cog
Everything posted by cog
  1. How far has it evolved ... Deathstar III or IV in the mean time? At least it works and the results are mighty fine. Those deck planks have a very nice caulking to it! Pitty can't get the same effect with a lighter. that's more to my wallet's liking
  2. Jack, The get more depth, you need a higher f-stop, as from f-16 it improves. Depending on your point of focus too of course
  3. great job on the painting Greg. The shading looks fine to me!
  4. Yes master Haven't heard that name in a while, Mark. It does, however, describe it rather well :D I'l be grasshoppering along Cheers
  5. Denis, Thanks, although I do like the brass as it is, some of it has discolourations, and as she will be painted, I'm no looking for additional complications by leaving the brass unpainted.
  6. Patrick, I see your creative juices are running free again. Looking good!
  7. Jack, F8 is nice, but I can't get the depth of focus I need at that f-stop. It gets to blurry to quick with the distance I have to the object. Besides that I need to get the iso down, as the pictures get to grainy. Idealy it should be 50 - 100
  8. Who the heck is Brian, Sam? Am I getting old, I forgot my own name?
  9. Thanks, Ken. It means I cannot take pictures after dark, as I do not have the proper lighting - like Geatan - I'm saving up for a reasonable flash, and a lightbox. I presume you want to know what the tiny little perforated thing-a-me-jig is. As far as I could make up out of the drawings, AotS and some other papers, it should be a range finder. I have to say that the detail of some of the brass parts are really astonishing. It is a strange experience to put so much time in such tiny items. One would expect it to go faster.
  10. New and improved formula I got my studio tripod out, increased iso to 800, set f-stop at 20, et voilà if you look good, you see the front is perforated or slightly easier on the eyes ...
  11. Thanks Greg, but I feel the novice once again. It has been over 40 years since I build a ship of plastic, and in this size ... it is my first. As promised, some better pictures, at least light-wise, still need to improve the depth of focus.
  12. Nice progress, Denis. The details make her more ship like, instead of a mere hull.
  13. Pat, Denis, You are so right, I certainly do not want to make boo boos wit the PE, although I do have a CA solvent solution, I do not know what the result will be when I need to remove a PE part from the plastic. I might end up with a Musashi plastic puddle I make some pictures from my very limited accomplishments last week, this afternoon. Cheers
  14. I hope you are better with numbers, Chuck A meter is 3 1/3 feet ...
  15. Grind a point on the shank of broken drill ...
  16. Good to hear you feel better Dennis. Even better to see you at the tools again. Give my best wishes to Phyl. Cheers
  17. Geatan, A very, very lovely build, with a log that has more to it than a build log but is also partly a manual, or should I say a road map. Great legacy from you I might add. It is certain you will choose a very interesting build. I have just one question: Did you ever consider to build just the stern part of the ship with the cabins at large scale, an end cross section? Salutations
  18. I would expect 24 oars, 26 shields, and 26 chests. A chief and someone at the "rudder" are missing ...
  19. Eye candy, Bob. Each time I see them I would like to build them too!
  20. You like complex things it seems. I see you've mixed brass and aluminum on your vents too. Looking forward to the installed funnels
