Baker
Posts posted by Baker
  1. Building the howitzer compartment.
    Extra detail on the 4 seats
    New ammo (cleaning the ammo from the kit was more work) and some other extra's
    Drilling out the barrel
    I always do this with a knife like this. Just turn the blade until the correct diameter is reached. Ideal method in plastic
    But, watch out for the fingers...
    ready for painting20201130_164841.thumb.jpg.eca0caa333d5df18f7f9ed3b83ca474b.jpg20201130_165538.thumb.jpg.d7bdb188405d5803ee91cdf8e9683a15.jpg
    Parts painted, adding the howitzer is for later
    glued together (and a wash with diluted black)
    20201201_191622.thumb.jpg.bc3a752d195e95bb218d0197adcc0a65.jpg20201201_191641.thumb.jpg.329ca060782386c8f66e952b4d1f59bc.jpg
    Next, wheels an tracks. Again lots of cleaning to do...
    Thanks for following
  2. 10 hours ago, rkwz said:
    Maybe you should have a model to demonstrate the operation of the thrones you just made?
    I did not find any volunteers 🤣
    1 hour ago, G.L. said:
    Your forecastle looks like a cosy corner for lots of interesting conversations provided that there is not too much overcoming water.
    I can always add a few news papers.
    Long ago, on the farm of my grandparents, there was a box of old newspapers on the seat of ease.
    And they were not only for reading ... 😳
  3. 12 hours ago, luponero said:
    but from the "lusterklem" to the switch where the batteries are, do you go outside?
    If I understand the question correctly
    battery holder with extended wire, The wire is soldered
    The wire ends in the clamp together with the copper wires of 1.5 diameter
    Need light ? Open the helmsman's housing and insert the clamp
    simple and effective ;)
  4. Hello, i slowly restarted the Pelican build. So a small update.
    Made a removable plug for the battery of the LED lights. Not hi tech, but it does what it should do: turn on the LEDs.
    20201126_161837.thumb.jpg.7394944c37e75cf7cae752808f69176d.jpg20201126_161942.thumb.jpg.6991462d79345dc7f98a05e97631a460.jpg20201126_162320.thumb.jpg.e85c9aa749e6ceea3973ec2c62660d4d.jpg
    Some things that may not be completely correct have been adjusted.
    The stern gallery was also normally used as a combat station. So no sanitary facilities here. The holes are closed.
    The two holes in the beakhead have been modified, there are now two seats of ease.
    The black tubing turned out to be a bad idea and was not used.
    20201126_135942.thumb.jpg.10dacd6c6127c0574c4393687e378ef7.jpg20201128_121822.thumb.jpg.efe7717357a590ae665823ad394be091.jpg20201129_143728.thumb.jpg.79b5ce4774fba801f5f1a1f8150c6aae.jpg20201129_155836.thumb.jpg.6a090826d5e061bdc6cc1dbba6c35bd6.jpg20201129_155820.thumb.jpg.a58e2487edde60ed7e5cd1450621c6f0.jpg
  5. 13 hours ago, Danstream said:
    I noticed that you are used to paint with Tamiya acrylic paints. I understood you apply them by brush. If yes, how do you manage that? I largely use them, but only by airbrush. In other builds of yours, I have seen that you brush them also on wood with quite realistic results. Also in that case, how do you do that?
    Well, I'm a little very old fashioned. I don't have an airbrush. Simply the old methods. painting, dry brushing and a washing with thinned paint.
    On plastic
    Have a look at the military models (links in signature)
    On wood
    Paint with thinned paint, Let  dry, polish with scotch brite  (post 129)
  6. Building the superstructure of both vehicles.
    The ammo carrier (left)
    All parts fit  👍
    Grrr ;)
    Some cutting and sanding, and hairpins and glue
    The gun carrier : little space availeble for many things to place
    Some extra parts for detail ( from Russian kv turret...)20201122_144747.thumb.jpg.bea38f1a73fdb048df3e9723ac4ecb01.jpg20201122_152453.thumb.jpg.5b74934d74e69e906e22fc295c9ec3b8.jpg
    The instructions say to place the cannon first.
    But I don't know if the parts of the superstructure will fit
    20201122_140225.thumb.jpg.9fc420130ef3ce9b72087fed5cbf59f0.jpg20201122_152509.thumb.jpg.913955578bb38e1062567d971643f855.jpg
    so i make the superstructure first and dry fit this on the chassis (Surprise, it fits from the first time )
    20201122_154734.thumb.jpg.81b1dc17a2b304f8f2f33de67bc6cd45.jpg20201124_191211.thumb.jpg.592857a6f2fcc4802bff8838184e2f6b.jpg
    And then the cannon doesn't go in anymore
    I will place the cannon first and then the superstructure.
    It's been a long time since I've built such a difficult kit like this one. But we'll get there.
    Instruction riddles   :  Make part C and see where you put it an they sometimes forget to number part 5
  7. 2 hours ago, Robert Taylor said:
    After some research I will not be including a bowsprit sail or yard as original paintings seem to depict the Santa Catarina do Monte Sinai  with none and various other carracks from this period, albeit  some do, so I guess it begs the question  why did some and some not use them ?
    The purpose of a spritsail was to help with steering. It may be that this was still experimental during this period.
    With the help of the spritsail it was also "easier" to keep the ship on course.
    Helpfull?
  8. If you want to drill out the barrel of the cannons. Usually these were 6 pounders with a bore diameter of about 76mm (on this scale 1 mm looks ok).
    I think you have a rigging plan a few hundred years later than the GH, 16th century rigging is different from your drawings.
    And yes, normally first the shrouds,  and then the yards
  9. 14 hours ago, rkwz said:
    looks like I've opened a can of worms with this build haha.
    We can go fishing with the worms for bait.
    In this build I will only give you an idea every now and then.  It's your model and you build it There is some free interpretation in 16th century shipbuilding ;)
    Some things that I don't think are right.
    The "stairs" on the side of the hull, never seen  them on a drawing of a ship from this era
    The draines of the lower deck are also questionable
    Grating or hatches? I think grating that can be closed with hatches
  10. 15 hours ago, popeye the sailor said:
    these two look really neat!   the main tank bodies look fairly similar.........did the munitions tank have any armament?
    Neat : indeed     Armament  ammo tank  : none
    13 hours ago, Canute said:
    Isn't that similar to the chassis for a Universal or Bren Gun Carrier? It was also a light tank for the British? Interesting.
    No
    The main purpose of a carrier is to transport material (weapons) and people. In theory, people and equipment leave the carrier before entering combat
    In a tank everyone remains "safe" inside the tank and takes part in the battle
    13 hours ago, Old Collingwood said:
    Some parts in that.
    OC.
    Indeed. But i think only some parts of the suspension
    12 hours ago, Edwardkenway said:
    Interesting subjects.
    Yep.
