cog
Everything posted by cog
  1. That's the whole point about kit bashing, once you start, you're hooked
  2. Oi Butts, Works with decals on grey as well Haven't seen you crap an airplane yet RGL ...
  3. What I do: I spray a layer of gloss lacquer, add the decals, when fixed, spray a layer of clear lacquer, satin or mat, and after that shade or weather or whatever
  4. Quite a difference compared to the kit's, both your guns and your carriages came out wonderful. I can even see the hole for the peg in the axle. Very well done!
  5. Depends if the shading should pass over the decal or not. If it does it's easy, than it is "Yes", you'll be inventive enough for the other possibillity
  6. How did you know ... straight forward as always ...
  7. Another challenge for the Mo ... I would suggest to make a new piece ...
  8. I would say: "Hang in there mate" you've got still some yards to go ... looking good
  9. The latter is a must as you would hardly see a line on a slick surface with that hardness. I saw the video's ... very educational. Thanks for pointing those out, Mark
  10. Impressive, I'll have a look at that video. Are you certain it's a 6H not a 6B pencil? Lines look like they are made with a soft pencil
  11. With regards to tying down the prop, you could use eybolts, this may be a source. You will probably be able to make something yourself based on these Now I see her at dinner, Steve, she does match your interior quite well
  12. You are getting better, and better at it, Patrick. Each ship shows your progress
  13. beautiful work Johann. It shows you took the time to prepare!
  14. 'arry, What's a few pounds more or more ... fortunately I couldn't buy it as I'm unable to carry it presently ... you need to build a shed around it
  15. So no ships or boats, I presume the short refer to destroyers and such ... Well you are building a tank ...
  16. I've had my eye on the gun, but haven't seen any after market ... and thought it rather expensive, but that may be the case in Europe, whilst it is "afordable" in the US
  17. Than he should use the Halve Maen, use a Dutch ship not a Swedish one. Furthermore, the name is De Vliegende Hollander, you shouldn't translate names
  18. flow improver is only useful to distribute the paint evenly, it doesn't help against clogging your brush, or improve the flow from the airbrush
  19. It's quite limited Tamiya's colour palette. That's why I like Vallejo. Did you dilute the paint (even the model air)?
  20. love the look of that hull, Jules. Could do with some less elastic bands though ...
  21. Thank you for sharing your rich history, profession, and hobbies
