Everything posted by CDW
Going through the Pontos instruction photos, it becomes obvious the same instructions are shared by the King George V update, the Prince of Wales update, and the Duke of York. Certain construction/detail photos are marked for KJV, PoW, and DoY, only. It's quite possible the only difference in the sets will be the wooden decks, which are different for each variation. That means for my build, will have quite a few rocket launchers left over. So far, I like this set well enough that I am tempted to build both of the other versions after I finish this one.
- 151 replies
- duke of york
- tamiya
More tools - Luthier, jeweler, fly-tying
CDW replied to vossiewulf's topic in Modeling tools and Workshop Equipment
Excellent thread. Have made note of a number of items I want/need. Thanks! -
Great! Permission to come aboard, sir. Have never seen this ship before now. When I first saw your pictures, thought it was a DD rather than a CL. Small guns it seems, even for a light cruiser. Almost look more like destroyer guns at first glance. Looks like it could be a lot of fun and will be a good display match for the Yamato.
Painted the hull with hull red and dark gray, painted raised portions of the deck with light gray. After paint dried, attached deck to hull. Stained the wooden deck stick-on with a dark gray acrylic wash (Vallejo). After 2 coats, I was satisfied with the finish. I sprayed the wash on using my airbrush, then wiped down excess with paper towels. ***One particular thing to take note if you might attempt this conversion yourself...my donor kit, the Tamiya King George V, has in the very center of the deck a raised structure with a deck on top for mounting the ship's boats. To model the Duke of York, the Pontos set provides cranes and railways that accommodate the observation aircraft and hangar, in place of the structure and deck (provided in the Tamiya kit). The ship's boats get mounted elsewhere on the ship. This is not made clear at all in the Pontos instructions, but you should quickly realize it by looking ahead in the building sequence and comparing it to the Tamiya plans. You will need to measure and cut an appropriate sized styrene sheet to fill in the "hole" that's left by not using the Tamiya ship's boat deck. The wooden stick-on deck covers this area and later on in the construction sequence, the railways are constructed with photo etch and glued to the wooden deck. I do not know for sure exactly how the Tamiya Prince of Wales is configured if you are using that kit as the donor. Either the KJV or the PoW should work fine for the conversion, but there may be differences in how that center section gets handled. Hope this makes sense. Anyway, I placed the stained wooden deck and fastened her down. Next, will begin building the superstructures, painting them, and building/painting the other conversion set details as required. Stay tuned.
- 151 replies
- duke of york
- tamiya
The white styrene strips really simulate the caulking well. Looks great!
- 146 replies
- dumas
- Chris-Craft Commander Express
Thanks - I'll look for those AK products in my favorite places.
- 151 replies
- duke of york
- tamiya
What is the AK wash, Greg? Not familiar with it. Painting it would be simple enough. I don't think there are any pre-stained decks available for this model so I'll have to do it myself or just use the natural wood deck.
- 151 replies
- duke of york
- tamiya
Experimenting on a scrap piece of natural colored wood deck material, I stained it with Vallejo dark gray wash. It seems to have turned out okay, so maybe there is a way to stain that wood deck after all. My concern will be how consistent the stain works over the entire deck and that it will not look splotchy in places. I guess the only way to find out is to just do one up and see. As it turns out I do have an entire extra deck I can experiment with.
- 151 replies
- duke of york
- tamiya
OC The reference I have shows that scheme (your photo) as being from 1941, so maybe there was some period in 1943 she wore that scheme before receiving the newer scheme which she wore in December, 1943. Don't know for sure, but just guessing.
- 151 replies
- duke of york
- tamiya
I had these pictures that were labeled as the 1943 color scheme, but I doubted them. After reading your description from the Roger Chesnau book, maybe they are correct after all? What do you think? My wooden deck is more of a natural wood color, not stained dark as pictured here. I don't know a way of restaining a wood deck a darker color like that, so I would leave it as is I think. Comments?
- 151 replies
- duke of york
- tamiya
It doesn't look like much, but spent several hours cutting away unwanted raised detail, sanding and smoothing out the deck pieces in preparation for the wood deck. Finding color call outs or pictures of the 1943 configured HMS Duke of York is turning up rather empty. Best I can tell, the colors are pretty basic...a white-gray on the hull, turrets, and superstructures, a dark gray on top of the turrets, and a black-gray on the hull armor belt. Does anyone have any information that either agrees or disagrees with this? The ship went through several or more paint schemes, but the December 1943 scheme is what I'm after.
- 151 replies
- duke of york
- tamiya
Fokker Dr.I by Torbogdan - FINISHED - Model Airways
CDW replied to Torbogdan's topic in Non-ship/categorised builds
I think you have done a fantastic job cleaning up those cast metal engine pieces and assembling them. That will turn out to be a very respectable representation of the engine. The landing gear and wheels look super as well. -
Got started tonight. Not too much done yet, though. When I have multi-piece decks, I like to glue a styrene strip to the bottom of the deck pieces at the joints so that the pieces have something to glue to each other and not allow the deck to flex at the joints. Then, there is a ton of raised deck details that must be cut off and sanded smooth as the wood deck covers it, then replacement resin pieces are provided in the Pontos set to take their place. I started cutting off the raised details and sanding the deck smooth. Also, sanded smooth the raised mold line along the bottom of the hull to prepare it for painting.
- 151 replies
- duke of york
- tamiya
That really looks nice. Only another modeler can appreciate how much work is involved in laying down that much planking. The added interior and lighting are very nice detail features. "Admiral" is definitely the correct term for a spouse graduating with their master's degree. This is her weekend.
- 961 replies
This old 1:350 Tamiya 1:350 King George V kit has been in my possession a long time. Maybe 20 years or more, I forget. A short while back I took it out of storage from my attic and decided I would build it. Discovering that Pontos made a conversion set to build this model as the HMS Duke of York gained my interest because I had already finished the Scharnhorst and it's in my display cabinet. As you probably know, these two ships have significant combat history against each other. In December of 1943, the HMS Duke of York along with other British ships sank the Scharnhorst off the coast of Norway. In one salvo, the DoY destroyed the front main gun turrets of the Scharnhorst and everything went downhill from there for the ill-fated German Battleship. Here's my starting shot of what I'm working with. Even as old as this kit is, it's a testament to how well Tamiya kits are engineered for good fit. I am hoping it's going to turn out to be a nice model in the end. The Pontos set comes with five nice photo etch sheets, a heavy bag of turned brass gun barrels and ship's masts, and a large number of resin parts. In addition, it brings a wooden deck and a small sheet of dry transfers.
- 151 replies
- duke of york
- tamiya
Hello FR I love the subject model and have been looking at them for sale on Ebay from time to time. Will follow your build log and try to learn how it all goes together. Looks like you are making swift progress and she appears to be of very sturdy construction. Great choice of a model in my opinion! Regards CDW (Craig)
I wish the Calypso had even less to do with a plastic model...like the hull being of wood construction instead of that ABS plastic. I'm still looking at alternative construction to build the hull from wood rather than using the plastic hull.
- 44 replies
- schnellboot s-100
- revell
Old Floquil paints?
CDW replied to MEDDO's topic in Painting, finishing and weathering products and techniques
I used a lot of Floquil paints years ago. I had probably 300 bottles of paint from years ago in storage containers not long ago, Rather than hose up some good models and clog up my air brushes, just gave them away and disposed of the rest. It was maybe wasteful of me, but mine had been subjected to some hot temps in a non-climate controlled garage and I just didn't feel like experimenting. With these new acrylics, I've gotten spoiled on how easy they are to use, not stinky, and how quickly they dry. Some of my old Floquil paints took a long time to thoroughly dry. -
Want to decide on one of these, next: 1:200 Mikasa with a Pontos detail set 1:350 Duke of York - a conversion from the Tamiya Prince of Wales using a Pontos conversion set 1:48 Billing Calypso Research Vessel 1:8 '32 Ford Roadster Street Rod (for a change of pace) 1:32 Trumpeter SU-25 Frogfoot ground attack aircraft (another change of pace) Going to decide in the next day or so.
- 44 replies
- schnellboot s-100
- revell
It's time for me to put a bow on this one and call it finished. Tonight it will go into my display case for the grandsons and other visitors to eyeball behind glass, safe from curious hands. Of course, I reserve my right to float it in the bath tub with me from time to time when necessary to run "sea trials".
- 44 replies
- schnellboot s-100
- revell
Today I made a battle flag by cutting a small piece of aluminum foil, shaping it a bit to simulate a flag flapping in the wind, then applied the Kriegsmarine battle flag decals to both sides of it before attaching it to it's mast. Rather happy with the way it came out but not so happy with trying to freehand the swastika on the flag as the Germans (Revell-Germany kit) cannot reproduce it on the decal I suppose. The aluminum foil was so delicate I had to be careful when drawing the swastika not to ruin the flag by piercing or folding it.
- 44 replies
- schnellboot s-100
- revell
