Posts posted by PRS
12 hours ago, glbarlow said:
I’ll just follow along from back here. 😊
1 hour ago, FrankWouts said:Hi Paul.
Good to see another Winnie build log started! Welcome and I already love your beautiful precise and clean work!
I'll certainly pull up a chair and follow your log!Frank.
Grab a chair and there is coffee over there and beer in the fridge.
- FrankWouts and Matt D
1
1
With all of us following you are going to need more chairs
- glbarlow, FrankWouts and AlleyCat
2
1
Lining up the gun port lays.
I took a lot of time with this and left it overnight to look at it again the next day and did see where I could make some adjustments.
I am going to frame the upper and lower port openings before fairing as to give some support at the top.
The piece of wood I am using is the exact opening dimension on the large end which makes lining up the top piece easy.
I must say having a table saw and a crosscut sled sure makes duplicating these pieces easy.
- FrankWouts, BobG, WalrusGuy and 4 others
7
23 hours ago, Chuck said:
Cant beat that. Well done
Thanks. I can now do this in a proper wood.
14 hours ago, JeffT said:Don't throw that one away...lol
It was just a test piece out of 1/4 poplar and the wood colour is not that great.
- WalrusGuy, Jack H, Edwardkenway and 9 others
12
- Chuck, WalrusGuy, FrankWouts and 8 others
11
You will absolutely regret using birch ply when you get to the point of fairing the hull. Its tough stuff. Lite-ply usually made of poplar is the way to go with the bulkheads if it isnt to late for you to switch. Thats why you are killing so many blades. Just think about trying to sand that stuff.
Glad you started work on her.
Thanks Chuck. I wasn't able to find lite play locally so went with this. I am used to sanding aircraft ply which is real tough stuff so I will see how it goes.
I initially looked at MDF but the panels were warped really bad and I know that stuff is hard on blades because of the glue if the blade gets hot.
22 hours ago, Matt D said:Your bulkheads look great, Paul. You did a really good job on the false keel. I had a very hard time with the joints on mine.
Thanks Matt. Just time consuming and slow work.
18 hours ago, glbarlow said:Try rubber cement for attaching plans to wood, easy to remove and keep the wood clean.
Good to know. Wasn't sure if the rubber cement would get into the wood and make it hard to come off.
- FrankWouts, glbarlow and BobG
3
Posting the start of my build log for the Winchelsea.
This is going to take quite a while to build as it is huge and complicated with many parts to make.
I am going to attempt to scratch build as much as I can as a challenge to myself.
I started cutting out the bulkheads and false keel with my scroll saw and it can be done but you have to use sharp blades and work slowly. You WILL break blades and I found that when they get dull you are not far off from breaking.
These are the blades I used. They give a very smooth cut.
I am using 1/4 inch birch plywood sourced locally and printed out the parts to cut and then used a glue stick to the wood. Then carefully and slow cut with the thin blades right on the line as best as possible.
I found sitting with my saw on a desk works best as it ends up being chest high and you can follow the lines easier than standing which is hard on the old back.
I did cut the false keel in three pieces as this will keep any warping between pieces to a minimum.
Once the pieces are cut I have a sharp scraper and just peeled and scraped the glued on paper off. This scrapper has been sharpened with 800 grit sandpaper so it is very sharp.
While I was at the lumber store I also picked up a 3/4 inch MDF used for stair treading as my work base. It is nice and straight.
I also made up some squaring pieces for assembly and did have to modify the bases a bit later as they are too large and interfere with the bulkheads.
Here is have the false keel pieces glued up and held straight. It was a lot of cutting and if you do it slow not much sanding.
Once that was all set I mounted my squares on the build board. There is a very slight warp at the top of one of the pieces which release when it was cut but I am aware of it and will make sure there is no warp built in.
Next up is the process of cutting each bulkhead and laying them in place. You know there are a lot of them right?
I still haven't decided on Yellow Cedar or Cherry for the most of the build yet.
Hope you can follow along and offer suggestions or even an attaboy which helps with motivation as my new 3d printer keeps pulling me away from my projects
Your figures are great!
How do you make them?
Wow you guys are awesome and I really love the comments!
I do spend a lot of my free time building as it is my hobby hence the fairly quick build. (I need to slow down)
My next project is the Winchelsea. I have the plans and do have a plan in mind. I will be cutting most of my parts myself as I really enjoy working with wood.
That will be a slow project and it is HUGE!
- Ryland Craze, JpR62 and BobG
3
- GrandpaPhil, hollowneck, Ainars Apalais and 6 others
5
1
3
- Bill Brown, hollowneck, Ryland Craze and 12 others
12
3
- lmagna, mtaylor, thibaultron and 1 other
4
1 hour ago, Kevin-the-lubber said:
I haven’t tried any colours at all, always gone grey as everyone says it’s the easiest for seeing the detail before painting. I was thinking of getting some brown for making blocks etc, but maybe black is worth a go. It certainly has a nice look to it.
I’ve just begun a new run of printing and, oddly enough, the elegoo ABS-like is coming out a bit softer than previous batches. So I wonder if mixing resins was, after all, quite a good thing to do. I only did it because they were test prints and the end result didn’t matter, but I think I’ll try a standard and abs mix again shortly, and be more scientific this time.
Out of interest, presumably you printed the cannons vertically, with supports on the muzzle? Any issues with that? I had planned on printing vertically with the muzzle flat on the plate, to avoid support dimples, but am conscious that there’s nowhere for the resin to drain from the barrel.
Here is how I did the canon prints.
- thibaultron, Egilman and lmagna
2
1
On 10/16/2021 at 6:26 PM, Kevin-the-lubber said:
I only used one bottle of water-washable and have a feeling I mixed half of it with standard resin to use it up. I think I just found that the surface finish seemed fractionally less sharp. I also wasn’t too keen on washing prints in the kitchen sink, I really don’t want a blocked drain down the line.
I find FEP gets dimples from supports and this makes fails a little more likely. I had a terrible problem with supports breaking halfway through a print until I was told that extending the exposure time was the cause; reverting to recommended settings, and beefing up the supports, sorted that out. But I agree, more and stronger supports is safer. Same wrt paper towels, though to be honest, I haven’t found hazy FEP making any difference.
You are correct on this.
Here is the difference between the same print of some canons. The black is water washable and the grey is regular resin. Also the water washable just seems softer than the standard resin and the detail is less.
Something the black I have is good for is small detail parts. Here are some hooks I drew up and printed. I tested the strength and they are mighty strong. I left them on the supports to cure and they come off easy and I don't loose them
On 10/24/2021 at 5:30 PM, Chuck said:
That looks great. Its amazing how much larger the rigged model is compared to when you were working on the hull. That took some getting used to.
Thanks Chuck. Yes it is huge now and I have to be very mindful when I am working on it to not snag myself in all the rigging.
22 hours ago, glbarlow said:Looks great, congrats on almost being done!
Thanks Glen. I am going to be happy/sad to be finished and have not completely decided on my next project.
It is a decision between the Triton cross section or the Winchelsea. Today I am leaning towards the Winnie but will be cutting my own bulkheads if I do it.
- GrandpaPhil, hollowneck, Gregory and 9 others
9
3
I am pretty happy with the detail you can get with the resin printer.
This is with the Elegoo black water washable resin. The finish is dull and I have purchased some Anycubic standard grey resin to try.
I am still in an early learning stage and find that Lychee Slicer is a lot more user friendly so I will stick with that.
Here is a few things I have learned:
Do not use paper towels on the FEP as they will scratch it.
Run a vat clean and removing the piece of cured resin is the best way to clean up after a print failure and might not be a bad idea between prints.
To do a plate level on the Mars 2 use two pieces of paper and home it with the bolts loose. Then slowly snug them down back and forth then remove one sheet to check and you are done. The spring is quite strong in the build plate.
Make sure you get the build plate back on all the way when you remove it.
More supports are better than less to avoid failures.
- CiscoH, Gregory, Ainars Apalais and 9 others
12
HMS Winchelsea 1764 by PRS - 1:48
in Member Build logs for the HMS Winchelsea
OK starting the fairing process. This is going to take a while...
