dvm27
Everything posted by dvm27
  1. With regards to wood movement I am reminded of a anecdote by Robert Bruckshaw, whose Navy Board style models are (or were) on display in the Smithsonian Museum. After framing the hull he took a break from it for several months. Upon returning to the model he noted the hull was a full 1/4 " shorter. Fearing the worst, he covered it with a wet cloth and returned 24 hours later to find it had returned to it's specified length. He added clamps and wales and that was the end of the problem.
  2. Been an enthusiastic user of the Sherline mill and lathe for over 15 years. Check out their Craftsmanship page https://www.craftsmanshipmuseum.com/. Great stuff!
  3. Great photos, Mark! I have the same problem with my current hull. A couple of the joint lines along the continuous solid plane have separated. I have filled and sanded but they reappear religiously, always in the same place. Wood just wants to be wood!
  4. Mark, if you're going to continue doing work of this quality (which obviously you are) you must take some of that hoarded retirement income and invest in a camera with macro capabilities and post higher resolution photographs. I had no doubt you were going to solve the wale planking issue flawlessly and we all want to see your work close up to find those .001" gaps you must have somewhere. I mean, you are human aren't you?!?!
  5. Nice work, Ben. She looks like a great side project to palliate the inevitable burnout that accompanies a multi-year build.
  6. Yes, David and I (Admiralty Models) are excited to partner with Chuck on this new project. Both of our companies share the same philosophy with regards to service and quality. I, for one, can't wait to see how Chuck innovates our cross-section and makes it accessible to those lacking scroll saws, spindle sanders and the like. I have seen Chuck's concept for constructing built up frames and believe that beginners with a bit of confidence to advanced model makers will be able to make a beautiful fully framed model small enough to fit on their desk. Here is my version of the Pegasus cross-section which was constructed as a side project when building the full version. Chuck's may not look exactly like this but his will be similar (probably nicer!).
  7. We want to make this CD as accurate and fun as possible but also affordable to everyone. Some of the higher end animations may not run on everyone's computers. We'll have to see how large the files are when finished. But chew on these for now. Denis is a genius!
  8. Will follow this topic, Chuck. I really liked the frame building technique you shared with me previously. I think this will be a very satisfying mini project for a lot of people. I suspect most of them would leave 1/2 of the frames unplanked. Best, Greg
  9. Yes, Dan, it will be available to all, most likely on a thumb drive as these files are huge!
  10. Nice work, Ben. Keep on marking that centerline cause everything looks perfectly symmetrical.
  11. You have insanely high standards, Johann. Which is why your model is amongst the tops!
  12. Regarding the wood blanks for masts and spars I have had similar problems (I believe it's referred to as sprung wood). Jeff Hayes, formerly of the HobbyMill, was particularly adept at providing perfectly straight lengths of boxwood for mast and spars. I have some blanks of wood from him over a decade old that are still straight as a pool cue.
  13. I just tried out my new Porter Cable hot air gun for the first time and the results were astonishing! I bent a 1/8" boxwood strip, 1/2" wide, in several directions in less thank a minute. No water, no opening grain and no marks. It's almost as if the lignins are liquified and retain their new shape as the heat is turned off. Although not happy about ruining a perfectly good strip of boxwood I'm never going back to soaking wood and clamping in place until dry to bend. But be careful not to burn your fingers! I did use a blow dryer previously, as Chuck has demonstrated, and achieved mixed results but nothing comparable to the above. Here's a link for anyone interested. Thanks to Michael for exposing me to it (I believe) in one of his posts. https://www.amazon.com/PORTER-CABLE-PC1500HG-1500-Watt-Heat-Gun/dp/B004Q04X44/ref=sr_1_3?ie=UTF8&qid=1514407837&sr=8-3&keywords=hot+air+gun
  14. Well, Dave, you are correct in that the clearance is insufficient for the outer pump tube to pass between the well wall and the carling. Your choices would either be to cut it into the well wall or to move the carling 2" inboard (as I did). I believe I also may have narrowed the lower deck partner and carlings an inch or two but I can't recall. At any rate with the inner-most deck planks hiding the evidence I can't be sure. Just cut a blank tube to the correct dimensions and shipwright it until it fits.
  15. The fore and aft faces of my rudderhead cover are parallel, Toni. Aesthetically, it looks pleasing and I believe this is how David has illustrated it in TFFM.
  16. Yes Cliff, a picture is worth a thousand words. I, of course, am omitting the numerous intermediate photos involved in every step of the building process that Denis has included. I would highly recommend any Swan class model builders to wait until the work is finished as it is as valuable as TFFM texts are for building.
  17. Nice work, Ben. Rather than remake an entire beam I found that adding a small wafer on the short end, then blending to fit, worked very well for me.
  18. Our Swan rendering guru Denis is already up to Chapter 9 in The Fully Framed Model. Those who have built a Swan class model will appreciate how detailed and perfect (unlike our models) his work is. Note the sandwiched leather between saucers in the second photo emerging from the pump within the cistern. Enjoy and Happy Holidays from Admiralty Models!
  19. Welcome aboard Steve. You may be interested in the work of Olof Erikson. Olof has built a Cutty Sark as well as Victory and Constitution...all in steel. Of course he has the advantage of being a master machinist and owns a large industrial manufacturing company where he also built his models in his spare time (or on the clock since it's his company). Here's a link to some photos of one of his models http://uniquesystems.com/u-s-s-constitution/. Do consider that a fully rigged (steel rigging of course) steel model of Constitution weighs 1300 pounds and requires a case 15' x 8' x 10'. This could upset some spouses. His Victory Model is featured in a two part Scale Ship Modeler Magazine (1990) article and this stainless steel model is an exact duplicate of Longridge's model in London, right down to the anchor stock planking of the hull.
  20. Lovely work, Ben. You'll be happy to know that your meticulous work will be only partially visible once the lower deck is in place and invisible after the upper deck is framed in (even if unplanked. But if you're of the mindset that every joint should be perfect (you obviously are) even if the detail will be hidden later on your model will be stunning.
  21. That's the launching cradle, Mike. It was affixed to the hull just prior to launching to keep it stable while slipping into the water. It also makes for a nice display!
  22. Not exactly what you were looking for but, if the Queen were on board your vessel you might expect to see furniture such as this: http://www.shipmodell.com/index_files/0ROYAL_CAROLINE3.html I don't believe you'll see finer furnishings on any ship (or dollhouse) model than these!
  23. Like your approach, Mark. Less confusing than drawing several parallel lines on the pattern. I'm sure your projected planks lengths will be fine. I wonder about the joint surfaces mating correctly after bending. My recently spiled wale planks needed edge bevelling to sit properly at the bow. Will the upper surfaces of the plank joints spread apart while bending? I guess trial and error will tell. Wonder if Gary had any issues here?
