Everything posted by ccoyle
Intro to Card Models Part VIII: Building V108 - Miscellaneous Bits
ccoyle replied to ccoyle's topic in Card and Paper Models
You are a braver man than I! Well done! -
I guess they must have thought a little extra challenge was in order.
- 5 replies
- cabin cruiser
- Aero-naut
BTW, here's one for the airplane nerds out there: According to what I have read in online sources, the 109's radiator doors were linked to its flaps, the idea being that since the lowered flaps partially blocked the flow of air through the radiators, the flow would be maintained by automatically enlarging the rearward aperture via the linkage. Thus, a model should match the positioning of the radiator doors to the angle of the flaps, i.e., flaps down -- doors down, flaps up -- doors up. The construction diagrams show the doors fully opened, but since I intend to display the model with the flaps up, I will position the radiator doors to match.
They are by no means unique in that regard. Misspelling one's native language is a shared human experience!
- 97 replies
- Corel
- Große Jacht
A challenge, perhaps, but at least Corel kits typically have good-quality wood. P.S. I have edited the log title, including correcting the spelling of Größe to Große -- the first instance is a noun, the second is the adjective form. Those pesky umlauts!
- 97 replies
- Corel
- Große Jacht
Some dimensions would help narrow the field a bit. The construction of the stern galleries is quite crude.
Bonjour, Tanguy ! Bienvenue sur notre forum. J'espère que vous apprécierez de parcourir l'énorme quantité d'informations que nous avons ici pour les aspirants modélistes. Veuillez noter qu'il s'agit d'un forum en anglais et que nous exigeons que les messages soient rédigés en anglais. Vous pouvez utiliser un traducteur en ligne pour vos messages – de nos jours, ces sites font généralement un très bon travail. Cordialement, Welcome to our forum. I hope you will enjoy browsing the huge amount of information we have here for aspiring model builders. Please be advised that this an English-language forum, and we require posts to be made in English. You may use an online translator for your messages -- nowadays such sites usually do a very good job. Kind regards,
Greetings from a clueless Patrick O'Brian fan
ccoyle replied to Galkar's topic in New member Introductions
Welcome aboard! -
Welcome aboard!
Ah -- the sort of vessel "Lucky" Jack Aubrey would have been snapping up during his time in command of Sophie.
- 55 replies
- Le Martegaou
- billing boats
One of the problematic parts of the assembly process on the E-4 was definitely the wing, so that's something I wanted to 'get right' on this build. First step was to add the central ventral skin ('central ventral' -- catchy) and wheel wells. The wheel wells on this kit are really rather simple and posed no problems at all. The sort of 'antennae' looking bits are fairings/joiners that will wrap around the wing root and blend into the fuselage. Now this is a shot from the E-4 build. The part I've circled was supposed to have been folded upward to be the trailing edge of the wing, but that wasn't clear to me from either the instructions or diagrams, so I left it un-folded. 😬 Fortunately, it's on the bottom of the wing, so very rarely does anyone see it. Here's the properly done E-7. And here's the dorsal side of the wing, with tips yet to be added. You can see how one of the 'antennae' bits has been wrapped and mated to the wing skin. Now, you may have noticed that the wing skin consists almost entirely of a single skin. For anyone wanting to try a model like this, I've found it to be much easier and neater to not attempt to glue the skin on all in one go. Instead, I work in sections, starting at the wing root and working toward the tip, using the various bits of framing to align everything properly (I should mention that I gave the entire wing frame a light sanding before starting this process). You can see in the photos that everything has come together very well at the various junctures, e.g., wheel wells, radiator wells, skin edges and frames, seam between dorsal and ventral skins. This is a testament to the excellent design. There will be a less-glowing testament once the wing gets mated to the fuselage, but I'll save that for when we get there!
Great finish! Congratulations!
- 28 replies
- Lowell Grand Banks Dory
- Shipwright Series
(and 3 more)
Yes, it is not cheap, but the construction method is different. Vanguard kits have a lot of laser-cut parts, but in the Shipyard kits, everything is laser-cut. As a result, there is almost no sanding to be done, other than smoothing the spots that hold parts in their frets. This also means there is no plank spiling to do. This makes Shipyard kits appealing to modelers who may not be able to deal with wood dust for whatever reason. So it's not really a direct competitor to Vanguard in the sense of being a choice between two POB kits -- it's more of a choice between two similar but substantially different construction methods.
Great paint job! It does, though, kind of hide just how many pieces of PE you had to apply to the superstructure. I admire the skill and patience of anyone who can work with that stuff successfully.
- 97 replies
- Enterprise
- Tamiya
Congratulations! I think that's a very handsome display.
- 82 replies
- half hull planking project
- half hull
SPAD XIII c1 by modeller_masa - Roden - 1/32 - PLASTIC
ccoyle replied to modeller_masa's topic in Completed non-ship models
Looks great!
