russ
Members-
Everything posted by russ
Couple questions regarding Chainplates
russ replied to BareHook's topic in Masting, rigging and sails
Ken: I agree with Rich. Strop the lower deadeyes, attach them to the chainplates, and then attach the chainplates to the hull. Reeve the lanyards as the shrouds are installed. Russ -
Michael: The bitts and the knees look great. I also like the elegant chamfered edges on the inboard portion of the bowsprit. I will doing the same thing on my schooner. That seems to have been a common detail. Russ
- 2,207 replies
Next kit suggestion???? moved by moderator
russ replied to Rich_engr's topic in Wood ship model kits
My vote would be for Syren. I have seen Chuck's plans and instructions and I know that kit itself is first rate. Russ -
Very nicely done. It is a beautiful model. Thanks for posting it. Russ
- 45 replies
Mario: Nice work on the sails and rigging. Russ
- 45 replies
The figurehead and trailboards look very good. Nice carving there. Russ
- 104 replies
- rattlesnake
- mamoli
Martin: Your model is looking very good. On the rigging questions, I would place any of the sources above the Mamoli plans. Lees, Steel, Antscherl should serve you well. It might pay to get a copy of the Model Shipways plans also. They are dated, but I am sure well researched. Russ
- 104 replies
- rattlesnake
- mamoli
That looks good so far. You are doing good. Russ
- 246 replies
- revell
- constitution
Cross-section by russ - FINISHED - 1/48 scale
russ replied to russ's topic in - Build logs for subjects built 1751 - 1800
Dida: Thanks. I appreciate the kind words. Russ- 69 replies
- frigate
- cross-section
US Brig Syren by Gahm - Model Shipways
russ replied to Gahm's topic in - Kit build logs for subjects built from 1801 - 1850
Beautiful work so far. Your hull is really nice. The planking and coppering look great. The guns look they are spot on from the photos. Russ -
You are doing good. so far. Fairing is a time consuming process, but it will yield great dividends when you plank. I think that it is possible to do a bit of prebeveling on the bulkheads prior to installation, but I agree that the bulk of the work needs to be done after the hull framing is glued up. You always want to take off less than you think you should. It is easier to take more off later than to try and add it back on afterwards. Russ
Augie: You have made a good start on your spars. I look forward to seeing some rigging. Russ
- 1,668 replies
- syren
- model shipways
Cutting that rascally rabbet
russ replied to trippwj's topic in Building, Framing, Planking and plating a ships hull and deck
Yes, you have it correct. You are making an area into which the end of the planks sit. The rabbet, depending on the hull's shape in any given area, will change shape along its length. Russ
