gjdale
Everything posted by gjdale
  1. Well done Dan. The other side will be done before you know it.
  2. That's really cool Gil. You're certainly setting the standard! The Gold Standard, that is!!!
  3. Lovely work, as always John. She's looking a treat.
  4. Kevin, Nice to see your build back. If you're not happy with the gunport rope work, you might like to try "splicing" them. I picked up this tip from Gil Middleton's excellent log. You use a sewing needle to thread the line through itself and create a sort of fake splice. It is actually really easy to do and looks great.
  5. Nice going Sjors. I've consulted my crystal ball and I see ratlines in your near future - lots of them!
  6. Congratulations Mike on an outstanding build of a unique and interesting subject.
  7. Just found your log Wim. What an interesting subject to model! Looks like you're doing a fine job. I look forward to following your build.
  8. Just came across your log Matt. Amazing work! Very impressive indeed.
  9. Hi all, It seems ages since I posted some progress, though in reality it's only been a couple of weeks. Life has been pretty busy lately, between work and house guests, but I've slowly managed to make a little progress with the yards. I've now completed the basic shaping of all of the yards. Not much to tell with this part of the build - cut to length, place in lathe and sand until you've got the right taper. Fairly mind-numbing, but at least I was making sawdust again. The yokes for the Driver Boom and Gaff were an interesting proposition to make. The kit instructions would have you make each of these from two pieces of timber. I had some stock of sufficient size, so opted to make each from one piece of timber. As simple as they look, there were some interesting challenges in making these (read, I got to play with lots of my toys ). I've placed all of the yards together in the one picture below. The ship in the background gives you some indication of the relative size of these. In the picture, all of the Foremast yards are at the lower left (including the Studdingsail Booms), the Mainmast yards are in the centre at the rear, and the Mizzenmast yards are at the lower right. I still need to add some 2mm x 1mm strips to the centre section of the lower two yards for both Fore and Main masts (this gives the larger octagonal section for these yards). I then need to paint them and add all of the various fittings etc. The glacier moves!
  10. That's quite a difference Toni - on both counts! Your build continues to look superb. I've really enjoyed re-reading your log as you've re-posted.
  11. Ouch! Bad luck with the bowsprit Sarah, but as the guys have already said, you can make it even better second time around. I don't want to think about how many times I've nearly snapped the bowsprit doing the rigging on my Victory. Don't lose heart - you're doing a great job!
  12. Congrats Kevin - and a week ahead of schedule too! Looking forward to more progress now!
  13. Hi Mobbsie, Your idea of inserting a solid block into the tube to give support while cutting, sounds like it should work. Best of luck with that my friend! She is looking good.
  14. Safe travels Andy. I look forward to seeing completion of Pegasus on your return.
  15. Nice start to the ratlines Dan. As for glue, I used white PVA diluted about 50/50 with water. It seems to have worked just fine. Good luck with the rest of it. As you say, once you get the hang of it, it's a pretty mindless task, and you'll be done before you know it. Just don't rush!
  16. Remco, You turn even the simplest of structures into works of art!
  17. Well done on adding the missin Mizzen Sjors!
  18. Dip? What dip? Congratulations on reaching this milestone Mobbsie, and of course on your promotion too!
  19. Bruce, I had only the bowsprit yards fitted when I did mine and found I was constantly knocking them when working on the foremast ratlines. Trying to tie them with all yards fitted might be asking for trouble.
  20. Beautiful Nico, though she looks precariously balanced on that box for the photo shoot!
  21. Bruce, I've just finished my ratlines. I did them as the last item of the Standing Rigging. That worked okay, but I did find the backstays various to be a bit of a nuisance. Might have been a bit easier to do them a little earlier in the build, but it's probably six of one and half a dozen of the other.
  22. Hey Sjors, I was just having another look at your last batch of photos. It's obvious that Anja must have taken these, because you appear in your clown suit again, doing a handstand, in the background in one of them!!!
