davyboy
Members-
Everything posted by davyboy
Hi Jim,there is a mention of of these pumps for deck washing in Laverys' Arming and Fitting of English Ships of War page 79. They were fitted to all 2 and 3 deck ships and were introduced in 1770. The inlets were 3 feet below the waterline,one per side. He doesn't state where they were fitted though. Midships would be my guess. It was doing repairs to one of these which caused the sinking of the Royal George in 1782. Hope this may be of help to you. Last time I was in Edinburgh half the streets were being dug up for tramlines. Dave
Hi David, You may find this of interest :- Google The Elements and Practice of Rigging and Seamanship. This will take you to the website of The San Francisco Maritime Park Association, there they have Steeles' work. You want the asterisked chapters of 208,209,210 and 211,numbered drawings and names of the numbered rigging and sail items are there. Should be of great assistance to you. OK, these appertain to a 20 gun ship but the names are the same for all ships. This book covers everything as the title says. A lot of reading there to keep you out of mischief for a while Dave
Hi David,definitely do it again,that deadeye gap does not look good. Anyway,it will give you some practice There are a couple of books on rigging that I recommend to you. James Lees Masting and Rigging of English Ships of War 1625-1860 and Karl Heinz Marquardts' Eighteenth Century Rigs and Rigging. Second hand online booksellers usually have them in stock. Either is worth having,the first being the best. Dave
Hi David, The distance between deadeyes should be appproximately 3 times the diameter of a deadeye. Dave
Good evening Maurice,you have made a beautiful job on your Alert. All your research has indeed paid dividends. I look forward to following your next build,another Cutter or something more exotic I've just spent much of the past week building a Capstan for my Speedwell,had a pig of a job making the spindle. I don't have a lathe so had to make do with using dowel,no choice. However much scraping and sanding I eventually got a passable round to build upon. There are a surprising number of parts to make if you count all the wood parts never mind all the other things,bolts,pawls etc. The ten bars I'll leave 'til much later. Regards, Dave
- 335 replies
- alert
- vanguard models
Hi David, Skip what is in the instructions and make them as I wrote as that is the correct method. It's also easier and neater,you would have 8 loops to make taking more space on the masthead. I do my shroud siezing like Pat says around a suitable sized dowel. I thread a needle with the siezing line and pass it through one of the legs at the top then take around ten turns downwards about both legs. I then pass the thread between the legs at one end of the siezing then over the siezing and through between the other legs doing so 2 or 3 times. Finally pass the needle & thread through the middle of that,apply some glue (not CA) when dry clip off. You're then good to go. This last bit sounds complicated but is dead easy to do. Dave
Hi David, I assume you are referring to the shrouds. These were made up in pairs by doubling a suitable length of rope leaving enough lenght to tie in the deadeyes. The centre portion was normally served then the two legs lashed together leaving a loop sufficient to fit over the mast head. They were always fitted in the following sequence :- first pair starboard,second pair port,third pair starboard and so on. Hope this answers your query,have fun. Dave
Mark,if you have a copy of Marquardts' Eighteenth Century Rigs & Rigging Davis's "The Proportion of the Rigging" tables are printed in the appendix section pages 307 to 328. If you don't have a copy maybe your local Library could help. Hope this may be of help to you. Dave
LOL,when I lived in Northumberland many years ago it was called "newkie broon" or more usually "Lunatic Soup". Visited the Scottish and Newcastle brewery once and looked inside a vat of the brew fermenting,80 odd thousand gallons of it 😵 😵 Heady stuff. Dave
Hi Wahka, Many builders change the 2nd planking for another wood. Pear is indeed an excellent planking timber and readily available in Europe in sheets or milled planks and not too expensive. It also has very little grain showing. Cherry and Maple are also suitable timbers. As far as historically incorrect goes most period ships were planked with oak which is not really suitable for modelling purposes at all. BTW,there is no such thing as stupid questions on MSW,that's how we all learn "how to do it" correctly Kind regards, Dave
That is an interesting painting but I suspect that they were carrying out some repair work on the hull. Not only did coppering prevent a shipworm infestation but also prevented the growth of various types of marine vegetation. Copper is I believe poisonous to plants. Dave
Thin hull planking
davyboy replied to Gerarddm's topic in Building, Framing, Planking and plating a ships hull and deck
Ahem !!!!!! 1mm is 0.0394". 1/32" is 0.0312". Dave -
Hello Doris, These are the tackles for the Top Ropes which were used to lower the Topmasts. They were hooked to the top rope pendants which ran through sheaves in the heel of the Topmast. These pendants started from an eyebolt in the Lower Mast cap running through one of these sheaves up to a block on the opposite side of the cap then down to the tackles. There is a very good illustration of this in Lee's Masting and Rigging book (page 55). Also in R.C. Andersons 17th Century Rigging,drawing #13 items 166,167 and 168. Hope this helps with your wonderful model build. Dave
- 1,035 replies
- royal katherine
- ship of the line
Hi Matt,welcome to MSW. Dave
Hi Maurice,very very nice indeed,super job👍. I look forward to the continuation next year. I had a rethink on my Speedwell POB. Didn't like the filler blocks fwd of the front bulkhead so they were chiseled out. Made the upper parts of the bollard timbers and 4 hawse timbers from pear and fitted them. Had to do some "surgery" on the fwd bulkhead and part of the lower filler blocks. Looks very much better. It was quite a job making these parts with a fretsaw,razor saw and files Regards and I wish you a Happy New Year. Dave
- 335 replies
- alert
- vanguard models
Hi Srodbro,may I suggest you PM Jim Lad who is one of our mods. He lives in Sydney and is also a volunteer at the Maritime museum there. I'm sure he will be able to give you any info you require. Enjoy your cruise, Dave
Greg, Doris is still working on her Royal Katherine. Can be seen on the czech forum :- modelforum.cz Now has the lower masts stepped and rigging started. I wonder why she stopped posting here on MSW. Dave
- 1,035 replies
- royal katherine
- ship of the line
Opened it no problem here in Switzerland. Dave
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Good evening Maurice, That's one of the problems with kits unfortunately. Scratch is the way forward Your idea of using 6 mm stock looks good to me anyway. I was very surprised to see what was provided in the kit for eyebolts and rings and those ghastly cast cannon,oh dear. Love your Alert print from the Science Museum by the way. I was in their shop 12 years ago hoping to replace a print of HMS Prince I bought in 1974 but was told they didn't sell prints anymore. Guess they must have started again. Dave
- 335 replies
- alert
- vanguard models
Weak Joints - Deadeye Strops
davyboy replied to VTHokiEE's topic in Metal Work, Soldering and Metal Fittings
You really need silver solder for joining brass wire. Ordinary solder is useless for this. Dave -
Hi André, Welcome on board MSW enjoy the voyage. Dave
