BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. More candy for the eyes; a delight to view your updates Brian. cheers Pat
  2. That must be so frustrating for you Glen; but, I am sure you will figure it out. cheers Pat
  3. Keith, ever so sorry to hear of this sad news; my thoughts are with you and other members of your family. When the time, and your thoughts, are right, perhaps you may complete the model as a lasting tribute or memorial to him. My regards and condolences mate, Pat
  4. I'll jump on this bandwagon also. I have had most of Jim's tools for many, many years. Over that time the tools have been reliable, accurate and safe to use. The few issues I have had were quickly sorted and parts sent when necessary, much appreciated noting I live on the other side of the world cheers, and many thanks Jim and Donna Pat
  5. Boy, you're not sitting around on this - progress is impressive Rob. cheers Pat
  6. Thanks for sharing; what a fantastic opportunity that was; especially collecting a few small artefacts. let's hope they find the funds to better preserve the vessel; if all these small bits keep falling off who knows what will be left in the longer term? cheers Pat
  7. Hi Clipper, not out of left field at all. I have purchased and consulting Andrew Bowcock's excelnt "CSS Alabama - Anatomy of a Confederate Raider" which, along with some other related material, has been the source of some very useful information. There are also some useful 'Official' ship's documents for contemporary vessels of a similar design in the NMM which have proven useful. My problem is that analysing all this by myself has proven very time consuming and slowed down the build considerably. The main reason/cause of the slow down being that I jumped ahead with the 'armament' only to find the initial research (sweep/race patterns) proved wrong and trying to fix them would ruin the model (deck). So lesson learned - thoroughly research and validate before building cheers, and thanks for your interest. Pat
  8. Hi Greg, nice work, your Sydney looks great. If I may be permitted one suggestion: the Mk92 dome appears too shiny compared to the weather hull? (May be a trick of the photography though?). cheers Pat
  9. Very nice work Raz, I especially like the turned fittings. I don't comment much but look in often to follow your progress. The model is looking great with all this new detail. cheers Pat
  10. Rob, some of those shots really show the very fine job you are doing with this model, very nice work indeed. I also very much enjoy reading the background discussion all of you are having in resolving the best possible outcome for her true lines and equipment placement. I just wish I had someone else with similar deep knowledge of the Victoria to bounce my ideas off cheers Pat
  11. That rigging looks good Keith, I think you have done a pretty decent job of it. We are always our own worst critics cheers Pat
  12. Hi Peter, that looks pretty good. Please note the lay of the rope for the shrouds may also affect the amount of twist. Most shrouds of this era were cable laid (left hand). I was referring to the sequence or method you actually put the lanyards through the deadeyes; from your response I am still not sure you understood my comment. Please ignore/forgive any unintended 'motherhood' in the following if you did understand. A good example can be found here in the forums at post #20 in the following link: Basically from forward to aft and not crossing (I note yours do not cross so may not be the cause, so it may be twist imparted from the shrouds themselves). Another helpful diagram is provided on the Suburban Ship Modeller website. Hope these clarify, cheers. Pat
  13. You're making some significant progress Peter. The twisting of the deadeyes may be related to the way you reave them - have you done them the recommended way (as in the real ships)? cheers Pat
  14. Ditto the above - mate you will just have to stop work, I am running out of superlatives for your workmanship and detail. cheers Pat
  15. Thanks for looking in and the info Steven; appreciated. Yep, the one and the same vessel. In her early years Victoria was attached to the Water Police with her Captain dual ranked as a Commander (Victorian Navy) and as a Police Superintendent, the rest of the crew were similarly dual rated based on their ranks. I was aware of the Shenandoah and the antics surrounding her visit. There is an excellent display and artefacts held by 'SeaWorks' in Williamstown, (some in the the "Pirates Bar'), if you are ever down give me a hoy and we could go visit. Also of interest, Churchill Island (near Phillip Island in Westernport Bay) has a couple of cannon on display in the grounds which they proport are from the Shenandoah. Attached is a piccy of the model of (Capt. Douglas) Elders Gun Raft 'The Elder' for anyone interested. cheers Pat
  16. Very clever indeed. The yards with their furled sails look very effective, I will really have to try your technique. cheers Pat
  17. Ouch, hopefully not a difficult repair? The 'canning' effect looks good Greg. cheers Pat
  18. All I can say Keith is WOW! but even that did not sound right beccause my lower jaw is still dragging on the ground. cheers Pat
  19. Thanks for all the comments, likes and support/encouragement folks, much appreciated. Some good ideas presented/offered which may cause me to revisit my technique. The use of the crossed pieces inserted into slots sounds promising, thanks Eberhard. cheers Pat
  20. Nice find Bruce, makes interesting reading. cheers Pat
  21. Next up are the spiderbands which require lugs to be soldered to some small thin walled tubing. I made up a jig which I think is self explanatory. I used aluminium as the solder will not stick. The jig allows me to keep the lugs square to the tube even though in the photo they don't look it (optical illusion). These lugs have yet to be drilled, shaped and cleaned up, then I will use a razor saw to part of 1.5mm wide band with the lugs attached. The real tricky part will come when I have to try and impart a very shallow taper to the ID of the tube; hopefully the solder (silver soldered) will hold. cheers Pat
