Posts posted by PRS
- CiscoH and GrandpaPhil
- 2
- muratx and GrandpaPhil
- 2
That book is an awesome idea.
Everything looks great!
You could just glue them together and sand down the glue seam.
Thanks for the tips Chuck.
Looks like I have some sanding to do. Not sure if I can remove the gratings on the forward ones but can sand the one at the stern no problem.
- BobG, Matt D, GrandpaPhil and 5 others
- 8
I need to get some brass wire to make up the eyebolts and rings.
What gauge should I be using?
- muratx, rafine, Boatsinc2000 and 6 others
- 9
- Ryland Craze, GrandpaPhil and muratx
- 3
Nice fix and looking good!
19 hours ago, BobG said:
Looks great! What method did you use for the treenailing?
Thanks Bob. I used Chucks method that he shows in his build logs.
14 hours ago, bartley said:Looks great, Paul. The treenailing, the dullish red and other features make it look "authentic". some I have seen from very accomplished modelers look a bit "plastic" to my eye.
John
Thanks John. Much appreciated.
- BobG and Ryland Craze
- 2
- GrandpaPhil, Gregory, Ryland Craze and 9 others
- 12
- JpR62, BobG, Captain Poison and 10 others
- 13
- JpR62, Freebird, GrandpaPhil and 4 others
- 7
- rafine, BobG, FrankWouts and 10 others
- 13
Wow that looks great with the black wood.
- JpR62, FriedClams and Saburo
- 3
Looks nice. Great job and you now have been bitten like myself.
- mtaylor, thibaultron, reklein and 1 other
- 4
For the hinges on the companionway I used some of the gun port hinges as there is a lot in the kit.
Also highlighted the door areas with some black wash so they stand out.
Painted the hinges before gluing them on with some 50/50 pva/water mix.
So now that all the deck furniture is done I have them set in place but not glued yet and will start to mark out and plank the deck.
- glbarlow, Nunnehi (Don), BobG and 5 others
- 8
Yes the muted reddish color is perfect!
- mtaylor, mbp521, FriedClams and 2 others
- 5
Made the companionway from 1/32 boxwood. First used the plans and cut out the 4 sides and glued them together.
The used 1/32 cedar to plank around the frame and did the roof last at there was 1/16 around the sides which was enough to have a good glue area.
Tried to make some spaces between the planks where the doors are.
All sanded with 600 grit and ready for painting.
Painted it up with the acrylic paint. 3 coats and used a hair dryer to speed up the drying between coats.
Couldn't resist test fitting it on the deck. Nothing is glued down and I may do like some of the Winnie builders and not glue the deck furniture down so I can sand the deck planking easier.
Still have to make up the hinged for the companionway yet.
HM Cutter Cheerful 1806 by PRS - FINISHED - Syren Ship Model Company - 1/48
in - Build logs for subjects built 1801 - 1850
Spent some time making the boarding stairs and got them mounted on the hull.
I made up a scraper from a single edge razer blade to get the profile.
