.
    Anyway, almost there.
    Cheers....HOF.
    Photos:
