Everything posted by Rustyj
Thanks Vladimir, The hull and deck are planked in pear wood. Very similar to cherry.
- 642 replies
- winchelsea
- Syren Ship Model Company
The first layer of planking has been completed and the outer patterns shaped and installed. Very straight forward and went on without any issues. Did use most of my clamps to do both sides. Now the hull is ready for the second planking and I've sorted through the provided pear strip wood getting the ones that the color is very similar.
- 201 replies
- Duchess of Kingston
- Vanguard Models
Upper bulwarks were soaked and bent around a can, blown dry and then fitted to the hull. This is only the second time I've used a one piece bulwark pattern and it went on better than I had hoped. I had to use some extra clamps besides the nails to get a good tight fit but I'm real happy with it.
- 201 replies
- Vanguard Models
Thanks Glenn. I'm taking a lot of inspiration from you! Also thanks for all the likes.
- 201 replies
- Vanguard Models
As usual that's some very nice work B.E.
- 261 replies
- muirneag
- vanguard models
Is there any other way? That's good to know Chris. I got them back in place and it was good practice fixing one of what will be several heavy handed oops. Well I'll be right in line next to you! I've faired the hull and the MDF sanded well but caution should be used as it is easy to remove too much if you're not careful. Also the stem has been added in anticipation of placing the bulwark patterns.
- 201 replies
- Vanguard Models
Hi All, Like Bob (Rafine) I'm in between chapters with the Winnie and the Duchess of Kingston caught my eye. I thought it would be a great change of pace and Chris's Vanguards models have looked so good I had to give it a try. I started a little while ago and have been meaning to post my progress but everything I'm in the shop I get distracted and start working on the DOK. The hull pieces all went together very smoothly. I didn't have to adjust any and all slots were a nice firm fit. I too dry assembled it and then used a brush to apply the wood glue. After assembling the hull I added the fore and aft sub decks and the cross braces. Be careful adding the sub deck. The two up right circled below are fragile and can be easily damaged like I did. Luckily I could move them back in place and glue them and all is well.
- 201 replies
- Vanguard Models
Looking really nice Chuck!
- 1,784 replies
- winchelsea
Moving along very nicely Glenn!
- 382 replies
- Vanguard Models
I hope you are right and get well soon. My best to you.
- 164 replies
- vanguard models
- flirt
Well done Grant. Keep the paint handy if you're anything like me with the scuffing.
- 109 replies
- medway longboat
Very nicely done Sjors. It's a fine addition!
- 164 replies
- vanguard models
- flirt
Great work Glenn. I've got the same pile on my bench!
- 778 replies
- cheerful
Hi Chuck. Glad to see you back at it. I hope you're doing well. Rudder looks great by the way.
- 1,784 replies
- winchelsea
I printed them on plain white printer paper. Photo paper would be too thick.
- 1,784 replies
- winchelsea
Very nice Ben. Now you just need to add a laser cutter to your arsenal.
- 889 replies
First off very nice work! I think your final two choices look very good and if Naphthol Red is easier to use then go for it.
- 109 replies
- medway longboat
Yes we all have had that moment. I used a hair dryer to accelerate the drying time to just an hour with no ill effects.
- 382 replies
- Vanguard Models
