Everything posted by Matt D
Me, too. I did a google search for 18th century cannon quoin and found a pretty big range with respect to the knob (don’t know what it’s called) on the tail of the barrel. Some of the handles were almost as big and others looked puny like our 6mm pins. Like you, Rusty, I have plenty of carriages to build and barrels to weather while I ponder.
- 642 replies
- winchelsea
- Syren Ship Model Company
Here are my cheeks and hair brackets. These were a lot of fun to build. I’m working on the guns, now and I have a dilemma. I bought some 6mm belaying pins from Crafty Sailor and I’m concerned that they are too small. Here’s a picture of one with a 6mm belaying pin and one with a larger handle turned down from a definitely too large belaying pin. What do you think?
Those look terrific, Rusty. I bought the 6mm belaying pins to use as quoin handles, too. I thought they looked too small. But seeing yours, I think I'll try them.
- 642 replies
- winchelsea
That looks beautiful, Mike!
- 607 replies
- winchelsea
This is looking good, Mordswixed! This is an excellent kit for a first wooden model and it builds into a nice looking model. You’re coming up on a trouble spot in the build. Many of us had a problem with the rudder. In the instructions, it fits straight as the laser cut piece is made. But the fit isn’t right and it needs an offset to look right. Be sure to look at the other build logs to see how others solved it. I cut a new one out of scraps on mine.
Rusty, those rings and eye bolts look terrific! I'm working on the same parts and they are not easy to get right.
- 642 replies
- winchelsea
Yup, I remember. Ben, you’re a genius for making use of it there.
- 399 replies
- winchelsea
Wait a minute! There were laser etched moldings you could use for that?! Man I wish I wasn’t such a dimwit!
- 399 replies
- winchelsea
Chuck, the binnacle is beautiful! I can’t wait to build it. Speedwell? I’m 100% in! It was already on my long term wish list. I’ll definitely buy both books, too.
- 1,784 replies
- winchelsea
Chuck, I’m in for the POF project. I’m sure it will be challenging, but much easier as a group project. It’s probably my best shot at finishing a fully framed model.
- 1,784 replies
- winchelsea
I hear you, JJ, as both of those are beauties. I can tell you that I'm doing either the Hudson River Sloop or the Hornet next. As far as I can tell, @Chuck hasn't let on yet which one is next!
- 1,784 replies
- winchelsea
Looking good, Steve! Welcome to the Winchelsea Club! This project is amazing and there are several excellent build logs to learn from. Be sure to read a lot of them so you can avoid repeating mistakes. It's much better to make your own mistakes than to copy others! Is this true Baltic Birch or is it the 1/4" birch from Home Depot or Lowes? I used the stuff from HD and it was fine. It's really just the outer veneer that's birch. The inner layers are pretty soft and easy to work. But my first attempt was Baltic Birch and it was like I made it out of sheets of granite - absolutely rock hard and impossible to work on. Thankfully, I had other problems and had to start over. Lastly, the Chapter 1 set from Chuck is the laser cut AYC or cherry pieces, not the bulkheads. So you may want to buy that.
Beautiful work, James. I'm impressed by how well your masking went. You must have had the 3mm tape absolutely perfect to avoid bleeding of the red paint at the top of the white. Good job!. How is the lettering done? Did it come with the kit or was it something you added?
- 36 replies
- vanguard models
- Erycina
I think what you’re asking for is the maximum theoretical force. That would simply be the dynamic pressure times the cross sectional area. Dynamic pressure is the pressure of air in the direction of flow, which is 1/2 rho x V^2, where rho is air density and V is velocity. It’s not possible for the force to be higher than that. The ratio between the actual force and the maximum theoretical force is the drag coefficient. This is an application of Burnoulli’s principle.
I’ve made some progress on chapter 5, starting with the rudder. It’s a beautiful set, but I broke several parts in the pintle and grudgeon sheet. Fortunately, they were easy to glue back together while I was gluing them on. My mistake was that I painted them before removing them from the sheet. This made them hard to cut free and i made a mess of it. But you can’t tell now because they went back together seamlessly. the ladders went together so nicely. I really enjoyed the process. The double ladder rungs fit perfectly. It was really nice to work on. I used annealed steal wire to pin the staghorn and cleats. This made it easy to paint them. I used the magnet of my torpedo level to hold them while the paint dried. Pinning them also let me test fit them to make sure I was happy with it before gluing.
