Everything posted by Louie da fly
Thanks everybody for the likes and particularly to mrcc for the nice comment. More progress. I've been working on the robands - fixing the sails to the yards: Note: in the picture above what looks like a break in the yard is actually just a bit of darker grain. I got about half way then happened to compare what I'd done with a photo of an actual lateen rigged vessel of about the same size as the dromon in real life and realised I had the robands about twice as close together as they should have been. So I removed every second one. As I was about halfway through, for the same amount of work if I'd had the spacing correct I would have had all the robands done. (sigh) And all complete! And I've started furling one of the sails, the only way I know how, by clamping everything and gradually adding the gaskets. The other thing I've been working on is carving three figures to go up on the fore yard, unfurling the sail so the oarsmen can have a break. (there's a nice breeze coming from aft) Unfortunately there was a really nasty knot right in line with the left leg of the last guy, and his foot broke off, with a section more like gunge than wood at his ankle. I had to do a lot of bodging to get it to work halfway decently. More to follow as I get more done . . .
Thanks, iMustBeCrazy. Yes, the name nef is just the mediaeval French word for a ship, so it's like calling a carrack a nao - context is all. The Wikipedia article is interesting (once I'd worked out that the word google translated as "straps" should have been "oars") - I'd like to follow up on some of the sources the article is based upon, though - such as what's the evidence for the contention that it is similar to the Knorr with its clinker-built hull and rudder attached to the starboard side, but it is significantly more bulbous than its Scandinavian predecessor. and also that the Nef was equipped with a continuous deck, but often rose steeply at the ends of the ship to the stems. I know of no evidence to back either of these contentions up - they may well be true, but I'd like to see the evidence, particularly as one of the sources it quotes dates back to 1914. Which is my own opinion. But what the hey, in the frumious spirit of investigation and quest for knowledge, I think this is all very well worth while. One from the mid 15th century: C. 1460 Decameron Harvard MS Richardson 031 f. 152v. And as late as 1588, accounts of the Spanish Armada refer to a large number of "hulks" being part of the Spanish fleet. Now this is an English translation and I don't know what the original Spanish word was, but perhaps it was urca, as above. Here are a couple of possible 16th century candidates: 1558 De Piscum and Aquatilium Animatum Natura Conrad Gesner Cosmography Samuel Munster 1598 And as you can see, these pictures also show the snarks . . . Dick, it occurs to me that as the hulc seems to be a northern development it would be somewhat rounder amidships than your diagram above, more like a knarr though the bow and stern would have to be rounder to allow for the lack of a stem and sternpost.
- 186 replies
- keelless
- reverse clinker
- (and 4 more)
Sounds like a good idea, especially printing the designs on the paper instead of painting them by hand. Not sure if I've already referred you to this site regarding designs on Viking shields: http://members.ozemail.com.au/~chrisandpeter/shield/shield.html - there's also this one -http://www.vikingage.org/wiki/index.php?title=Round_Shield_Designs#/media/File:Shields - it includes a lot of shield patterns which aren't Viking but they are from areas bordering Viking lands, and several of them appear in more than one region suggesting that patterns of this type were fairly widespread. A bit of experimentation should show you the best way to harden/stiffen your shields. And as you're printing them in bulk it doesn't matter if you have to throw a few away.
iMustBeCrazy, I'm really curious as to where you got that definition of nef - because I've been calling that type of ship a nef and I thought it was just me . . . do you mean to say that's the official name of the thing and I somehow came up with it independently? By the way, surely the Winchelsea ship doesn't qualify as a hulc because it has a stempost and sternpost. Which way the planks overlap is a little equivocal, but from a pic with better detail it looks more like standard clinker than reverse . . . At least the bowsprit doesn't get mixed up with the rudder sometimes . . . (A thing, as the Bellman remarked, That frequently happens in tropical climes, When a vessel is, so to speak, "snarked.”)
- 186 replies
- keelless
- reverse clinker
- (and 4 more)
That's absolutely stunning, Binho. For the shield bosses - hmmm, difficult. In real life they were about 15cm (6") diameter. So at 1:72 they should be about 2mm (converts to a little over 1/16"). They were of various different shapes, but hemispherical was common and would probably be the easiest to get hold of. Some kind of bead.perhaps? Or you could make a plaster mould (Australian spelling, don't worry about it) and cast them in car-bog (body-filler). Maybe the heads of small dome-headed bolts with the slot/Phillips head filled in? And just glue onto the centre of the shield board. Nobody will ever check the back of the shield to see if there's a hole there for the Viking's hand to fit through.
You're a braver man than I, Gunga Din. I look forward to seeing what I feel must be the first ever model of a hulc. Except perhaps this: And a boojum is a snark, but a snark isn't necessarily a boojum. You may serve it with greens and it's handy for striking a light . . .
- 186 replies
- keelless
- reverse clinker
- (and 4 more)
Hi Cap'n Snack and welcome to MSW. I had to look up what gunpla was. Quite a move from that to ship modelling, but I imagine the skills from on should transfer to the other quite well. Make sure you start a build log when you begin your model. It is a very good way to get help and advice and encouragement, and we get to see yet another beautiful ship model under way.There are instructions on how to do it here: Looking forward to seeing your progress.
Welcome, Patrick! I'd second Mark's suggestion that you start a build log when you begin your model. It's a great way to get help and advice - and encouragement. By the way, why the name Boomer? Are you a baby boomer (like a lot of us) or is it because that's the name for a very big kangaroo?
Half your luck, Andre, living in Portsmouth. So if you're unsure of a detail you can just pop down to the naval base and check it on-site! When you've finished Victory maybe you should consider making the Warrior and Mary Rose . . .
Very interesting conclusion. Perhaps because in frame-first construction the strakes were fixed to the frames, whereas in shell-first they were fixed to each other?
Chuck, I've downloaded it as a PDF. I'll PM it to you.
- 130 replies
- wütender hund
- hanseatic
A lot of fiddly work, but worth it in the long run.
- 181 replies
- santa maria
- mamoli
Beautiful work, Chuck. Very nice indeed.
- 179 replies
- shipyard
- wütender hund
Hi Chuck. Thought you might be interested in this. In Norway they've found "cogs" with remnants of rigging items. And there's a good definition of what are currently accepted as the characteristics of a "cog" https://www.academia.edu/22591645/Medieval_Shipwrecks_from_North_Norway_and_their_Contribution_to_Understanding_Maritime_Interaction_and_Trade?email_work_card=view-paper
- 130 replies
- wütender hund
- hanseatic
Yes, this seems to have been a common design - the Serce Limani wreck and other Yenikapi wrecks have the same flat bottom and sharp change at the bilge line. The ones I've looked at (admittedly galleys, as this is what I was interested in) have alternating frames - every second frame (though the builders weren't all that consistent about their spacing) crosses from bilge to bilge. Every other frame is a pair that runs from keel to gunwale on each side. Together these two frame types provide good structural integrity. However, it looks like Yenikapi 12 was constructed differently.
I thought you might be interested in this: https://www.academia.edu/22591645/Medieval_Shipwrecks_from_North_Norway_and_their_Contribution_to_Understanding_Maritime_Interaction_and_Trade?email_work_card=title - they found "six complete or partial blocks and two possible deadeye fragments.", though the only block the paper show a photo of is what we would now call a heart as it doesn't have a sheave. The paper also quotes a definition of what are nowadays understood to be the defining characteristics of a cog "having straight stem and stern,flush-laid bottom planking, clinker-built sides, and floor-timbers alternating between extension to port and starboard (Crumlin-Pedersen, 2000)", which I had never come across before , and though there are exceptions to this, it's a pretty good definition.
That's very good. He looks a lot better. I'm a big fan of shiny. Here's the helmet I made to wear at the battle of Hastings re-enactment event (on the actual battlefied) in 2000. I've always been a great exponent of the idea that if you could afford a helmet you'd have kept it shiny. You could see your face in this one. And I inscribed the nasal with 11th century "Ringericke" style knotwork (with wolves on the eyebrows). Unfortunately after I got home we moved house and the helmet vanished - I suspect the moving men who I was silly enough to show it to. After all that work! Yes, combs were very common. Usually made of antler (which I discovered is actually bone - it's just an extension of the bones of the body - but is configured very conveniently for making combs and falls off the deer's head each year - how convenient is that?). I got right into bonework at one point and made one comb for my lovely wife and started another but never finished it (ran out of antler). There are huge numbers of Viking and Anglo-Saxon (for lack of a better word) combs in museums, and it's possible to date them by their shape and decoration. The fineness of the teeth of some of them is unbelievable - I've no idea how they managed it with hand tools. Very highly sophisticated technology. And yes, the concept of "Englaland" was, if you like, created by the Vikings. They destroyed all the independent English kingdoms except Wessex, and when Aelfred the Great defeated them, the treaty divided the land into Danelagh/Danelaw and Aelfred's realm, he became the "king of the English folk". His kingdom was expanded by his successors, taking more and more of the Danelaw until everything south of the Scottish border was one kingdom. Several of the pre-Viking Anglo-Saxon kings had achieved the status of Bretwalda [effectively High King] by defeating their neighbouring kingdoms, but none had managed to unite the whole country under one rule as the Vikings did by default. Interesting - if there hadn't been Viking invasions, there wouldn't have been an England . . .
Phil, that's looking amazingly good. I'm impressed. you've even put the "bowsprit" in, which I wasn't expecting. (it's function is debatable - it probably didn't work the same way as the bowsprits of centuries later, and it vanished quite soon, but it does appear fairly often in contemporary representations). Probably the best name for those internal planks is "stringers", whose function is the strengthen the structure. If the inside of the hull was covered with them they'd probably have a different name (such as "internal planking"). They'll work well to provide you with belaying points for the rigging ropes. I'm amazed you've been able to achieve with balsa - it's really rubbish wood, and you've stretched it way past its normal capabilities. Making a capstan without a lathe isn't as hard as you may think. You can carve it to shape without too much trouble. Start with a square section piece of wood, then take off the corners to make it octagonal, then smooth it down further and further. That's how they made masts. Finally, you can use a "poor man's lathe" (electric drill) to finish it off. But don't use balsa! Even pine would be better, but I'm sure you can find some decent wood without too much trouble. Or, perhaps better still, you could shorten the process by starting with a piece of dowel and carve it down to the shape you want. Maybe even "turn" it to shape, using an electric drill as a lathe and a rough file as your "lathe tool". The Bremen cog had a capstan to raise the main yard, but it also had a windlass. See https://nautarch.tamu.edu/class/316/cog/ By the way, regarding the fixing of shrouds and rigging artefacts, have a look at https://www.academia.edu/22591645/Medieval_Shipwrecks_from_North_Norway_and_their_Contribution_to_Understanding_Maritime_Interaction_and_Trade?email_work_card=view-paper - they found some blocks and what might be fragments of deadeyes.
