Posts posted by Baker
6 hours ago, Katsumoto said:
So....what to do....leave them on or remove them....what would you do....after seeing the next pictures?
I've never seen anything like this on drawings. I would remove them. But, that is my non-committal opinion.
Why not provide a few loose ropes like in the picture below.
Nice work.
23 hours ago, Jonathan11 said:
If you have the time a couple of questions:
Why did you use white for the rigging?
Which colors did you use and what manufacturer makes them?
What wood oil or stains did you work with?
Thanks,
A stupid beginners mistake
(I got this kit for free (but without rigging) and had to improvise
- Tamiya matte colors
- matte varnish, the color is old oak
- Louie da fly and mtaylor
2
- GrandpaPhil, BETAQDAVE, mtaylor and 6 others
9
5 hours ago, vossiewulf said:
Mark, search MSW for Golden Hind. There are a couple promising build logs, the one below has numerous links to informational sources on 16th century ships.
Thanks Vossiewulf,
I have been working on this ship for a few years now.
Nobody knows what this really looked like. And most of the "detailed drawings" of this ship were actually drawn a few centuries later. Probably it was not a real warship but an armed merchantman.
Paint schemes are the choice of the builder.
None (brown wooden hull), red green white (English) Yellow red (Spanish). Nobody can say that you're wrong (or correct).
In the years that this ship sailed over the oceans it will probably have been repainted a few times.
And if you are thousands of miles from home, you have to paint with what you have found from the Spaniards ...What is reasonably certain :
Below the water line it is almost certainly white (the white stuff)
Inside of the gun gates certainly no red (ordinary wood color, brown)
Wales certainly not black, that came into use laterGreetings Patrick
Great work.
With all builds of the Revenge, the triangles and stripes on the hull are always beautifully painted. But I have never seen how this is done.
How do you do this?With my Golden Hind, I had to cut masking tape for hours before I could start painting
Great work Steven
Very interesting and instructive- mtaylor and Louie da fly
2
Looks great.
Very nicely done
4 hours ago, mfrazier said:
have a question. The plans call for nailing the first layer of planks on ( the hull is double planked). Is this considered the best way to do it? If so, should they be glued also and if so are the nails temporary? I am wondering, because the second layer of planning is very thin and unless the nail heads are sunk, I worry they may make bumps in the thin outer planks. I hope this makes sense.
Thanks,
Be sure to use glue to fix the first layer. And where necessary, nails are usually used.
The filler blocks is also a good idea. -
And thank you for the link.
greetings,
patrick
Greetings from Belgium
- mtaylor, BETAQDAVE and Keith Black
3
7 hours ago, olopa67 said:
I m hopping this will not create major issues later on
Why not move the hole of the ladder a little to the left. Now this is still possible.
Welcome to MSW and good luck with the exercises for walking again.
update,
The copper sheeting is ready. The rudder now has 4 hinges as it should be (The model had only 3 hinges).The railing has been removed again, it was not really what it was supposed to be.
Tested with a metal color, can be okay.to be continued, thanks for following
( Shipyard closed in the summer, on hold until october, november 2019)
Hello,
Today i started with the installation of a waterway on this deck. With the following models as examples : Batavia replica and the san Juan whaler.
First I paint the inside painting (had to do this much earlier, that would have worked easier)
All parts are first painted and detailed before assembling. Fillerblocks are used to make the horizontal parts easier to glue.In the meantime, a second (plastic) shipyard has unexpectedly been started up. This is why this shipyard sometimes has a delay.
This was going to be something quick and easy. But has become something like a semi scratch.
Thanks for following
- marktiedens, BETAQDAVE, cog and 7 others
10
Great work.
Where is the cat ??
- michael mott, mtaylor, Jack12477 and 1 other
4
We once visited the Tirpitz muzeum in Alta norway.
On the site of this museum there is an interesting film with a Tirpitz in grey color and various other color schemes
- DannyVM, popeye the sailor, mtaylor and 2 others
5
Looks great.
Enjoy the Stella Artois, you've earned it.
- Hubac's Historian, mtaylor and EJ_L
3
Santa Maria 1492 by Katsumoto - FINISHED - Artesania Latina - scale 1:65
in - Kit subjects built Up to and including 1500 AD
