Everything posted by michael mott
Coloring Basswood
michael mott replied to JPett's topic in Painting, finishing and weathering products and techniques
Daniel a very nice build. I enjoyed the photo show. Michael -
yesterday I needed to sharpen the hollow ground blade to ensure the my cuts were smooth. I use a simple method First I unplug the saw. Safety first!!! It is so easy to forget to unplug power tools when changing blades and cutters. I sandwich the blade between a sheet next to the fence and a board clamped to the table. then raise the blade so that the file in horizontal. next I offset the file to the position to give the correct angle with the file sitting flat on the handle you can see that the file is off to one side. I then draw a line on the wood to keep the file straight while I sharpen, it is low tech but works fine. Michael
Joe, yes I know that is the case, The trade off for me is that I do not use even half the stuff you can do with LT. so the expense of the full version was not in my cards. I am also not willing to put in the time for the 3D functions in the programs that support it . I have used Rhino and Sketch-up, I found them just a bit too frustrating. when I need a 3D I work with a pencil and sketch it out in seconds. Michael
Excellent work Doris, your figures are wonderful. Michael
- 883 replies
- royal caroline
- ship of the line
Buck the mini me is not photo shopped I just printed a picture of myself and cut it out with a pair of sharp scissors. The low tech version of having fun, I stuck some raw treenail rod on the back of the photo so I could stick it anywhere on the deck before I filled the holes. Thanks for the compliment on the Bristol Cutter. Your restoration on the little boat is really nice. and I have filed away your neat trick with the cutters, that was very clever thinking. Michael
- 515 replies
- artesania latina
- whaleboat
The first real harvesting of wood for a model was in 1975 when I was at the Ice-fields Campground At the Athabasca Glacier with my parents who were visiting from the UK. The firewood at the campground was about 16 inches long and had been roughly split into quarters It was extremely fine grained spruce, probably from close to treeline or a low moisture location am guessing that the rings were no more than a 1/128th inch apart. anyway I saved some for a model aircraft I was building at the time. I striped it into a small square section to bend for the tailplane. perimeter. Yes getting the wood from nature is a big plus, in my books. Michael
Bob, those look Nice. I have adobe illustrator I needed it for an Exhibition project that I did back in 2002 I never did like it, I prefer Corel for the bitmap stuff. I have been happily drawing all day. I am working on tracing the Colchester Smack There are some good images on the Betty CK 145 Website http://www.betty-ck145.com/docueng/smacks/smack_plans.html I am tracing it at full size in Autocad so that when the drawing is finished I hope to have a full set of plans to build an accurate model from. Once the plans are drawn full size in the cad environment it is simple to print them to any scale. I like working in full size because then there is no mucking about trying to sort out scale sizes. a 4x6 timber is drawn as a 4 x6 timber and so on. I don't have to do any mental gymnastics while drawing. The drawing on the link shows that the drawing of the Colchester smack at a scale of 1/90 my Corel file to PDF then imported to Autocad showed the length as 17point something inches I cannot remember the exact number at the moment. so using the 1/90 as a guide I did the math on the calculator to find the multiplier and scaled the PDF up so that the lines drawing was full size. It worked out to be 34feet 8 inches long. so at 1/24th scale it would be 17 inches or 34 inches at 1/12 scale and so on. I am really happy that you told me about the PDF's because I would not have tried that. and I much prefer to work in Cad I do find that I have to lock the layer that the PDF is on after it is re-sized though. Michael
:D Molasses those wires are mighty fine. .002 that is finer than most human hair!..... Now there's a thought what about rigging something with human hair. it has probably been done. Michael
- 84 replies
- esmeralda
- training ship
Elia that looks really great, I had not realized how complex the deck furniture was going to be. Michael
John those are some long mast and spars. I am going to suppose that you will have the sails furled.... but maybe not? Michael
Ok I know there was some info and posts about this on MSW 1...... fast forward to MSW 2 I am coming up to my 65th birthday and My sweet wife will pool with her family to get me the right stuff for my Bristol Pilot Cutter. Here is a picture of the sailplan What do I need? Michael
Russ I think it has to do with the level of the Cad package There are a number of things that were not included in the Autocad Lt 2000 The other thing I cannot do it 3D. The difference in cost between the Autocad Lt and the full Autocad is considerable. The thing that I really like about Autocad v's the Corel drawing program is the way the vectored program works compared to the raster program simple things like extending a line or trimming a line those tasks are much more cumbersome in the drawing program and Ortho mode. Michael
Hi Russ Upload the JPEG to which program? If I scan a drawing for instance I save it as a JPEG then upload it to Corel Draw II Then I scale the image to whatever scale I am working with. So now instead of doing the tracing in Corel I will save the Corel file as a PDF then load it into the Autocad Light. Once the file is in Autocad Lt 2000 It is put on layer 0 and the layer is locked not frozen, That way the trace goes well as in the case of the example that I started the post with. Now in order for me to post a picture that I have generated in Autocad Lt 2000 I have to save it as a DXF open the DXF in Corel and then save it as a JPEG PNG or PDF to post it here. This is the Autocad file that I traced from the PDF this morning. It is a PDF file test trace of corel Cockwells.pdf This is a PNG this is a JPEG The PDF was the easiest on my computer system resources, and the line weights in the JPEG and PNG are very hard to see in the exported images. In each case the same file in Corel was saved. The JPEG and PNG both had to be reduced from 8,000 pixels to 800 pixels to post. I used Ifanview to do the reductions , it is a free and very easy program to use. This has been a bit of a ramble but I really prefer to draft in Autocad and not draw in Corel. So I am happy that I have begun to use the spline function and it will make drafting so much easier for me. Michael
Dee Dee Just checking in, I like what you have done so far. Michael
- 89 replies
- muscongus bay lobster smack
- midwest products
I must add my own congratulations Garward. michael
- 111 replies
- le fleuron
- cannon
Hexnut I am sorry I confused the issue in the first post I meant to say that from Corel via DXF to Autocad which is when it freezes . I do set the line width in Corel 11 .001" because if I set it to 0" then I see nothing. I just did the PDF into Autocad LT Well thanks for that tidbit of Information , learned another great tip today Thanks. Oh this is such a great site !!! Michael
