BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. That is some very fiddly work and you have achieved mastery over it Danny - very clean and precise. cheers Pat
  2. Just an airfare Carl; I can provide the 'coldies' cheers Pat
  3. Welcome aboard Richard; lots of helpful advice both in the forum and in the articles database. Look forward to seeing your work. cheers Pat
  4. Hi folks, I have been making slow progress lately as the research side of the project has taken more time than I can really spare and, I have been busy making furniture for the nursery for the soon to be born first grandchild. The following pictures show some of the small items I have been, and continue, working on. I have also completed the heads, stern bench and made a start on the common service lifebuoy (more on the latter in a later post). First the pissdales. These are only 8mm across, 4mm deep at the apex, and 4mm across the opening. The drain tube looks a little out of scale in the photo but look OK in real life These still need to be cleaned up a little. The second photo shows the process of making the rudder gudgeons. The process I have used is the one Ed Tostie described in his Naiad build and modified in his YA build; this process and works well once you learn to control the copper when cutting (hence the odd shape - it got away from me a couple of times ) - Ed did warn of it grabbing so my error . These still have to be polished and cleaned up a little. I have made 4 but only two show in the photo. The wood strip is a jig of the same size as the rudder post (width and depth). The straps are short as the rudder post is quite thin and in reality the gudgeon straps would have wrapped around the post. however, as We have already fitted the propeller and its control mechanisms (see earlier posts) this is impossible now so will terminate at the end of the post. The third photo shows where I am at in constructing the towing timbers (bollards). These are about 75% complete; the process I used was to cut some 4mm brass square tube to length, solder a cap to the top, drill for the cross pin, insert and solder the cross pin, insert and solder the base locator pin. The cross pins have yet to be trimmed to size and the ends rounded over with a cup burr. The bottom round bar pins are for locating the bollards and to reinforce the glue connection. Then, a lot of cleaning up before blackening. I decided to make them from brass as at this scale, I found it near impossible to make a sub post of wood and add an iron cap. These will be blackened and would appear much the same as if I had made them from wood and iron as the whole item was painted black anyway. I don't know how Ed does such detailed work at this scale - respect! cheers Pat
  5. You'll get there Mark, some good progress there. cheers Pat
  6. Snowy, I went through this saga with my Endeavour build. I am about to lose the internet connection here as a new system is being fitted today - fingers crossed all goes well If i get a chance to find this I will update this post but otherwise I will do so after reconnection. in the meantime try looking for The Boats of Men of War by "May" . A search through the forums may also bring up a few answers as it has been raised on several occasions. [Edit: a quick search found this, but there is more definitive info avail. cheers Pat
  7. Great to see you back at it Rusty; you haven't lost any of your skills during the interval - very nice work. cheers Pat
  8. Nice work Carl, plenty of detail and well worth the frustrations. Mark - I wouldn't recommend wax of any type unless you are absolutely sure you will get it all off before painting? cheers Pat
  9. Stunning work yet again Ed, everything is so well manufactured and finished - QUALITY cheers Pat
  10. Thanks Ed, a very nice clean job you have done of that, hence my question. I have also just noticed the material you have used in the vice for holding the mast to minimise any marking and movement. Will need to find something similar. Thanks again for all the feedback and ideas cheers Pat
  11. Danny you have really mastered this building medium very quickly; very nice work and great detailing at that scale. cheers Pat
  12. Hi Ed, very nice work and a great explanation of techniques as we have come to expect. Maybe a silly question in that I have missed it, but how do you get the futtock deadeye lower eyes through the small trestles? Are the holes drilled and squared large enough to accept the eye or do you expand the lower eye after threading through as a flattened piece? cheers Pat
  13. Nice analysis Jason. I agree with the RB/Syren combination being the more realistic. Thinning the quoin bed should resolve your issue I think ? Nice work. cheers Pat
  14. For irregular surfaces also try those refillable fibre bristle propelling pens BUT do take care not to get a fibre remnant in your hands/fingers as they are a real pain to remove They clean surfaces really well and I find it not even necessary to do any other prep on small items; although treatment to remove finger oils etc if not wearing gloves is recommended. cheers Pat
  15. Looks great Steven and a tribute to your efforts. cheers Pat
  16. Great smithing Ed, they look very good! I sure hope there is enough strength in them at the tips/ends to sustain the pressure of the shrouds and preventers etc without them bending or will the cantilever action reduce this a little? cheers Pat
  17. Sorry to hear about the water damage Karl; but I bet the new version will be even better. Any salvageable parts to save a little time? cheers Pat
  18. Looks really good greg; you are really getting a handle on that airbrushing now. cheers Pat
  19. Seeing that last photo Gaetan really shows how big your model is. Don't breathe in any of that dust mate! cheers Pat
  20. Nice work Danny, she is coming together very nicely. Do you finish these card models off with a coat of lacquer? I ask as paper/card does not have the longevity of wood and wonder how long they will last without some preservation. cheers Pat
  21. Great to see you back OC; but, as Carl has said your health and well being must take priority. cheers Pat
  22. Ed, one idea (if not too late) for the leather; on my Endeavour I used Brown paper to simulate the leather lining - right thickness and very pliable. I used a sharp pencil tip to simulate tacks where needed, and applied with dullcoat (lacquer) which stuck to the paper and provided a leather like look cheers Pat
  23. Really looking good now Russ, those cap rails added that 'finished' look to the bulwarks. cheers Pat
