Everything posted by ccoyle
Super-Hobby is actually an internet store with its home base in Poland. It's the same kit (see post #1 in this topic). Well, thank you, I'm flattered! But I'm also realistic -- I'm no match for the kit's beta builder. I'd like to get there someday, but I don't know that I ever will. It's difficult to learn the secrets of the masters when all of them live in Poland and are mainly active on the various Polish-language forums. Cheers!
Last night I finished the cowling and mounted both it and the engine to the fuselage. When it comes to cowlings, card model designers have two options. By far the more common option is to make the cowling from a series of rings, like those seen here for my earlier F6F build: The other and thankfully less common option is to design the cowling as what's called a "petal structure" in the hobby, i.e., the cowling is a single strip (or two strips in this case -- an inner one plus an outer one) from which a series of tapered darts is removed, creating a row of 'petals'. The petals are then rolled to bring their tips together, creating the rounded cowling. I absolutely, positively despise petal structures. In the first place, they are an absolute nightmare to shape properly. I don't know how the Poles do it, but I'm far from mastering the technique. In addition, and for obvious reasons, a petal structure has a large number of seams -- sixteen in this instance. Lastly, it is very difficult, for me at least, to judge whether I have achieved the correct amount of 'roll'. The roll is largely determined by the petal shape -- you simply roll them until the edges come together -- but there's still a certain amount of leeway between getting it just right and almost right. Happily, the whole thing does not look as bad in real life as this unflattering close-up makes it appear. Still to be added is the air scoop that sits atop the cowling. The dash-four had two additional scoops inside the cowling at roughly the four and eight o'clock positions, as you can see in this photo: The kit makes no provision for the inside scoops, so I'll have to give some thought to whether to add them. Anyways, that's where we're at for now.
Welcome aboard, Blaine. Marine Models has been out of business for quite some time, so it's little wonder that they don't turn up on the forum very often. In fact, we have only six build logs that have been tagged with that company name -- you can see them here. Your Dapper Tom model may be nearly as old if it is one of the old 'yellow box' kits. Cheers!
Sometimes, when I dying in the sweltering heat and humidity of the Deep South, I look up the weather data for my hometown in Humboldt County and dream longingly of summertime highs in the upper 60s. 🥵
- 54 replies
- Spray
- BlueJacket Shipcrafters
All done! I'd tell you what all the extra added doohickeys are, but I don't know what they are myself -- I just followed the reference photo. As a matter of curiosity, there are, of course, multiple variants of the Twin Wasp. I didn't find any sources that could tell me which variant(s) was(were) used in the dash-four, so if you know, don't tell me now, cuz it's too late! 😅
I don't think the MK kits look bad when finished bright -- they use good-quality wood, and the combination of wood tone and brass is attractive. But you can't go wrong with adding a touch of paint, either. I've seen them both ways and like them equally well.
- 42 replies
- Cannon Jolle
- Master Korabel
Congratulations, David, on a grand achievement!
- 218 replies
- Victory
- Caldercraft
Now we're getting down to details that are difficult for a cellphone camera to capture. Cylinders #3 and #13 have hoses that connect to the distribution ring. In addition to these, I did a test run of the spark plug 'wires', which are simply black thread. The hoses and wires have couplings that I believe were probably brass on the original or some other brown-toned metal; these I have simulated with dark tan paint. Overall, I like the effect and think we're good to go for the remaining thirteen sets of wires. BTW, the kit provided a template for making the distribution ring from wire, but since the original is rectangular in cross-section, not round, I chose to make one from scratch from scrap 'beer mat'. This was a good move, because it is infinitely easier to glue the thread ends to card rather than to metal.
Our friend, Tomek @0Seahorse , has published a new kit. This charming US revenue cutter -- including all of its accessories -- can be had for under US$40 at WAK (the kit by itself is only US$7.16). Tempting!
- 24 replies
More engine progress. I have added the rear bank of cylinders to the crankcase (BTW, I'm not a mechanic nor mechanically inclined, so my engine terminology is limited). To see what extra detailing I have added so far, you can compare the detailed cylinders to the basic kit cylinder on the left. The front cover on the crankcase and all of the bolt heads are extras, as is the little blue daub of paint, which represents the Pratt & Whitney badge (no, I'm not gonna super-detail the badge -- don't be insane!!). Next step will be adding the push rods to the rear cylinders.
Brig Niagara 2023 sailing season ending early
ccoyle replied to gak1965's topic in Nautical/Naval History
Oh, the irony! -
Welcome aboard! If you'd care to read about my experience with building a CLC boat, you can find my build log here.
I have actually crossed the River Lerma numerous times on the way in and out of Temascalcingo.
- 286 replies
Beautiful! But these should be posted in the gallery.
To be honest, it's been so long since I did that part of the project that I can't remember exactly what I used. I probably used a water-based stain, and I'm fairly certain, but not 100%, that I used an off-white from Model Shipways, also water-based, for below the waterline. BTW, I hope my next project doesn't take me 17 years, too!
- 69 replies
- fly
- victory models
Finished So, first of all, if anyone is interested in why this model is finished without having any masts or rigging, allow me to refer you back to post #25. I ordered resin swivel guns from Chris at Vanguard Models. These are very nicely done and far superior to the off-the-shelf metal ones from Amati. I was surprised, though, to discover that the guns did not come with any mounts. I don't blame Chris for this at all -- I never asked about the mounts and he never said anything about whether they were included. The lesson here is it pays to ask! I tried several methods to create mounts: wire (fail), cobbling something together from leftover PE parts (fail), and finally hit upon yokes made from scrap black construction paper. These look fine as long as one doesn't view them from head-on, otherwise they look impossibly thin. The final shots: So, that brings this seventeen-year-long, on-again off-again journey to a close. I do have another wooden subject waiting in the wings, but I'll divulge that project at the proper time. Cheers!
- 69 replies
- fly
- victory models
You are aware the kit is designed to be planked first before installing the keel? It's not a deal-breaker if you don't (I did mine that way by accident), but that was the designers' intent.
- 42 replies
- Cannon Jolle
- Master Korabel
