Everything posted by Retired guy
She does look beautiful Joe and I also like the lettering, have this to do soon have got some dry and wet transfers not sure which ones to use yet. Regards Richard
- 139 replies
- benjamin w latham
- model shipways
Last update I stated that up next was going to be making the Ratchet Quadrants and associated parts which go along with them, so it has taken me awhile to figure out how I was going to make them, so went back to the drawing from LB Jenson and also looked at a picture on the web of a Ratchet Quadrant and this is my take on these. Picture from LB Jenson book (this is to help with my build if not allowed please delete) With the gears I had made they were .046" wide so I needed .046" + width for middle part then add .010" for sides which go passed gear teeth. and looking at drawing I assumed they had a ridge in the middle because I see he drew 2 lines, so made body from three pieces of .016 brass sheet, the middle piece I cut out a little bigger to have a ridge, the sides I made from ,010" sheet brass. Once I got the shape I soldered the three pieces of .016" and one of the .010" together then the other .010" side I CA glued so that I could remove later then I made an easy jig so that I could drill holes as per drawing. https://imagizer.imageshack.com/v2/800x600q90/923/tZJ4eu.jpg https://imagizer.imageshack.com/v2/800x600q90/924/NxqcgE.jpg Then made a jig so that I could work out heights https://imagizer.imageshack.com/v2/800x600q90/922/gmFoD8.jpg https://imagizer.imageshack.com/v2/800x600q90/922/mJZDx9.jpg Made the shackles and did a some clean up and then put back in jig to work out link https://imagizer.imageshack.com/v2/800x600q90/923/bYaK9L.jpg https://imagizer.imageshack.com/v2/800x600q90/924/LmFVCy.jpg Got the dimension needed then bent and soldered links https://imagizer.imageshack.com/v2/800x600q90/922/vZHvgu.jpg https://imagizer.imageshack.com/v2/800x600q90/924/QVkOb9.jpg After this I un-glued the one side on both pieces so I could solder a piece of .010" round brass so that it would hold to the gear once I install, forgot to mention the three pieces of .016" I ground away so that the pawl would fit. https://imagizer.imageshack.com/v2/800x600q90/922/v4iv60.jpg https://imagizer.imageshack.com/v2/800x600q90/924/He1km6.jpg https://imagizer.imageshack.com/v2/800x600q90/924/pK8TFL.jpg Next was to make the handle shafts, made from brass machined to fit square rocker then filed to round for the shaft, mounted rocker with some small bolts then made the handle parts. https://imagizer.imageshack.com/v2/800x600q90/923/ulGqsD.jpg https://imagizer.imageshack.com/v2/800x600q90/923/XKJSsL.jpg https://imagizer.imageshack.com/v2/800x600q90/924/h7ru8d.jpg Reworked the jig so that I could solder the handle parts to the shaft https://imagizer.imageshack.com/v2/800x600q90/923/SCxUCT.jpg And it came out just as I had planed https://imagizer.imageshack.com/v2/800x600q90/924/ENQ1gi.jpg Made the small pawls and then Casey Blacken all parts https://imagizer.imageshack.com/v2/800x600q90/924/Ir5S1F.jpg Last pic off the whole Windlass still need to make the u-bolt pins https://imagizer.imageshack.com/v2/800x600q90/923/6GkfRR.jpg Kit supplied parts https://imagizer.imageshack.com/v2/800x600q90/922/YjoI2B.jpg Next up to make some pump parts, will be looking at Gary's (FriedClams) blog did see he has made some of these 🤔 https://imagizer.imageshack.com/v2/800x600q90/923/K8e2m8.jpg Thanks again to all who comments and all who hit the likes do apricate it 👍 Until next time Regards Richard
Just catching up as well Wally your details and gun rigging is brilliant well done 👍 Regards Richard
- 950 replies
- syren
- model shipways
You have captured the deck house as per the pictures this will look brilliant once installed 👍 Regards Richard
Blimey 12 pages of brilliance, very crisp and highly detailed scratch work and then to boot all the fantastic weathering boy does that bring out the model 👍 my bad for not looking around more. Regards Richard
It was great to hear all was Ok your side of the pond and it was a very nice update Keith Regards Richard
Very nice update Wally guns look very sharp 👍 also like your pictures shows your work off very well. Regards Richard
- 950 replies
- syren
- model shipways
Wow Wally you have done a brilliant job very nice indeed 👍 Regards Richard
- 950 replies
- syren
- model shipways
