BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. And so the Pagoda takes shape - it is isn't it? Seriously though Mark, this is looking good so far. I must have missed a post as I thought you were reconsidering the Hahn method? cheers Pat
  2. Nice work Piet; now while your at it and have a nice work flow going - I'll have a dozen cheers Pat
  3. Very clean work Danny, the result is stunning and makes a difficult shaping task look easy - always the sign of a good tradesman. cheers Pat
  4. The type and quality of the stock thread is important when it comes to making scale rope - there are some Cordenet crochet threads, that at some scales looks OK off the spool for small scale stuff, but if you are making up scale rope, there are a few considerations for you to ponder. You need to minimise stretch so a lot of users go for cotton or linen for this; if you use poly you need to stretch the rope a bit to 'set it' after it is made up to remove the elasticity otherwise it will 'change' tension on the ship with use and humidity etc. You should also try to find a thread that has little or no fuzz to it, not just off the spool but also after working it. You also need to find the right lay stock. You need LH lay to properly make up RH lay scale rope. If you cannot find the right lay, some modellers will find smaller stock thread, make up the appropriate lay and then remake that into the rope desired. You need to do a bit of experimenting to find what stock size you need to get the final dimension of the made up scale rope. Don't let this put you off as once you have found good stock thread, and experimented a little it is actually reasonably easy to make the scale rope (with an appropriate rope walk that is) I have used Gutterman, YLI and Cordenet 100% cotton for stock and each produces good end results. Personally I stay away from poly as while the resulting rope looks really good and has a nice 'feel' to it; the amount it stretches causes me some problems - but I stress that is a personal choice. If making scale rope is a little too fiddly for you at this stage of your hobby there are a couple of good after-market suppliers - you need look no further then Chuck's rope available from his Syren shop for example (no association etc....) - there are several plaudits to his rope in the various build logs. Good luck Pat
  5. Great to see you back at it Rowan, and I trust all goes well for your wife. These types of speed bumps are inevitable with the poor quality / sparseness of the AL Instructions to the point I ignore them completely now and simply follow the Marquardt and Parkin drawings as need for my version of the ship. Good luck with the recovery process, at this stage it should create no further problems down stream once corrected. cheers Pat
  6. Looking great Mark - all you have to do now is remember which mark is which cheers Pat
  7. Hi David, I cheat (oops perhaps I shouldn't admit that ) - for POB kits (as per Hamilton's post) I cut the keel away on the backbone wood from the bottom of the rabbet edge down (after marking it out of course). I then remove sufficient wood from the rabbet area to allow for the total thickness of the planking (bevel the edge) to create the rabbet recess. After assembling the skeleton (backbone and bulkheads) and sometimes even after the hull planking, I fit a new keel which in effect creates the bottom edge of the rabbet for the planking. You can include the stern post and stem in this process also if you wish. If you do it after the planking, my trick is to dry fit the keel before planking and create a couple of alignment holes in the bulkheads which will align with pins in the top of the keel when they are finally fitted (just leave these holes clear when planking). For me this creates a very clean edge to the planking, and if using a good hardwood, provides a better finished keel (stem and stern posts etc if all are done) in which you can add the scarfs etc- and who can tell the difference if you don't tell them cheers Pat
  8. She's coming on very nicely Ollie, some great detail appearing - now onto that wonderful task (chore?) of rigging You may wish to hire some of Danny's (Dan Vad - HMS Vulture Scratch Build) trained rigging spiders cheers Pat
  9. Have fun making sawdust Mark; I'll be way back in those far stalls munching the pop-corn cheers Pat
  10. Now Grant, that is an invitation to much innuendo - sure is better than looking at the south end of a north bound camel though! Oh by the way Rusty, very nice planking; the boxwood looks great! cheers Pat
  11. Hi Ulises, nice build! WRT the planking, I once experienced a similar butt-shift pattern issue and in my case it was due to me using a central King plank. I proceeded to build the pattern down one side of the hatch opening then worked across the bottom and forgot about the central (king plank). I can't quite make out whether you are using this planking technique of a central king plank and then starting the shift from either side of this or not? May not be the cause of your issue but just in case cheers and good luck in resolving this. Pat
  12. Hi Errol, that's a good start mate and I glad to hear that my build notes may be of assistance to you; there are also a couple of other very good builds happening which may assist you also (you have probably seen them). Are you planning on filling the bow with filler blocks faired to the dimensions of the first planking? If not, you may wish to consider extending the first layer planks to the bow (bend at the point where you currently finish) to allow a good contact area (for the glue) to hold these planks in place where they bend. Please feel free to PM if you need any clarifications to any of my posts. cheers and happy modelling (and a belated welcome to the Endeavour build club ) Pat
  13. very nice work Remco - another display of your excellent craftsmanship. cheers Pat
  14. That's an excellent boat coming along there Ollie. Good to see you up and running again mate. cheers Pat
  15. Have not heard of them prior to this; is tick to the known quality of Swann Moreton which if bought in bulk and the unsterilised version, are reasonably cheap now.
  16. Ah, I think I can even smell the sawdust from here Happy modelling Mark. cheers Pat
  17. Oh boy - a bit more work - Maybe put her on her side careened a la repair at Cook Rover? Those studding booms look good! cheers Pat
  18. Coming along nicely Rusty - another fine build. Look forward to seeing your progress on this one. cheers Pat
  19. Rich, try dry fitting the completed parts to the hull and marking out the positions of the gudgeons and pintles etc before final assembly. I use low tack clear tape to temporarily position the rudder in place using some small offcut wood to provide maintain the even spacing between the sternpost and rudder. Then lightly mark the positions (centrelines) of the metal straps for the gudgeons and pintles on the rudder and the hull (make the marks so that the straps, when fitted, will cover them). Remove the rudder and set to work - I usually do the hull first and then do another dry fit of the rudder just in case there are slight alignment changes resulting from the first step. To assist, it is easier to make the gudgeons and pintle sets and shape them for each position, ready for assembly - I also shape an offcut of wood to duplicate the rudder leading parts on which I shape the straps to better fit the actual rudder without damaging the rudder. If you are simulating the bolts, pre drill the straps as this makes the fixing to the actual rudder much easier, and provides a template where to drill the hull to receive the bolts. On the other hand, if your question is about making the gudgeons and pintles, have a quick search through the site as there have been several very good techniques discussed. I hope this helps a little. cheers Pat
  20. Hooo boy Greg - frustrating, soul destroying and irksome all at the same time - a year's work down the drain (that is the hardest to take). Well the philosophical aspect is that what is done is done and you now just need to assess the damage and how to fix it with the least rework - I am assuming some parts are reusable? Good luck! Hopefully the moggy won't feature as a set of bagpipes as a result of this Pat
  21. Ah, thanks Danny - that is an interesting line of thought - and a VERY practical one - this warrants a lot more thought and is possibly the answer to the riddle . cheers Pat
  22. Very nice Danny - it seems you are a man on a mission - the updates are coming thick and fast cheers Pat
  23. Hi Greg, some great progress mate - the end is in sight Those anchor stocks look really good! cheers Pat
