yvesvidal
Everything posted by yvesvidal
  1. If you intend to use that figurehead on the bow of the CAF Model HMS Bellona, you will need 12 mm between the legs, to make it sit comfortably, unless you are planning to shave and sand a lot of the cherry bow. But you probably know all that already, since you have the CAF kit Session #1. Yves
  2. I have always wanted to build this ship at 1/100 scale. I started when I was a kid at 15 years old, and did not go further than the bridge and main turret. The guns were made of brass tubes soldered together and raised when spun (like the old Lindberg model). I will be following your build. The Trumpeter kit is a good base to magnify the parts. You should also consider 3D printing some of the repetitive parts. Yves
  3. Fantastic job. I also love the dark/black board to present the model. Yves
  4. I like the old SAE electronics from the 70-80's. I own a SAE 8000 Tuner and like it very much. Great model, by the way. Yves
  5. The inner planking is quite unusual. Fantastic job. YVes
  6. Fantastic job. I would try to drill a little bit, these canons for realism.....It is difficult to say, from the picture. Yves
  7. For the separate ovens.... I can fully understand: you don't want your bread or pastries to smell like venison or roasted chickens. For the checkered floor, it (unfortunately) reminds me of the flooring used in all Grand Lodges of the Masonic fraternities, where some significant atrocities are committed. I will not say more about that... Yves
  8. I never really understood, why the Brits were so fond of these diamond shaped floors.... I did not know they would even place them in their barges (granted, this one is an "Admiral" barge). Any explanations would be most welcome. Yves
  9. That is exactly how Revell should have approached these beautiful kits: using spars made of real wood. Yves
  10. Great job. Now, you need to source small sheets of thin mahogany to finish the hull, in a similar way to Sea Goddess. Yves
  11. Tom from CAF Models, will send you replacement parts, if anything bad happens. Yves
  12. I would second your comments completely, as I have the same remarks with the Bellona kit. Fortunately, the hull is planked with limewood which is more suitable for this kind of purpose. I like the cherry tree for details, especially soaked with a liquid orange oil/olive oil/bees wax concoction that I find at Home Depot. Yves
  13. Incredibly beautiful and realistic. It was hard for me to pick up a picture, but I think this one summarizes the excellence of your work. Yves
  14. Guns factory: Putting together the remaining 18 pounders and starting some 9 pounders to go on the quarterdeck: Yves
