BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. That will sand back nicely Russ as the planks appear to butt up very nice and cleanly. cheers Pat
  2. Hi folks, well after a delay due to holidays and some further research, I decided I needed to make some further progress with the build. I am trying to create and fit all of the necessary detail to the inside of the bulwarks that need to be done prior to painting as I do not wish to mar the finish once the paint has been applied (airbrush). I am also hoping to identify and fit all the necessary fitting to the inside of the bulwarks prior to fitting any deck furniture and equipment as these latter items will impact my ability to add detail later - hence the research. I have fitted the pinrails, the chock in the bow through which the jib(s)' downhauls etc are led, and have made a start on the after bench through which the stern davits are fitted. The following photos show my progress on these items; the after bench and davits are only loose/dry fitted at the moment.. I have yet to let in the ash shute, pissdales and heads. i am also just starting to contemplate where and how to let in the scuppers. I am also experimenting with the Lang Scuttles, which look a little like a porthole from outside, but are quite unique. I have located a drawing (following) showing the detail and an article in the Nautical Magazine of 1841 (extract shown) which provides me with some relevant detail. essentially I will mimic the external appearance only by using a very thin walled brass tube (drilled out) into which I will set some thin acrylic . I will then drill out the holes in the hull to match the OD of the assembly and glue thin slices of this material into them. Unfortunately I only have 10mm acrylic rod so I have had to turn the diameter down on my lathe - this proved somewhat difficult as the rod tended to melt if I had the cutting angle or the rpm wrong- persistence paid off I would value any feedback on how to turn acrylic properly as i cannot get rod of the correct diameter (being so small - 1.8mm to fit the ID of the brass tube). The following photograph shows that I can achieve this look and my experiment in a scrap of wood does the trick. When I shine a light behind, it mimics the appearance of thick glass. The expanded brass tube slice (top right in the photo) is the start of my experimentation for the scupper inlet in the waterways. My current punch is not suited and I will need to turn a better punch and die arrangement to use. cheers Pat
  3. Sorry I have missed this log until now Amalio; simply astounding quality and an inspiration for all modellers. cheers Pat
  4. Those shrouds look great set up the way you have done them Ed. cheers Pat
  5. Very nice updates Dan; that is a very good rendition of the windows using styrene and will add very nicely to the great detail you are achieving. As Druxey also said, the portholes are a marked improvement. I am very much enjoying following your build. cheers Pat
  6. Very nice work on Speedwell Greg and best wishes for a successful publication. cheers Pat
  7. Some nice ideas among that lot Greg, she should look good. The main stressed hull areas would be the water outlets/discharge area and rust streaks from angles/joined equipment where water would collect. Some rust would develop from the anchor and cable rubbing on the hull also. In 1945 I think extreme long periods of action may have been very few for Japanese Navy? cheers Pat
  8. Good progress there Danny and you seem to be overcoming the challenges being put to you (despite the dockyard workers :)). Interesting build you have going. cheers Pat
  9. Only a very knowledgeable person would pick up those differences Gerhard; you did very well with the info you had on hand at the time. cheers Pat
  10. Great progress Dan, she is coming al;ong very well; the careful sanding has sure provided great dividends for you. cheers Pat
  11. Nice work Gerhard, your Cairo is progressing very nicely. Any update is a good update - it took me 14 years to complete my first model Life simply gets in the way sometimes. cheers Pat
  12. Simply stunning work Karl, that is another very fine example of miniature joinery - a joy to view. cheers Pat
  13. Boy, i go to the footy and find you have built a hull skeleton - slow down for the rest of is mortals Danny, I am out of breath keeping up Great start, and now that you have the parts sorted there will be no holding you back - looking forward to this one. BTW, if you need further help with the language give me a PM, i know someone whom may be able to assist you. cheers Pat
  14. Glad to see you back Mark. Sorry to hear of your health scare and offer my most sincere wishes for a full recovery mate. cheers pat
  15. Very nice detail and work on those funnels Greg, they look really good. did you drill holes for the rail standoffs or simply glue them on? cheers Pat
  16. Great progress Steven, she is coming along fine despite the issues caused by the garboard plank. As Druxey has said - great attitude to the process. cheers Pat
  17. Very nice work Dave,the efforts paid off as they look very good. Did you try putting bits of white card behind the shrouds? i found that help me focus on the area of work a little better as the black on black against shadows certainly does do your eyes (and the brain) in. cheers Pat
  18. That hull planking looks good Russ, she will be 'dressed' before you know it cheers Pat
  19. Simply stunning Jay; very nice finish and i really like the shape of those blades - some serious carving to be done with those., cheers Pat
