Posts posted by BETAQDAVE
On 2/9/2018 at 4:36 PM, Senior ole salt said:
Maybe the acrylic stuff in tubes is better. I still have some used for painting that deals with TIME better than Model Expo Paint
You are probably right. The bottles allow way to much air in them, whereas the tubes allow very little. Some people say to try taking up that volume of air by filling them with stainless steel ball bearings, but when I received my Expo paint they were unopened for a couple of months afterwards but the sealed bottles were already like hockey pucks.
My 2 cents worth would be that scribed plywood decking just looks like plywood with lines drawn on it. Individual boards found on a real ship have much better definition than that! Having done woodworking for many years, I tend to notice right away that the wide grain pattern of the plywood crosses over all of the seams and that's a dead giveaway that it's just a sheet of plywood and not individual planks.
If putting in individual decking boards looks like too much work there is still another option. I once modified the 1/96 Cutty Sark by Revell many years ago in which I replaced the plastic decking with some 3" x 22" sheets of .05" thick basswood decking boards that were 1/16" (aprox. 1.6 mm) wide glued up with black glue to represent the caulking. It was a little bit of extra work but I thought well worth the effort to eliminate the seams in the plastic deck and add that extra definition to them. Micro Mark still offers this product for about $17. (It's also available in 3/32", 1/8", and 3/16" wide planks.)For your reference I have also attached some photos of the deck of the Cutty Sark as it actually appears today. But, as it's your ship it really is your personal preference, so just have fun with it!
As you can see, the decking is narrow and very light, so the 3 mm Mahogany would be both too wide (judging by the aprox. length of the feet of the tourists they must be about 6" wide, so @ 1:96 the planks should be about 1/16") and a poor color choice for decking but a good choice for the deck structures.
- russ, mtaylor, paulsutcliffe and 2 others
- 5
While working on my modified MS 1:96 scale version of the “Phantom” I found that I needed to make three very small turnbuckles. (They were referred to as stretching screws on the plan.) I had bought some brass telescoping thin wall tubing previously for making yard bands and thought up a way to use them to make a fairly realistic fitting. I took some 1.3 mm brass tubing that was just big enough to allow an eye bolt that came with the kit to slip into it. Then I used the 1.8 mm brass tubing (the next size up) that the 1.3 mm tube could be slipped inside of that for the main body of the turnbuckle.
I marked the length of the 1.8 mm tube and the length of the opening with a felt pen.
Taking the 1.8 mm tube to my vise, I cut out the open areas on both sides with a fine narrow file.
I cut the 1.8 mm tube to length for the main body and cut a pair of short lengths of the 1.3 mm tube for the inside ends of the turnbuckle. Taking the five pieces to my soldering block, I applied flux to the shortened eye bolt stems and the outside of the 1.3 mm tube.
The pieces were then assembled together and stretched out on the block with a couple of toothpicks stuck through the eye bolt holes to hold it steady.
I cut some small flakes of solder and placed them at the ends of the turnbuckle body and applied my soldering iron to the 1.8 mm tube. After it cooled off I just cleaned up the ends with a fine file and blackened it. While the fitting still seemed a little large to me, I was quite satisfied with it. By varying the size of the components the size of the turnbuckles can readily be adjusted for various other scales.
- RichardG, CaptainSteve, Belco and 15 others
- 18
Man alive Ed, you sure are doing an enormous amount of ironwork on this ship. Do you blacken the ironwork in place or before it's installed? If this is done in place, how do you prevent the woodwork from being stained? I have a hard time making the some of the complex ironwork fit in place only to have to remove it to blacken it and then reapply it. Your ironwork looks to be done quite neatly! The overall workmanship on this model is something way beyond what I can ever expect to achieve! (Maybe you should write a book about it someday.)
- Piet, Wintergreen and EdT
- 3
- Piet, DORIS, FrankWouts and 4 others
- 7
On 3/12/2018 at 4:51 AM, DORIS said:
BTW: The model is very heavy, even if it is made of card.
That's not too surprising when you stop and think about it. Basically they're taking out all of the voids in the wood cells, adding a binder and putting it under tremendous pressure when it's rolled out, making it much denser. While one sheet of paper seems to weigh nothing by itself, just try lifting a ream of 500 sheets!
Your ship is very well detailed for being a card model. The wood graining varies enough to make it look like individual wood planks. That's one reason that I like to build solid or built up hulls with individual planks applied to them.
Hopefully your two feathered assistants don't get too interested in your ship and try to add their own touches to it. Our Parrotlet would like nothing more than to gnaw that paper up a bit. Hope you're feeling better soon.
- Piet, FrankWouts, DORIS and 1 other
- 4
Tim
The Master Korabel kits do look very impressive. I watched some of the video tutorials of the construction of the brig, and although it's in Russian, I still found them to be very informative. The laser precut parts seem to be exceptionally precise. Although I prefer individual deck planks, the scribed decks included in the kit are also very precisely done!
I guess that the videos would be a necessity, as I wouldn't be able to read the Russian directions. I must say though, that the modeler does not spare the adhesive.
When the dimensions of a ship are given, they are stated as moulded dimensions. For example, the New York Pilot Boat "Phantom" is listed on Model Shipways plans as shown here:
Length overall (moulded) 76'-4" (Assuming that this is measured from the face of the stem to the stern end of the deck.)
Beam moulded 19'-8" (Assuming this is the maximum width)
Draught 10'-8" max. (Assuming this is measured from the waterline to the bottom of the keel.)
Here are some photos of the ship plans to help illustrate my confusion with several discrepancies that I have come across.
I have put notes on the plans where I have come across some errors, but the first and most glaring error (shown above) is that the overall length on all of all the deck and side elevation views measures about 1’-8” short of the previously stated dimension. One might say that the error is in the reproduction of the print, but if you measure the beam dimension off of the same drawing of the deck plan, it is very close to the stated dimension. Stretching out the length of that drawing would now make the beam dimension incorrect!
There is also a scale drawn below the waterline plan. When I put my 1/8” architectural scale on this printed scale, (shown below) you can plainly see that they don't come close to matching either!
If I put the same architectural scale on the waterline, profile elevation, or deck plan I have the same situation, and yet when measuring the beam section drawing below, the scale matches exactly!
Now that I have decided to build this ship @ 3/16” scale, I obviously need to have the plan enlarged some more. However, all of the plans seem to be drawn at different scales. If I enlarge one, the others also get enlarged the same amount. So the error would continue, but just at a larger size.
Having made the decision to use a somewhat modified bread and butter method of construction, the accuracy of the profile section drawing becomes quite important, and when my scale is used to measure this drawing you can see that it is right on the money. Oh but wait a just a minute here. That would mean that the ship is really wider than what the other drawings show! This leaves me a little confused as to which drawings are drawn correctly and which ones are not.
Oh, and by the way, this also brings up yet another question. If the ship length is short.............. does this missing 1’-8” need to be added to the bow, the stern, or somewhere in between?
- thibaultron and Sargon
- 2
Well, apparently no one has an answer for this question so I guess that it's up to me. As this build has been modified already, I guess my choice is to go with a ships boat and will just refer to whatever information that I can come up with.
My 1/96 scale Constitution that ended up in drydock after losing out in battle with the garage floor was a Revell plastic kit that I replaced the deck, masts, and spars with wood. It was fairly easy to do, as I had the plastic parts to use for patterns to copy. I was more satisfied with the results than I was with the originals. The masts being hollow plastic were a great improvement in solid wood. The deck I made with some panels made up from glued up individual narrow wood planks with dark glue to represent caulking. This eliminated the plastic seams that were way too obvious on the original ! It was a lot of extra work but the results were quite satisfing ! :-D
- thibaultron, Canute, John Allen and 1 other
- 4
Dust control in my model shop is limited to a small shop vac that hooks directly to my bench tools as I use them. Unfortunately, my tool dust ports are not sized consistently, so I am currently making some custom fittings for each of them. I just picked up an I-socket 110m Tool and Vacuum Switch for about $35. You insert the switch into any standard outlet, plug your vacuum into the vacuum outlet and your tool into the other one. When you turn on your tool, the vacuum also will start and stay on for 7 seconds after your tool turns off to clear the dust out of the hose. It saves you from having to remind yourself "dust bad, vacuum good".
Schooners are one of my favorite ships for modeling as they are a simple rig and not overly large, making them well suited to make in larger scales. I have built mostly in 1/8" scale and details are very hard to reproduce to my satisfaction. Having recently picked up a copy of this book, I am very happy to find so many of the finely drawn details shown in it that allow me a better shot at making them look more complete. While it is true that trying to find a particular detail is sometimes difficult, when you do find it it is usually worth the extra effort.
My wife and I have made ten trips to Hawaii prior to my life in a wheelchair and we really would like to return, but air travel would really be tough now. One of the things that I always admired was some of the woodworking projects that I saw when we were there made of Hawaiian Koa and some of the other native woods. I would love to incorporate some of them into my modeling projects but, unfortunately have not seen any offered thru any of our wood suppliers. Is there any source that you are aware of that can supply them? I like that you have been able to come up with the some of the woodworking properties of the various woods also.
- mtaylor, Seventynet and Canute
- 3
That's what I like to see, re-purposing a tool to do something that it was never originally intended to do! I have also tried it with one of my new Sonic Pop Dental units that my wife picked up from QVC as one of their special picks. I didn't like it for my teeth but after reshaping the head with a bend added to it, it makes a good vibrating sander. I don't know about you but, I can't sand by hand at 30,000 vibrations per minute! As it has a very compact stroke it can really get in some tight spaces. The only drawback is your hand seems to keep vibrating after you finish.
Welcome to MSW Angel! You do very fine work, something to be proud of. Ever thought of selling your models? I have sold almost all of the ships that I have made. I seldom made much more than the price of the kits but display space is limited and it was usually enough for me to afford the next model, so it was like getting it for free. To me the object was just to have the fun of building them, not to keep them on a shelf. (Our watch bird doesn't seem much interested in them anyway.)
Antonio C. Mendez (a scratch builder extraordinaire in Mexico) was a man after my own heart in that he was very adept at making his own tools and jigs out of whatever was at hand. He often took one tool and converted it into another; like making an old rotary shaver into a ropewalk, or an old pencil sharpener into a miniature precision planer.
That was the mindset I used to come up with my plan holder. I had an old no longer used adjustable clothes drying rack that I took apart and remounted onto the side of my assembly table with a few spring clamps used for hanging brooms and mops. As you can see, it can be very easily adjusted or removed without tools. If I have a larger plan sheet to mount, I can raise the cross bar, attach an extension to the bar, or both. Being in a wheelchair, my reach is very limited, so having it within easy reach was very important to me.
By the way, Antonio wrote a book titled William Frederick’s (1874) Scale Journey: A Scratchbuilder’s Evolutionary Development, in which he provides detailed info with many photos and drawings describing his techniques. I would highly recommend getting his book, as it’s full of ideas for model ship scratch builders.
Your craftsmanship in both the wood and metal fabrication is just fantastic!! Unfortunately the workmanship you employ is well beyond most of us, but just gazing at the results is something to behold!!
- EJ_L, Gerhardvienna, cog and 1 other
- 4
Jason......Don't worry so much about such minor imperfections. After all, the original ship wasn't built by master finish carpenters with power tools and the materials available today. It was all done by hand and the joints were not perfect, thus the caulking of the joints! Any such minor imperfections on your model only add to the illusion of realism, which is part of the reason we build our models in the first place. Your model is quite an impressive piece of art by most anyone's standards!
- mort stoll and JesseLee
- 2
Thanks for all the suggestions guys! I considered substituting metal for it but I would have a hard time tapering it. Cutting it into two pieces and inserting a metal rod on such a thin piece of wood would be tough also, as end drilling a 1/32" dowel would require much more precision to drill than I could handle. The top mast will be a varnished finish so I may just try a few coats of varnish and see how much strength is gained. The wood I have is beech which has a fairly high rating for bending strength, but I have some hard maple which has a little higher strength rating and similar appearance. Maybe I can locate some hickory which has a much higher strength rating but a very inconsistent coloring. If I'm picky in my selection I can select a piece that has a similar appearance to the beech. Does any one have a source for some hickory or any other wood that could qualify?
- Eddie, mtaylor and thibaultron
- 3
When you have a very thin upper mast, is there something that will make a wood mast stronger? I have a topmast dowel that is only 1/32" at its fattest and thus much thinner as it tapers. I'm afraid that the least little tug on the rigging would snap it off. I had thought of soaking it in some kind of varnish or similar product that may harden the wood. Anyone with any other suggestions? Dave
- Eddie and thibaultron
- 2
ModelExpo paint ?
in Painting, finishing and weathering products and techniques
Perhaps MS should be doing that to their entire stock.
