Everything posted by AntonyUK
Hello Zappto. Welcome to MSW. Nice work on your Lexington. And yes it is not easy cutting the ports for the guns and getting them looking right. But what you have done looks great 😊 Will look in again to watch you progress. Regards Antony.
Hi Jack. Wow your boat is truly a master piece. If weren't for the wood grain on your table I would agree with Yves above post. Real nice workmanship. Such a nice looking boat. With lots of character and style. Regards Antony.
- 174 replies
- gaeta falcata
- marisstella
Hi ? It would be nice to have a Name 😊 Welcome to MSW. That a fine looking ship. And keeping the hull natural is a good choice. More photos please. Will follow along with this one. Seat booked. Regards Antony.
Hi. A nice build. Shame on Constructo for supplying such rubbish components for a basic model. Looks like you made a good job on the cannons. Regards Antony.
- 41 replies
Hi Mike. Not easy to answer. I think you are right about"My understanding is the opening should be framed twice. Once with with a 0,5 thick plank. Then a 1,5 thick plank. " on Zoran Web site there are colour photos of the build. http://www.marisstella.hr/gotovi_modeli_galery.php?id=126&tip=2 Some close up of the hatch entrance . The 3 boards could be showing the side and the face of one board. Why the 0.5 strip stops ...no idea might be a drafting error. In the circle you have drawn... the 4mm is the width of the bulkhead. The 6mm is also looks like a board width.. 6mm X 0.5.. Again a drafting error (should show width of the 6mm X 0.5mm board.) Not sure on the 0.5mm. Don't know the kit so only guessing. Regards Antony.
- 204 replies
- trajta
- marisstella
Hi Mike. This is a very nice kit.. and you have made a excellent start to the build. I will grab my chair and await the next scene. All the best with this fabulous boat. Regards Antony.
- 204 replies
- trajta
- marisstella
Hi Doug. Not seen this kit before. Looks like a nice build. Got my premier seat booked. I like cross sections as you can add such a lot of detail. All the best. Antony.
- 99 replies
- essex
- cross-section
Hi. Look on eBay http://www.ebay.co.uk/itm/Eaglemoss-Captain-Cooks-Endeavour-Issue-84-start-to-make-the-formast-/401198177958 BTW It would be a good idea to remove your email. List of items in part Issue #841 x 300 x 4 x 2mm Ayous wood strip1 x 300 x 6mm diameter Ayous wood rod1 x 300 x 5mm diameter Ayous wood rod1 x 300 x 8mm diameter Ayous wood rod1 x Fairlead saddle, foremast top, bibs and trestle-trees (14 pieces)1 x Printed plan for the foremast All the best Antony.
Hi Jeff. Nice work on the on the removal of the bulkhead. ( The lesson here is to dry fit everything before applying any glue). You could always cut machine cut some small blocks to fit between each bulkhead that clamps to the keel.(the blocks would need to be cut dead Square or it will make the keel curve even more). Or cuting a grouve for the keel in plank of spare timber that is flat. You would also need to cut oversize grooves for each bulkheads. Regards Antony.
Hi Van. Nice little kits. We made the Black Queen some time ago. Regards Antony.
- 23 replies
- Victory
- Mini Mamoli
