![](https://modelshipworld.com/uploads/monthly_2017_06/594c220154a6f_JuliaDelacruz.jpg.7fb548c654153ae17c8e0d7243b347df.jpg)
russ
Posts posted by russ
Ingenious bit of modeling. The finished product looks good. Nice work.
Russ
- Nirvana, genericDave and Elijah
3
Tony:
Look at the side view I posted. The port tackle is attached the after most eyebolt on the carriage.
Russ
- tkay11, thibaultron, mtaylor and 1 other
4
Yes, the port tackles (sometimes called side tackles) are used to run the gun out after loading.
Russ
- tkay11, thibaultron, Canute and 1 other
4
Andy:
It looks great. The color contrast is very attractive. I used that same color contrast on another model last year. Great work.
Russ
Thanks. His surprise made it worth it.
- popeye the sailor, mtaylor, Moonbug and 1 other
4
Yes, any wood can be drawn. Some will probably be better than others. A straight grained material will be best. It will have less breakage be easier to pull.
Russ
- Canute, thibaultron and mtaylor
3
I have a Byrnes draw plate and it is the best one I have. It has a great cutting edge at each hole. It is easy to use and I would not trade it for anything.
Insert the material into the side opposite the countersink and then pull it through from the countersunk side of the hole. You can use pliers to hold on to the end while you draw it through. I use my thumb and forefinger, but others use pliers.
You can clamp it to your desk or table, but I have never done that. I hold it in my hand as I work. I can usually get a 5-6 inch length on each piece if I want them that long.
Make sure you have a piece that is not too large for the hole. I draw my bamboo through the same hole several times, angling it differently with each successive pass to ensure I am ready to move to the next hole. Be patient and do not try and work too fast. The faster you go, the more breakage you will have. Also, the more practice you have, the easier it will be to use.
You should experiment with it to see what approach works best for you. Have fun.
Russ
Chuck Passaro's Syren (Model Shipways kit) has great plans and detailed instructions. Check out some of the builds here. Chuck is also a PM away for questions.
Russ
- CaptainSteve, Canute, Jack12477 and 3 others
6
- rafine, John Cheevers, BANYAN and 11 others
14
I think the cradle will be a good idea. The hull looks wonderful and I know it will be gratifying to finally cut the build board away. Good work.
Russ
- CaptainSteve, Jack12477, cog and 7 others
10
Congratulations. It is a beautiful model and the flag looks great. Well done all the way around.
Russ
Your wheel looks great. It is far and away better than mine at the same scale.
Russ
- mattsayers148, Canute, src and 2 others
5
The decal and the pump came out really well. Nice work.
Russ
- Omega1234, FriedClams and mtaylor
3
Mike:
Breechings were about 3 times the length of the gun's bore.
Russ
- BANYAN, mtaylor, thibaultron and 2 others
5
Dave:
Those pieces look great to my eye. The issue with the engine box is one that not many would notice.
Russ
- genericDave and Elijah
2
Dave:
Really beautiful model. The flags came out great. Congratulations on a fine finished model.
Russ
- Canute, WackoWolf, CaptainSteve and 3 others
6
Santa Maria by SkerryAmp - Artesania Latina - 1:65 - PoF
in - Kit subjects built Up to and including 1500 AD
Good to see you back at it. The planking looks good.
Russ
