Gregory
Posts posted by Gregory
  1. To get a better  feel for the tapering some measurements help.
    Determine the number of full width planks at '4' then divide the measurement indicated in green by the number of planks.  You might also want to do the same at the stern.
    However the measurement at the stern might be a little  bigger than '4 ' which would require wider stock or the introduction of a stealer.
    With a first planking I would leave some gaps and fill them in with scrap.
    It's really not that critical for the first planking, but it makes for good practice looking ahead to the final planking.
    I really did not do a proper job on my earlier builds, so they would not serve as a good example.
    I plan on trying to get it right this time but I haven't caught up with you as far as planking is concerned.
    Hopefully I will have something soon.
  2. Be sure to bring up questions before gluing or cutting.  I have built Gretel before - a couple of times actually.
    I have built for family members who just had to have one of those wooden ships they know I spend so much time on.
    It's such a quick little build, if you stick with it.  I've made a lot of side trips that keep me from forging ahead.
    I like to experiment with decorative touches since it was supposed to be a 'Pleasure' yacht.
    Here is a shot from my Gretel in the gallery.
    I played with making patterns with the wood on the cabin roof and quarter deck.  The cabin doors were printed.
    The rigging leaves a lot to be desired because I didn't pay attention to scale very well.  The belaying pins can use refinement, and I didn't show proper coils at belaying points.
    I built this kit before I had joined MSW and  the expertise to be found here.
  3. Maciek,
    Allan seems to have some historical info regarding gun tackle that none of the kit makers have, or they choose to ignore it.  So, 99% of the builds you see here will have the double/single  configuration you have used.
    Many of the highly credentialed  Anatomy of the Ship authors also go with the double/single rig without regard to gun size.
    You have a very nice model, and your gun tackle looks really good.
  4. 4 hours ago, Intasiabox said:
    The kit is 20+ years old.
    Have you been able to inspect the kit?
    A few years ago, ModelExpo unloaded a lot of AL Bountys at a very low price because a lot of the wood was moldy.  Might be a good reason to avoid it if mold is present.
    Otherwise, because of the reasons Jaager mentions, old, dry wood is not necessarily a problem.
  5. Don't worry about sanding the first planking too thin at the deadwood.. Just allow for  the 2nd planking to fit flush with the keel and stern post.
    I have built a couple of these kits; one of the older original Mamoli kits, and one of the newer Dusek versions, which I believe you have.
    In the new Dusek kit, I found part 17 to not be a good fit,  being too small.  Too big would have been easy to correct.   You may need to make a new part.
    This is how the supplied part fit on the plans.
    I found a couple of layers of card stock to be adequate for making a replacement.
