davyboy
Members-
Everything posted by davyboy
ancre Chebece 1750 by Jeronimo - FINISHED
davyboy replied to Jeronimo's topic in - Build logs for subjects built 1501 - 1750
Hi Karl, I have just been admiring your superb workmanship but one thing puzzles me. The large stern grating has the fore and aft planks raised higher than the thwartship planks. This seems to me to be rather dangerous and could cause a person to catch a foot in this gap and trip up (stolpern) Then,I see in a later photo taken below the stern and notice that the grating planks appear to be flush with each other. No criticism meant, just an observation but I would have thought this should be the top side of the grating giving a level area to walk upon. Kind regards, Dave -
Black wire for eye bolts/rings
davyboy replied to Johnnyreg's topic in Metal Work, Soldering and Metal Fittings
Hi John,it's very easy to blacken copper with a liver of sulphur solution. Takes seconds to do after cleaning the part then just rinse off with water,you can also blacken copper items in situ then rinse it off. It doesn't do any damage to nor discolours the wood. Check out Ed Tostis' Young America build log,he uses it for all his copper work. Is that very nice Tearoom still open in Harrogate ? I was in there several times many years ago,very nice pastries were enjoyed to be sure. Dave -
Nice job on the drop plank BE,yes,it was bit of a pain to get it right. My first attempt was not good enough (a couple of tiny gaps) so was ripped out and replaced. Had no problem on doing the other side,lesson learned. Apart from that the planking was/is straight forward. Regards. Dave
- 574 replies
- cheerful
- Syren Ship Model Company
Hi BE, I planked my model with individual plank lengths as shown in the plans. I find it's easier to get a good fit between adjoining plank strakes doing it this way using scale lengths. My model is built using Pearwood and European Boxwood,the deck planked with Birch. Just finished making the chainplates today (the second attempt,don't ask why) As always,keep up the good work. Dave
- 574 replies
- cheerful
Hi Charlie,JMO but I think 2.5ft is too short,not much leverage there. The Cheerful pump handles scale at 4ft long at 1/48 and a drawing at 1/96 I have also measured has the pump handles scaling at 4ft long. Still,as they say"up to you" Dave
- 362 replies
- active
- revenue cutter
Hi B.E. She is coming on nicely. I did what Kurt mentioned,vertically planked between the bulwark extensions with 1/16" limewood. Makes sanding the extensions to the right thickness easy,adds strength plus giving a good base for glueing on the inner planking. Keep up the good work Dave
- 574 replies
- cheerful
Cutty Sark by NenadM
davyboy replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Congratulations Nenad, I too had Cataract surgery done today on my left eye,I had the right eye operation done in January. The increase in vision in that eye was spectacular (40% to 100%) within a few days. I hope it is the same for you. Dave- 4,152 replies
- cutty sark
- tehnodidakta
Hi Doris, How nice to see you are back with your model of the Royal Katherine. Sorry I can't help with the book in Swedish but the following book may be of help to you. 17th and 18th Century Ship Models from the Kriegstein Collection. Second revised and expanded edition. It was published by Seawatch Books ISBN 978-0-9820579-7-1 but unfortunately it does not appear now on their current list. Perhaps your local library could obtain a copy for you. Some of the models are of ships of around this period with very good colour photographs nearly all showing the ornamentation,these are:- The Royal James 1671 1st Rate. A Charles the second 4th Rate ca 1680. The Coronation 1685 2nd Rate. I have this book and it's a treasure. I just checked and see there are copies of the first edition for sale on Abe books but am not sure how much difference there is from my edition. Probably not a great lot I would think. Kind regards, Dave
- 1,035 replies
- royal katherine
- ship of the line
I like your shade of red B.E. very nice indeed. Kurt,I made my wales at the full thickness,easy enough to bend with no worries about a second layer being feathered down to nothing at the rebate. Dave
- 574 replies
- cheerful
Hi BE,if you are interested have a look at this website. www.massiv-holz-werkstatt.de He has a large selection of timbers at good prices, eg a 1000mm x 200mm x 1.5 mm plank of Linde (Limewood) would cost €7.30 +p&p. I bought all the Pearwood for my Cheerful build from him,excellent quality it is too. He says he will cut wood to any size you wish,so I guess he would do Imperial sizes if you asked. He does speak English,however his website is in German. I did my order by email and bank transfer. On his homepage click on Produkte,then scroll down to Brettchen (planks) all are from .5mm to 50mm thick x 1000 x 100 mm. I've no connection to his company just a happy customer. My order arrived within a few days of payment. Kind regards and thank you for your good wishes, Dave
- 574 replies
- cheerful
Hi BE,your Cheerful is coming along nicely. Have you considered using 1.5 mm ply for the false deck it's only 5 thou thinner and you can cut it in one piece out of a sheet. I did for mine it worked a treat,just epoxied it down. I had the same problem as you with the bow fillers just added a thin piece on top. Thought I'd made a booboo as I'm scratch building mine except for the windlass. Building is on hold just now until I have the cataract op on my left eye next month. My vision just now with one good and one bad eye leaves much to be desired as my specs are now useless. Regards and keep up the good work. Dave
- 574 replies
- cheerful
Bumpkins
davyboy replied to bluenose2's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
Hi bluenose2, I believe the original Endeavour didn't have bumpkins fitted. For certain the replica has the foretacks led to a block on top of the catheads. I'm sure that they would have got this right. I think that where boomkins would have been fitted the foretack fouled on the catheads due to their position. Google HMS Endeavour and you will find many pix,some showing this lead of the foretack. The ones shot from just aft of the windlass show this best. That I'm sure is why there is nothing on the plans about them. There was a short discussion about this a couple of years ago,in one of the build logs as I recall. Dave -
Hi again Tom, Sailmaking section :- page 153,left hand column last sentence, page 154 left hand column first sentence. Regards, Dave
Hi Tom,here's two bits from Lees,hope they are of help. 1:- "After 1730 and up to 1745 on small ships and 1780 on large ships,the fore part of the sail was cut off and the luff laced to the mizzen mast". 2.- "When gaffs were fitted,which was from 1745 on small ships and 1780 on large ships the mizzen sail was cut exactly as just described". He also states that "the mizzen sail was always loose footed,that is,no boom was ever fitted; it was only when the permanent driver replaced the mizzen that the boom became a permanent feature". If it was my frigate model I'd fit the gaff. Dave
Hi Tom,the mizzen jeer did hang abaft the mast. As I understand it this allowed the mizzen yard to be moved to the other side of the mast when changing tack to prevent the mizzen sail wearing on the mast. The parrel/truss was slackened off,the mizzen yard bowlines disconnected and the yard physically hauled aft then passed to the other side. Must have been a real PITA for the crew as the jeer,brails,sheet and likely the lift would also need some slackening off. Still,Navy ships had large crews so manpower wouldn't have been a problem. I would imagine the sail would have had to be furled to do this but I'm no sailor,a large kite comes to mind Dave
Thanks Kevin, Thought that might be the case,poor design in my eyes. The Chilean Navy had the right idea. I worked offshore in the late 70's with a Sikorsky S 58t,similar to the Wessex but powered by a P&W PT6 T6 twinpac. Had to get a "dead one" cleared off the helideck to one side. It took a dozen of the rig workers to manhandle it over the helideck netting. That was on a production platform which didn't pitch and roll like a ship. Regards, Dave
Hi Kevin,I too follow your build and a sterling job you are making of it too. One question if I may,was the Wessex kept out tied down and bagged on the helideck most of the time. If not,it must have been a real pain to get it in and out of that sideways hangar on a regular basis. Blade folding for sure and probably also the pylon. Keep up the good work Dave
Model Shipway Ratline tool
davyboy replied to fnkershner's topic in Modeling tools and Workshop Equipment
Doug,that is how it was done. Stbd 1&2,Port 1&2 then Stbd 3&4,Port 3&4 and so on. A good dodge for single shrouds is,if the ship had 2 Burton pendants (masthead tackles) to incorporate these with the single forward shroud. Alternatively a false cut splice can be made joining the 2 single shrouds,the serving will hide this. Just for info,the forward shroud on square rigged RN ships was always wormed and served for it's full length. Prevented the sails chafing on the fwd shrouds when close hauled Think this was standard in all navies. I believe on fore and aft rig the rearmost shroud has this done. Dave -
An interesting idea but...What are the chances of not pulling the ratlines out of line when,after turning in the deadeyes reeving the lanyards then tensioning the shrouds? It's almost a guarantee you will pull them out of line,thread/rope can/will stretch after all. Could end up looking dreadful if you've glued the clove hitches. Just a thought Also,I can't imagine the hastle of getting 4 or 5 pairs of shrouds linked together by ratlines over the masthead in sequence stbd 1&2 then port 1&2 etc. Dave -
Hi Maury,when I have to rig very small blocks I dip the end of the thread in cyano glue and cut diagonally through it. As sharp as a needle and goes through no problem,I do this for larger blocks too. No need for a needle threader at all. regards, Dave
- 525 replies
- anchor hoy
- hoy
Hi Seren,can't help you with drawings but if you google HMS Victory the second item is 100's of photographs of her. You should be able to get a good idea of where the wale positions are from them. Surprised there's no info on the plan,nor any material provided for them. Hope this may be of some help to you. Dave
What brand of #11 blades do you use
davyboy replied to bigcreekdad's topic in Modeling tools and Workshop Equipment
I've been using Swann-Morton #26 unsterilised blades for donkeys years,also use the #21 and #25's occasionally. Much prefer the larger size of these blades to small blades. Incidentally,I just use my fingers to change these blades and have never cut myself doing so. To remove,I hook a thumbnail under the end,lift then push forward a bit and slide blade off the handle by gripping the back. To replace,grip the back then slide new blade on 'til it clicks in place. That's how I've always done it without injury. Dave -
Issues with rigging on Pannart Royal caroline
davyboy replied to Capn. Morgan's topic in Masting, rigging and sails
Hi Capn Morgan, The tackle R11 is called the Lateen Mizzen Yard Bowline they were rigged on both Port and Stbd sides. The tackle at the aft end of the yard is called a vang,they were also rigged in pairs Pt and Stbd. A rope was clove hitched around the yard peak,a long tackle (fiddle) block was spliced in each end and connected to a single block hooked into an eyebolt in the quarter piece each side. Have to say this,that rigging plan is rubbish. Get the book JCF mentioned or get Andersons' 17th Century Rigging IMO a better book,with better line drawings etc. Also usually easily found on online booksellers lists. Rigging really is fun,honest Dave
