Posts posted by Rustyj
6 hours ago, Chuck said:
It will be so nice to finally cover up those bulkheads.
Very much so. I'm really looking forward to the inboard work!
5 hours ago, glbarlow said:Did you choose to go with the pear for your decking?
Thanks Glenn and yes I will be using pear to plank the decks.
- FrankWouts, Ryland Craze, Wacom and 1 other
4
Ah that looks so nice Mike!
- Stuntflyer and FrankWouts
2
Chapter 4 Cherry parts have arrived as well as the hatch grating kits!!!!! They are even better that they look.
I installed the beams that create the opening for the hatches. Next I had to "fair" the tops of the bulkheads. As I decided to cut my own bulkheads there is some minor variations in the height of the tops of the bulkheads. It's probably a combination of sanding to the line or taking the line. That seems minor but it can cause some minor stepping. To get the run as smooth as possible I sanded the whole thing.
Next I'll start dry fitting the false deck and then start throwing some wood on the inboard bulwarks!
Having a lot of fun with this.
- Matt D, Stuntflyer, Wacom and 19 others
22
Looking great Bob. You sure didn't let any moss grow!
Wonderful job on the deck. Have you given thought on how you're going to mount her yet?
- Ryland Craze, JpR62, BobG and 2 others
5
Great workmanship. She's a beauty!
Great looking workmanship! Well done!
Looking real nice B.E. That hull was fun to plank!
You're on your way now!
While waiting to start chapter 4 I've been doing some prep work.
I've planked the fore and aft sub decks with pear.
Then I sorted through the pear I'm using to plank the deck. I've tried to get pieces with the most consistent color.
Even so you will notice that the color can change over the length of a strip so I'll have to pay attention!
Spare planks are in the sleeve on the right.
The inboard bulwark planking will consist of 3/16", 7/32, and 1/4" planks. They have been cut and seen below.
After that I glued together 1/4" and a 7/32" pieces which represent the two rows under the gun ports.
I placed them on a piece of 1/32" to simulate the thickness of the false deck.
I then checked the gun ports and found that most were right on. Whew!
Looking really good Fred!
Thanks Chris. Your opinion is always appreciated.
Also thank you all for the likes.
4 hours ago, Blue Ensign said:
Nice to see you have a new canine assistant, every shipyard should have a dog (or two) 🙂
Yes it's nice to have a second shop assistant although the two almost never agree! 😉
Thank you all for your opinions. It's deeply appreciated. I have been cleaning and reorganizing the shop
in anticipation of starting chapter 4. In doing this I remembered that I had overcut the 1/4" pear needed for the hull.
So I pulled it out and there is more than enough pear already cut to plank all the decks and still have some left
over. Can't let it go to waste so I'll be planking the decks in pear! It's like I subconsciously knew I was going to
do it this way when I cut them. I'll go with that as opposed the the shop assistants who think I just screwed up.
Oh and they both agree on this point!
Here is some of the unfinished pear planks just laid on the deck.
- Ryland Craze, JpR62, VTHokiEE and 15 others
18
Oh I really get what you mean after looking at the picture of the contemporary model! Thanks Chuck.
- Ryland Craze and FrankWouts
2
Is that pear on the right? Looks dark for boxwood. The cedar would compliment the carvings and friezes better and tie in with them. The holly may be too light. But using Pear would keep it all consistent. I personally like the decks the same color as the hull planking but thats just me.
You need to thing about how the deck fittings would look against the deck planks if you use pear and and paint most of the fittings down the deck. Its a tough decision. One I anguish over all the time.
Yes it's boxwood. It was cut from an old scrap piece. I looks darker in the picture than it really is. I agree the Holly is too light so that's out.
I was thinking that with the bulwarks painted red, hatch combings black as well as the stove using a different color from the hull wouldn't look as drastic. Will the bits, pumps, railings, binnacle be painted too?
Here is a pic with the samples on the deck. Pear is on the far right now. Excuse the covering as she was all wrapped up for protection until I start on her again.
Glenn, I too favor AYC but it may be too light too.
I probably won't make a decision until the false deck is in and the bulwarks planked and painted, then I can get even more confused!
Thanks for checking in!
- ccoyle, MEDDO, Ryland Craze and 5 others
8
- FrankWouts and Ron Burns
2
Hi Glenn,
4 hours ago, glbarlow said:I wish I had a stash of boxwood and holly. Do you have a source or still working off a supply from Jeff😄
Still working off a stash from Jeff. I dread the day I have to start looking for new wood.
In the past I've done decks in all three woods and liked them all. Just have to decide what to do with this one.
- Ryland Craze, glbarlow and FrankWouts
3
I'm puttering around in the workshop while waiting to start chapter 4. The biggest decision will be deciding
what to plank the decks with. I'm contemplating AYC, Holly and Boxwood. I'm going to cut up some
scale planks and see how each looks. Once I decide I can start milling what I need.
- Ryland Craze, JpR62 and FrankWouts
3
Beautiful planking job! She's something to be proud of!
Glenn that is one hull to be proud of. A perfect example of taking your time, fixing what you're not happy with and persevering. Great explanation too! Well done.
- mtaylor, MEDDO, Ryland Craze and 3 others
6
HM Cutter Cheerful 1806 by glbarlow - FINISHED - 1:48
in - Build logs for subjects built 1801 - 1850
She's looking really nice Glen. I have faith you'll conquer the moldings before you run out of wood!
