dvm27
Posts posted by dvm27
  1. These are magnificent examples of mixed media use in ship model building, Doris. Do they not have dust in your country? I wonder how you keep these masterpieces in pristine condition without being encased.
    Whatever will you do next? I hope you will share it here. We talked once of your publishing a book based on your techniques. Did that ever come to fruition?
  2. As Druxey said buy an architects scale on eBay. Using full sized measurements, even if not ones you are familiar with, will eliminate a layer of potential error. After awhile you'll pick up this arcane system of measurement pretty quickly. Plus, when working with full sized numbers an alarm bell will go off in your head when your piece is way too small or large based on an errant calculation you made.
  3. 1 hour ago, Roger Pellett said:
    That the guys that built these were able to create anything resembling a ship is amazing.  They worked in primitive conditions with hand tools, and inadequate lighting.  If their results look crude by today’s standards that understandable.
    I have the pleasure of owning a copy of  Prisoner of War Ship Models by Manfred Stein, While some of them are a bit crude in their appearance others are exquisite works of art. Like Navy Dockyard models many of them were built by committee and by some of the finest craftsmen of their day.
  4. You are indeed correct that the apron is extremely difficult to make, Don! Took me several tries to get it right. As the width of the lower apron tapers from 18" to 10" over it's length your strategy might be difficult to employ but perhaps is doable. You would first need to make the lower apron to the correct dimension (12" tapering to 10" aft - chapter 1.19 in TFFM). Then you would need to add the 3" stepped line to either side and taper it to fay into the apron at the bottom. No matter how you do it check and double check that the steps line up on either side of the lower apron both horizontally and vertically. I found it much easier to do this with my Sherline mill but others have successfully done this with just a sharp chisel. Care, deliberation and patience is required here! Oh, and the stern deadwood stepping lines is no cakewalk either but should be easier after after completing the apron.
    Have you started a build log?
  5. Great video, Kevin. Wish I could attribute my building issues to termites but there's snow outside!
    Couple of comments:
    1. Using those pencil marks to fair the inside of the frames works as well as on the outside. Those concave surfaces are hard to fair, especially in the bow and stern.
    2. Great fix on the transom knee error. Is the wing transom upper edge at the right height at the outer counter timber or did you need to raise that as well? It seemed to be flush with the lower transom knee in the video before repair.
    3. The deck beams can be recessed in two ways. You could cut 1" mortises into the deck clamp to receive the beams or notch the ends of the beams 1" to fit over the clamps. I found the latter infinitely easier to do although you need to be carful that they are installed in the proper location after cutting the recess.
