Jim Lad
Moderators
Everything posted by Jim Lad
  1. Looks like we now know the best place to go for our new sails! John
  2. What? Not made of brass? Very nice, Michael! John
  3. Ira, If you look at photographs of the original Admiralty models, you'll see that they usually had the rabbet cut in. John
  4. Crikey, mate, she's actually nearly there! What a journey you've been on, Kats. Obviously you're going to have to start looking in rubbish skips for another wreck! John
  5. Either way for the boat for me, Ollie. If truth be known, in practice the boat was probably upended over the skylight or some other totally inappropriate place. John
  6. Tom, Actually, I hope the starboard light is green! What sort of jack would she have flown? The company's house flag? John
  7. You kayak down a beach? The gun tackles look like they're spread a bit far apart, mate. Attached to the bulwark a little closer to the sides of the guns would look better, if it can be done. John
  8. Hmmmm. So when are you going to start on the small bits, Grant? John
  9. I think it's up to you, Bob - whatever you think will look best on the model. She would surely have been flying flags at some time - certainly for her launch and probably on national holidays, so if you fly flags you'll still be historically accurate. John
  10. Your hull is cleaner, Bob! When you add the flag staffs etc. she'll be a dead ringer for the original. John
  11. Very sad news indeed, Michael. Hopefully Conway will resume publication in the future. John
  12. She' going to look brilliant on the water, mate! John
  13. Hmmmm. Very interesting idea, Michael. I'll have to give it a try. John
  14. Just catching up with your beautiful build, Alexandru - still absolutely first class! John
  15. Excellent blacksmithing there. Just a bit of advice - don't fit them permanently until you need to - they'll catch on everything within ten metres! John
  16. She's coming along nicely, Ollie. Just a totally trivial point - did you know that for some totally unknown reason most boats stowed on stern davits are stowed with their bow to starboard? It's not a rule and it's not invariable practice, but it just seems that most boats are stowed that way! Re your deadeye spacer;- that's the type used by Harold Underhill, but I've found that a 'single hole' type spacer is a pest as the deadeyes keep trying to turn around the spacer while you're working on them. Try a 'two hole' type for comparison. Get a small scrap of wood and, using a deadeye as a jig, drill two small holes spaced so that they line up with the two parallel holes on the deadeye at each end, spaced so that the deadeyes will be the correct distance apart. glue short pieces of wire into the holes and the spacer can then work by holding two holes on each deadeye, preventing them from turning when you put tension on the shroud. John
