Everything posted by Gregory
My laser cut planks
Gregory replied to modeller_masa's topic in Building, Framing, Planking and plating a ships hull and deck
Have you checked out LightBurn! They have an unrestricted 30 day trial. One of the powerful tools is a bitmap trace that I found a lot easier and more powerful than Inkscape. Greatest of all is you can have many layers. Each with it's own power and speed setting. You can control the order the layers will cut or engrave, or you can choose a layer to not cut at all. When I first started using it, it was like I had a new, more powerful laser. -
My laser cut planks
Update: I originally tried one of the Atomstack brand 10w machines looking to save quite a bit. but really wasn't happy with the build quality or the performance. However, if you want to stay in a lower price range it shood be adequate. I was able to return it and I bought the Xtool 10w machine, which I upgraded to 20w and have been using for over a year now. The working area is 432 X 406mm but I believe there are bed extensions available. modeller_masa may be able to tell you more about a larger work area. Getting a 40w machine will put you in the $2,000 range, but if that is in your budget, I can only recommend the Xtool brand because I haven't had any experience with other brands. I also recommend you get a Honeycomb worktable and the air-assist feature. Some type of exhaust system is also a must have regardless of the laser power. I also highly recommend Lightburn software to drive the laser. It provides a very powerful and versatile interface. If I can answer any more questions, I will do my best. -
My laser cut planks
I'll get back to you later. Just saw this and will get back to you with particulars. I know it is Xtool brand. I really like Xtool compared to some of the cheaper brands.. -
Books to learn Fusion 360
Gregory replied to allanyed's topic in CAD and 3D Modelling/Drafting Plans with Software
I would enjoy seeing something relatively simple like a Longboat. The steps learned could be easily applied to a more elaborate design. -
Looking for pre-made sails for Mamoli Britannia
Gregory replied to MOURADATOR's topic in Wood ship model kits
Do you have the plans? Mamoli kits do not have a separate instruction book. All the instructions are written on the plans. -
HMS SUSSEX by KarenM - FINISHED - 1:48
Gregory replied to KarenM's topic in - Build logs for subjects built 1501 - 1750
Just curious why you think so? -
Staining
Gregory replied to Eindride's topic in Painting, finishing and weathering products and techniques
Agree particularly with number 2. The Minwax & Varathane stains I am familiar have a consistency similar to mineral spirits. Unlike paint, there is no obvious build up on the surface of the wood. How would a layer of anything, measured in microns, appear out of scale? -
Yes, but I'm not sure it's necessary depending on how you go about fabricating. I didn't document my method very well, but I could come up with something if you are interested. I will eventually be doing it with my rattlesnake, but can't say how far in the future that might be.
You might consider card. It really lends itself to simple shapes like this. I used black card, but it takes paint very well so the color of the stock is not that important.
Hard to call it a rip off when the seller refunded and is shipping another kit.. Appears to be an honest mistake that was quickly corrected.
- 16 replies
- Lady Nelson
- Victory Models
A lot of room to come out ahead of the original painting.
- 562 replies
- vanguard models
- alert
Syren is at the top of my list, but Crafty Sailor has blocks that look a lot like the ones at Model Expo.
