Gregory
Everything posted by Gregory
  1. You might consider dropping the metal ring, which is just a kit convention, and using wedges, once you are ready to step the mast. ( you can make the wedges look a lot neater than this ) Or fashion a wooden fabrication that you will find on a lot of models.. ( Chuck's Cheerful ) On the actual boat, this area would have a canvas cover, which isn't seen often on models..
  2. Could you elaborate? The sheer strength seems to be more of a problem with non porous materials, which doesn't include most woods. In what way, would the planking on a ship model, be subject to stress after the CA has cured?
  3. Post #64 From Mark's post has a comprehensive list...
  4. Here are some nice drawings. These instructions for Chuck's built up blocks might help with ideas.. More instructions..
  5. I have used clear plastic wrap and zip-lock bags.
  6. It became popular because of the very fine, almost invisible grain and it's carving properties. It holds a very fine edge. Personally, I like the look of wood grain on large areas like the hull, as I prefer not to paint. Purists however, will decry open grain wood as being way out of scale for model ships. Too me, boxwood looks like something besides wood, like marble or ceramic, so in that regard, I like it for decorations and things like figureheads. The price has probably at least quadrupled in the last few years, and it does not show up in models here as much as it used to. Chuck's Cheerful and many of the early kits he sold were based on Boxwood.. So, you will find several Cheerful logs that utilize boxwood. I have really grown fond of cherry as of late, but it's darker color is not appealing to a lot of folks.
  7. There is a nice kit at Syren Ship Models, but at 24mm it may still be a bit too big. However, if you take a look at the downloadable instructions, they may help with making your own. Cornwall Model Boats has a nice selection, but shipping may be a little slow these days..
  8. Lay some masking tape along the top of gunwales and trace the edge with a pencil.
  9. Here is one method that looks pretty good: Your rope looks a little heavy. You might consider scaling it down a bit. There are those who will refer you to tables and establishments, but I like to go with what looks good.
  10. Just a note, it may take several swipes with the acetone. The cured CA is essentially plastic, and the acetone dissolves it.
  11. You might hold out for the long awaited Amati 1:64 Victory
  12. This is an image from a Caldercraft build, and the look you might be going for.
  13. Not an expert, but I have never seen two tackle on the rear like that. It is the in-haul to haul the gun inboard. I wouldn't be surprised if Corel got it wrong. it wouldn't be the first time.
  14. If they are twisting, it is because the shroud or lanyard is trying to find a rest position that it was forced out of when it was laid up.. You have to make sure both are hanging untwisted naturally before seizing them..
  15. Have you tried wiping with acetone? You might need to put some cloth on a thin blade of some sort, saturate it with acetone and wipe between the planks.
  16. AS for Chuck's weathering powder technique, I don't know if he goes into more detail somewhere else, but it seems pretty simple and straightforward here: Weathering the cannon on Cheerful
  17. You would be hard pressed to find an example of where this is done well by anyone at this scale.. Even at 1:48, most efforts leave a lot to be desired. More often than not, any strops and hooks look way out of scale.. You will find many fine models where the tackle is not rigged at all, or maybe just the breaching rope is present. You might consider a method called " frapping " Shown here on tkayy11's  Triton cross section. However, I think this is a 1:48 build.. Getting the hooks to look good at 1:64 is more of a challenge.
  18. I think the bronze with patina look is nice. End the end, it's how you want it to look.
  19. You might check out Glenn Barlow's method in his Cheerful log.
  20. 20 Gauge stranded: Here It could be any similar wire found around the house.
  21. You might try twisting together 2 or three strands of the really fine wire found in 20 gauge or thinner electric wire. It will be copper or aluminum, so you will still be looking at blackening it..
  22. I guess this part is a little late if you have already put them together.. When I have put these together, I just put a little white glue in random slots of one layer. Doesn't take much to keep these assemblies together. As far as where to put yours while they dry, just set them on some plastic wrap or a plastic bag.
  23. With regard to these planking drawings, What is the significance of the red vs the black drawings? Sphinx 1775
