Everything posted by Baker
After the top plate was applied, cleaning and sanding of the hull started (with a too sharp knife 👍👎) The mudguards are cleaned up, extended and glued The upper part of the hull is adjusted and the engine exhausts extended. And i have a full bag with new clamps. Extra detailing on the hull. A previously built Mk.3 serves as example. I will see you all back in 2021
Hello from the little town of Woodland Washington
Baker replied to Roberts Orca's topic in New member Introductions
Welcome to MSW -
Roter Löwe 1597 by Ondras71
Baker replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Not words , but 👍 -
My idea (without obligation of course) The original model will likely have been painted white below the waterline. There are archaeological findings that confirm that ships from about that time have a layer of "white stuff" below the waterline. The replica is a different story. It looks like the hull below the waterline has been treated with a modern protective layer (I don't know much about modern iron ships, but these days they also have this color below the waterline. Just above the waterline, the replica is white. Once launched it looks like the hull has been correctly painted and the underwater part is well protected with modern paint. The original mayflower I was white below the waterline when she was built https://mayflowereventnews.com/1957-the-reception/ https://mayflowereventnews.com/1957-television-news/ The first voyage
Another very nice update. For you also a Merry Christmass and a happy new year
- 86 replies
- whaling
- clinker built
Thanks, Airfix sells / sold this kit as a Mk.8. This is certainly not a Mk.8, but a Mk.3 or 5. Extending the hull was successful. Reinforcements have been added inside, so later on there is only some cleaning here and there. The chance that this model ends up in the waste bin has become very small Discovered something, this build cannot go wrong The kit was "born" in 1964 (and that was a very good year ) Thanks for following, and a merry Christmass and happy new year
I agree with Kirill. Mixed colors below the waterline are very unusual Ps, very nice paintwork
Thanks everyone and welcome I think so, and it did come out later in a box. With few modifications, different models can be made, and I think the kit in the box represents a Mk.5. My Airfix Centurions 178 463/BG73 Centurion (10,5cm diesel) 179 539/GB81 Centurion Mk.2 180 544/GB82 Centurion Mk.3 181 58/GB10 Centurion Mk.5 182 646/GB94 Centurion Mk.5/2 183 1414/GB176 Centurion FV-4005 18,3cm
This will be an attempt to convert an old Airfix Centurion (Mk.8) into a Centurion Mk.1 General Centurion info: Wikipedia https://en.wikipedia.org/wiki/Centurion_(tank)#Centurion_production_mark_numbers While looking for parts for another project I came across this old "box with parts". And i knew I once had a description of how to build a Mk.1 "somewhere". This will be a build that will end in one of 2 different possibilities. 1: A model in the cabinet 2: plastic waste in the trash bin Base An Airfix Centurion. An Airfix magazine from 1977 and a book Centurion in action from Squadron / Signal publications. The hull of the Mk.1 & 2 was longer than the later models. This is also stated in the Airfix description. Plastic Surgery needed... Let dry, and fingers crossed for a successful build
After 4 weeks, ready for an update. Detailing the masts. Much time has been spent on research, thinking and testing. Masts in the 16th century could not be disassembled. Everything was solidly attached to each other. How ?? No useful info found. So i improvise, with the idea: if I make it myself on scale 1/1, how do I attach everything together. How and where to attach the deadeyes to the mast top. There are 3 ways : on top (red) in the middle (blue) bottom (green) The most common in this era is the top. Determine where the deadeyes should come (to avoid mistakes like with my Bounty experiment) The materials used are plastic, wire and copper and metal nails. The deadeyes are the same as those on the channels. Work in progress (fore mast) Details painted and colored (main mast) "Woolings" ? around the mast. Normally this is not necessary because this is not a made mast, but this gives a little more detail to the mast. The first (mizzen) mast fixed on the model Main mast and extra's dry fitted Thanks for following, likes and comments
- 756 replies
- galleon
- golden hind
Doc Watson Plymouth England..... Ahoy!
Baker replied to Doc Watson's topic in New member Introductions
