![](https://modelshipworld.com/uploads/monthly_2017_06/594c220154a6f_JuliaDelacruz.jpg.7fb548c654153ae17c8e0d7243b347df.jpg)
russ
Posts posted by russ
Whilst waiting for some supplies to arrive, I got to work on the pilot house. The house sits on a raised base and that was the first order of business.
Here is how I made the base. I made it this way to be able to more easily and in the round up of the bulkhead frame tops into the bottom of the base.
Russ
- BANYAN, captainbob, FriedClams and 13 others
16
Lawrence:
Thanks for the kind words. I also find the lines of these boats very appealing, especially up forward. The planking should be fun.
Russ
- mtaylor, FriedClams and canoe21
3
That looks good. Different challenges require different solutions. I spend a good deal of time just thinking about how to get a particular piece made. The first pass is rarely the last, but it is fun and it keeps the mind active. Good work.
Russ
- Eddie, Overworked724, Elijah and 2 others
5
Beautifully done. Love the rigging details. Congratulations on a really nice model.
Russ
- FriedClams, mtaylor, Elijah and 2 others
5
The volutes you came up with look pretty good. Nice work.
Russ
- thibaultron, Overworked724, Elijah and 1 other
4
Pat:
That was exactly what my client was going for when she chose this case. She wanted no vertical frames so that when you look in the case, you do not have to look around anything to see the model and she liked the white acrylic base.
Russ
- mtaylor, popeye the sailor and BANYAN
3
- druxey, alde, popeye the sailor and 13 others
16
The rigging looks good so far.
The deadeye strap issue is a problem. The CA will hold it, but getting it to look neat is a different problem. Soldering is a good way to keep that from happening.
Russ
- CaptainSteve, mtaylor, cog and 2 others
5
I agree that the fourth rail is a bad idea. When you look at these rails from the side, there should be a graceful sweep towards the stem head. That is what you are looking for.
Russ
- billocrates, Altduck, mtaylor and 1 other
4
Your model is coming along really well. Nice work.
One thing you might want to look at. Look at the top headrail from the side. It seems to me that the headrail should curve upward a bit more than it does. The curves from the top view look good. However, check the view from the side and make sure you have the proper curves there as well.
Russ
Michael:
Thanks. The sheer line is an important design feature of these luggers. If it is not correct, it will show.
Russ
It is your model so do what you think looks best. The grain is attractive.
Russ
- Elijah, Eddie and thibaultron
3
Pat:
Thanks. I am very pleased with the shape thus far.
Russ
- mtaylor and FriedClams
2
Kees:
Thanks. I also think she has nice lines. The upright stem is an attractive feature on these boats.
Russ
Here we have the framing almost complete. The knightheads will go in next. Once the framing is complete, I will spend some time fairing the hull. That process will take several days to make sure I have a good fair surface for planking. Once that is complete, I can begin lining off the hull for planking.
Russ
- Elia, cog, FriedClams and 13 others
16
Sultana by Overworked724 (Patrick) – FINISHED - Model Shipways – Scale 1:64 – Solid Hull – First Wooden Model Ship
Sometimes that happens. Analyze and retry.![:) :)](https://modelshipworld.com/uploads/emoticons/default_smile.png)
Russ
