Everything posted by Rustyj
Very nicely done Sjors. It's a fine addition!
- 164 replies
- vanguard models
- flirt
Great work Glenn. I've got the same pile on my bench!
- 778 replies
- cheerful
- Syren Ship Model Company
Hi Chuck. Glad to see you back at it. I hope you're doing well. Rudder looks great by the way.
- 1,784 replies
- winchelsea
I printed them on plain white printer paper. Photo paper would be too thick.
- 1,784 replies
- winchelsea
Very nice Ben. Now you just need to add a laser cutter to your arsenal.
- 889 replies
First off very nice work! I think your final two choices look very good and if Naphthol Red is easier to use then go for it.
- 109 replies
- medway longboat
Yes we all have had that moment. I used a hair dryer to accelerate the drying time to just an hour with no ill effects.
- 382 replies
- Vanguard Models
- Duchess of Kingston
Very nice masts and spars. It is something I think we all do a little differently and you seem to have found out what works for you. That's what's important. Each time you do it it'll get easier and easier. Well done!
- 436 replies
- vanguard models
- alert
Hi Glenn, Great save. Those little buggers were hiding on you. Beware when your placing the fore deck. The two vertical pieces circled in your picture below are fragile and can be bent or snapped off if your not careful placing the fore deck. As least if you have heavy hands like me. Keep up the good workmanship!
- 382 replies
- Vanguard Models
That is some fine work on those sticks Glenn. Nice tight joints too! It's really rewarding when you can take " sticks" and make them into something nice like you did.
- 778 replies
- cheerful
Your detailed log will be very beneficial for all who follow. Thanks for this. I tend to get in a zone and forget pictures for several steps. 😉
- 382 replies
- Vanguard Models
Thank you Jean-Paul, Sjors, JJ and Bob. Much appreciated. Also for all the likes. I'll give you the same answer I used to give my dad when I was a teenager and I quote, "Ummm, ahhhh, welllllllll, maybe, I don't know." That should about cover it.
- 642 replies
- winchelsea
Thanks Mark and Sjors. Sjors I've been following your Flirt and you're doing a great job on her! Also thanks for the likes. On to planking the deck. I planked her using pear wood. No big surprises, just follow Chucks directions! Here you can see the start of laying the first center line plank and the the filling in between the hatches etc. Then came the tabs around the hatches. You can see how I started figuring the cuts and just kept making small cuts and sanding until a tight fit was obtained. More pieces than I care to count went into the waste bin! Here all the tabs have been completed. Planking the remaining deck came next. First coat of wipe on poly going on. Brings out the colors nicely. Whew that was a lot of fun!
- 642 replies
- winchelsea
