Posts posted by SJSoane
I forget to ask in the last post; should an imaginary line connecting the two wales across the stem make a smooth curve? Or do they come to a slight acute angle in relationship to each other? Since the sheer drawing has the wale as a smooth curve up right to when it hits the rabbet, I have been assuming that this would translate into a slight angle to the stem when seen from face on.
- AON, mtaylor, John Allen and 1 other
4
Gaetan,
Very interesting. Is that the while balance meter on the far left of your mount, with the colored buttons? And are those two light meters on the right?
Thank you, aviaamator, the opinions of all of you really help keep me focused.
Following the good advice of Gary on his Alfred build, I am installing a temporary batten at the top of the wale, against which I can fit the upper strakes for a smooth curve.
Not quite sure yet if the pre-cut and then bent strake is going to fit tightly here. It needs some "encouragement" to lie flat against the compound curving surface, and I can't see yet if this will cause unreasonable stress. I am learning much at this critical place in the build; critical because it is so obvious if the wale lies correctly or not, and at the head where the viewer's attention will naturally be drawn when the ship is completed.
- garyshipwright, gjdale, druxey and 8 others
11
I pulled the pre-cut pieces off the formers this morning, and they bent very nicely to the hull. After pondering the not insignificant program of shaping a curved blank, I think I will have more success with the original plan of bending pre-cut pieces. This allows me to shape tight fitting joinery while pieces are still flat, then bend.
There was a little more spring-back on the these pieces that I had previously boiled, compared to the blank I bent the other day that had not been steamed or boiled before. So the boiling did seem to affect the wood before the steaming. Only steaming from now on..
- Siggi52, albert, Chuck Seiler and 18 others
21
Thanks, Michael. I always appreciate your keen eye and ideas for tooling.
Now I have successfully bent a piece, I need to think how I am going to shape it. I am thinking about attaching it to a backing piece that would allow me to clamp it in a vise, as shown in the drawing. Unless someone has a simpler idea.
Just for fun, I steamed the original pre-cut pieces that I previously boiled and could not get to the right curvature. They appear to have bent to the former after steaming, as seen in the last photo, and we will see how much spring-back I get tomorrow morning.
This is an impromptu experiment in the advantages and disadvantages of cutting and then bending, or vise versa...
Thanks, druxey and Mark, I found a little guidance in the book, The Complete Manual of Wood Bending, by Lon Schleining. It recommended forming a curve around a male form only, so the clamps can progressively and smoothly pull the wood up to the curve. My earlier former tried to capture between two halves, and it did not work nearly as well.
Mark, the holes in the PVC pipe are for a row of ¼" diameter dowels 1" O.C., which hold the steaming wood out of the condensed water in the bottom of the tube. The entire tube slants to a drain hole at the end opposite the opening, for getting rid of this water. This all came with the instructions I got with the steamer unit, which I found at Woodcraft a few years ago. There are also a number of instructions online, which would be more reliable than mine.
I used a rag stuffed in the opening, fearful of creating a bomb with a tight fitting on both ends. The thermometer only got up to 115 degrees, while I was expecting more; but it seems to have worked. I used the formula of 1 hour per inch of wood, multiplied by 2 for kiln dried wood. Since my wale planks are ⅛", this was ⅛ hour times 2 or 15 minutes. It took about 15 minutes from cold to 115 degrees (I put the wood in the cold tube, before heating up), and then another 15 minutes or 30 minutes altogether from beginning to end. I let it dry overnight in the forms, and hit it with a hair dryer the next day just in case.
Slow, but I only have to form curved planks from the wales up to the point where the hull flairs out for the catsheads. I am retired, plenty of time! ;-)
I might make a few more formers based on the first, using a piloted trimming bit in the router table. then I could steam and clamp a number in the same session.
Best wishes,
Santa did not bring a soldering iron or heat gun for me this year, so I turned again to the steam box parts that I had purchased a few years ago. I built a new box out of PVC pipe, scaled down to the sizes of wood I need to bend. I tried one former that was not sharp enough bend to allow for the springback, and then modified the bend more sharply to compensate (see sketch below). The final bend came out just right. I am in business!
Michael,
The more I see your clamping device in action, the more I really appreciate it. The time taken to design and construct a good jig or tool repays itself for the rest of one's life!
- druxey, thibaultron, Omega1234 and 3 others
6
Hi druxey, I got it over 20 years ago from Woodcraft, and it was labeled only as S.A. Boxwood, which I assume is South American Boxwood. Nice to work, very crisp, but is very stiff stuff.
Gaetan, I have not had success finding the heating element like Gary showed (it might have been lost or misplaced in my move). Do you have a source for the one you showed here?
Hi Michael and Gary,
I had that plank bender a few years ago, and didn't have much success first time around. I 'll see if I can dig it out and try that. Michael, you showed a heat gun/soldering setup on on of your posts a while ago. Is that what you use for this?
Thanks!
Best wishes,
Michael,
Very nice work on the lines. I can see the dilemma; leaving the cruder repairs just doesn't seem shipright!
- mtaylor, thibaultron and Omega1234
3
Hmm, my nemesis, bending 9/64" thick wood...
I cut the former with a greater curve to accommodate spring-back, boiled the pieces for 1 ½ hours, and then clamped them overnight. But as the first photo shows, the spring-back was much more significant than I had planned.
So there are three variables here: 1) the curvature of the former; 2) the time boiling; and 3) the time clamped in the former.
Before I start experimenting with different curvatures of the former, does my boiling time and bending time seem about right?
The good news is that the two strakes I bent at the same time came out with the same curvature, even though one was much longer than the other, and the joints fit well.
Best wishes,
- KORTES, Mike Y, aviaamator and 2 others
5
Thanks, Gary, I will try this. I already cut out the parts based on an expanded planking plan, so we will see how well the jig saw puzzle goes together when it goes on the hull. Some are probably going to be recut. Did you find it helpful to have the batten at the top of the wale?
Gaetan, your comment is a good reminder that so much of craftsmanship involves responding to the nature of the materials, and adapting and refining as the form begins to develop. I understand this is how the shipwrights worked, and why they needed relatively few drawings compared to the number of drawings required in our more automated construction processes today. Maybe we enjoy ship model construction in part because it lets us participate in a process when the craftsman's skills and judgement were more important.
And druxey, you are right about no dumb questions, but in hindsight it was a question I asked dumbly; the answer does depend entirely on the type of glue, which I neglected to mention. Since I am using yellow carpenter's glue, the answer to my own question is that it will come apart. I am going into the shop to try bending these individually against a former.
Thanks everyone!
- AON, Gaetan Bordeleau, michael mott and 2 others
5
John, Greg, thanks for the comments. It is great to be going again.
I planned to bend wood today, but it took most of the day to refine the joints and plank widths and thicknesses at the bow.
Dumb question; if I glued together the two planks shown, would they separate after boiling them for bending? I can see some value in bending these together, to keep the joint tight. I may also try making a caul shaped to the bow, and use this to ensure uniform bending if I have to do these separately.
Thanks, Mark, I am going to get up early tomorrow, bend some wood, and then see where I stand. The first planks at the bend are so long that once I get past those, the rest fit fairly snuggly against the hull. So I will only have to remake about 4 per side if they are too short.
Druxey, if you are reading, can you remind me how much the first planks are thinned at the fore end to fit the rabbet at the stem? The wales are 8 ½" at their fullest thickness. Every little thinning will help me here!
Best wishes,
Hi Gaetan,
I did my best to construct a true projection of the wales in CAD, and I taped a print of this drawing on the hull itself to confirm its shape and length. So far so good.
But I do have concerns about what happens to these pre-cut joints when I bend the strakes at the bow. I may have to throw away the ones I pre-cut and replace them with pieces hand-fitted to the space after being bent.
And as Greg pointed out, I also need to bevel the edges to fit the curve of the hull vertically.
I have to attend a social event today, but I hope to try a first bend of the foremost strakes tomorrow, and see what happens.
Best wishes,
Greg, I am putting an ⅛" brass spacer on top of the vise, and visually aligning the red line of the CAD printout on the blank to the spacer. I am keeping the cutter at a constant height as I change pieces. This means there is a slight variation from piece to piece as I inevitably align slightly higher or lower, or ever so slightly tipped one way or the other.
I am finding that I occasionally need to adjust these cuts slightly with a chisel and sanding blocks, to pull the faces on either side of the hook fully together.
There might be another way to make this more accurate right out of the mill, but I am not sure if the extra time it would take to indicate surfaces and creep down to the line with the Z-axis handwheel would be worth it. If I were cutting these inner faces entirely by hand, I would be doing the minute adjustments with chisel or sandpaper anyway. But I am open to ideas on this!
I am concerned about what will happen when I begin bending these pre-made pieces at the bow. I hope my CAD true projection of the wale is accurate. I did print it out and wrap it on the hull to confirm the length; but I don't know if the joints will still be tight after bending. I may have to consider laminating the first pieces at the bow. The pieces are 9/64" thick, and I have experienced considerable spring-back when bending this wood in the past.
Michael, interesting comment about the rhythm of processing pieces through a tool. I learned from a comment from Gaetan a few years ago about the importance of repetition building accuracy and speed. I have extended this idea a bit by first cutting all the hooks on the scroll saw, then sanding all the flats on the disk sander, then moving to the mill for the inner faces. And now I see I have to move to the chisel and sandpaper to clean up the fits, which is more piece by piece.
Ed,
That is counter-intuitive about low humidity in the winter and absorbing more moisture. I just heard the other day that in our location near a lake, doors tend to bind in their frames more in the winter than in the summer; this was also explained to me as counter-intuitive. And yet, my own admiralty framed model opens up joints in the winter due to wood shrinking. Many mysteries in the world still to be fathomed...
74-gun ship by Gaetan Bordeleau - 1:24
Thanks, Gaetan, very interesting and informative!
