Everything posted by Mike Y
Just a small note - the crank one from IKEA is very flimsy and has a lot of play, you get what you pay for. The proper electrical (BEKANT) is pretty sturdy and I can fully recommend it, best tool in my workshop. Note that they sell it without a tabletop as well, and you can screw on any tabletop that you like. The office-style fiberboard top may not be strong enough if you clamp a vice on it, drill some holes, etc. Solid wood is more practical for out needs.
Very realistic! Can you make it smell too? Might worth to scratch it a tiny bit with steel wool or some brite pad (aka the scratchy side of a dishwashing foam pad) to lighten the edges a bit. Though it definitely needs some experimentation first
- 179 replies
- longship
- Helga Holm
Very fine quality work! And a nice photography as well Thanks for showing your milling setups, some of them are quite creative! One question though: when you milled ladders by using a double sided tape and a block of wood - how do you attach that block of wood to the mill table? I do not see any clamps there. Another layer of a double sided tape?
Greg, druxey, thank you both for the input! Will definitely try the "clean" look too
- 969 replies
- hahn
- oliver cromwell
Håkan, you are lucky, we have a number of suppliers who sell it (I use Arkowood from Germany). It's not cheap (they sell custom milled sheets (50x500mm) with good surface finish for around 8-10€ for 1-2mm thickness, 13€ for 3mm, 15€ for 5mm, 19€ for 8mm), but not prohibitively expensive considering the size of your models. Beware - once you've tried it - you may be hooked
- 969 replies
- hahn
- oliver cromwell
Alan, putting glue into each hole would be quite messy and complicated, every second counts here since it's quite a lot of treenails. The holes are a bit oversized to allow for glue (otherwise it is very hard to push, and such a thin treenail breaks easily). The oversizing is small though - instead of a "proper" diameter of "the third smallest hole on Byrnes drawplate" I use the second smallest hole. The end of the treenail is dipped into a small puddle of fresh glue and inserted, then trimmed with scissors immediately. In 5min glue get slowly sucked into the hole, I had no issues with treenails falling off even in areas where I need to shave off quite a lot of wood afterwards. No chamfering of a lead corner, instead I make sure to "open up" the hole by gently poking a round tip of a wood scriber into it. It does not change the diameter of the hole, just opens up the entrance from loose fibers and other obstructions. It takes a bit of practice to "sense" a hole when there is a glue drop obstructing the view. But after a while it gets easy and relaxing.
- 969 replies
- hahn
- oliver cromwell
Carl, I'm not denying the history or suggest to remove Cromwell from all the books. I just don't want him anywhere close such a intimate thing like a model that you put hundreds or hours and elbow grease into In the same way as I would never build a model of Herman Göring's yacht. And, as Brian mentioned, I am lucky to have a choice - the ship was captured, slightly modified and renamed, it's not too late to pick the version to build. So back to the modelling! Roughly 1200 holes were drilled, the Buzzr did its job perfectly with zero broken bits! 💪 Bamboo treenails were glued in Resulting in a pretty satisfying sight Pointy bits were cut off and most of the glue was removed with a dremel with nylon bristle brush. The hull was covered in plastic since this process is quite messy, small bits of glue are statically charged a bit and stick to everything. Now the best part - sanding and fairing. I really love this one, turns an ugly uneven surface into a neat and clean one (unless there are gaps) Hahn jig is really convenient for such work, since you can actually lean on it and rest your hands on it without damaging the model. That allows you to work precisely and for a longer periods of time with elbows resting. I can really recommend constructing support like this even if you do not use Hahn's method. Nevermind my corona haircut Wide gauge chisel (Pfeil #7) came in handy for removing the remaining glue residue in hard-to-reach areas, as well as fairing the planks. It's surprisingly easy to control, can definitely recommend this tool. The rest was done with a combination of sanding, scraping and chiseling. Final sanding grit was just 400 instead of a usual 600-1200. Here is the end result. Notice how the treenail color is quite different, even though they were all cut from the same wood that looks identical from the outside. I know the the nail pattern is not entirely correct, as an excuse - it was marked up a year ago! It's definitely not perfect, there are a few tiny gaps and dings, but it's good to practice on an internal planking (that would be barely visible afterwards), to build up skills for the more exposed areas. Now it's time to apply some finish (at least to get an even treenail color), but I have no idea which one to use - these planks are actually the first boxwood parts on the model! All my finishing experiments were on pear, cherry and walnut, and the results are very wood-specific. I definitely do not want to turn this boxwood dark green-ish or dark yellow, ideally want to keep the color as light as possible. My guess is that oil is not the way to go, but some kind of sanding sealer would be better. Will make some samples and try all the main finishes I have before using them on the model. Feels a bit wasteful to spend quite a lot of boxwood for these experiments, considering its price and availability... But I wasted less than budgeted on whoopsies and redos, so there is a bit of a reserve
- 969 replies
- hahn
- oliver cromwell
It's actually smaller than a penny (16.25mm for a euro cent vs 19.05mm for a penny). (Pardon, crawling back under a pedantic rock). What giampieroricci is doing is incredible, can't imagine that accuracy on such a small scale, looks like an ultimate challenge! 😲
I have a shameful confession: since the beginning of the build, I've never actually read who Oliver Cromwell was further than a basic summary. "Some aristocratic British dude, whatever, I like the model". In hindsight that was not the smartest thing, it's like picking a rare name for your child without googling it first 🤦♂️ Over the last year I found more and more articles about him and his legacy, and it started to smell pretty bad. History (and the present) have had enough brutal authoritarian tyrants, and Cromwell was a pretty dedicated one. I started feeling shame and disgust when opening my own build log, like it's a dirty word that may be actually offensive. I hereby apologise to Irish for my ignorance.. Luckily, there is a way out without deviating from history - that ship was renamed once it was captured by HMS Beaver. The new name was very creative - "Beavers Prize" - probably to make sure nobody would contest the origin of the vessel It's great! It has no relation to any historical figures, a bit humorous and may work as a conversation starter The spelling is not so obvious (Beaver's Prize is also used), but I would use the simpler spelling with no apostrophe, same as on the original NMM plans. So from now on this log is renamed accordingly. Horrah to the Beaver! There are a few modifications that need to be done. When captured, it was measured and the plans were drafted. While there, some improvements were suggested and then implemented: * Second double-level capstan (I guess capstans were like clamps - you can never have too many) * Improved lower deck layout * Fore mast moved ahead a bit * New galley stove installed Quote from the Hahn's book "Ships of The American Revolution": Suggested changes are drawn as a dotted line on the NMM plan: I really like that changes, especially the second capstan - it would make the quarter deck a bit more interesting. P.S.: the actual construction is going well, all treenails are in place and I'm sanding and scraping the internal planking. Will post photos once that phase is completed.
- 969 replies
- hahn
- oliver cromwell
Great subject! I had the opportunity to help a bit to prepare it for the winter (just a few times, it's on the opposite side of town for me..) It was a nice way to spend a weekend, the smell of tar and the joy of helping Great for kids as well!
- 179 replies
- longship
- Helga Holm
Swan-Class Sloop by Stuglo - FINISHED - 1:48
Mike Y replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
Looks like you got through that steep learning curve! I cheated and started with some midship (square) frames before approaching fore and aft. Paid in bruised knuckles, but it paid off. Starting "the right way" looks much harder Great build, pulling up a chair!- 475 replies
ancre La Belle 1684 by Nenseth - 1:36 scale
Mike Y replied to Nenseth's topic in - Build logs for subjects built 1501 - 1750
Hi Hans, Hope things are ok for you! Have you figured out the transom geometry? -
Time to install top railings. Daria learned how to use a blade for scraping to turn rounded edge to a flat one: Installed: Also added an extra layer of wood for whales, etc. .... And then we had a long break .... She finally got a rabbit that she was planning for a long time, we started mountain biking together, and her baby sister needed attention too, etc etc (excuses, excuses). Modelling was a bit on a backburner for a while. ... A year later we got back to it. - Hm, daddy, I think we haven't been building our ship for a while? - Say no more! 😎 Now time for some fiddly things. "Fashion piece" imitation. I am proud that she could fine fit such a delicate part on her own (very thin and prone to splitting). Catheads. She does not like the feeling of a file rubbing on skin, but masking tape helps with that She wanted a timelapse:
Dust extractor - compact and quiet?
Mike Y replied to Rik Thistle's topic in Modeling tools and Workshop Equipment
I would seriously challenge the idea of a shop vac for our hobby (assuming you are not doing a full scale woodworking on a side). I am using a regular household vaccuum for 4 years already, though a bit of a fancy variety (Bosch ProSilence, HEPA filter included). It's quiet. The airflow is more than enough, I rarely use it on a highest setting. It's quiet, nothing is ever getting clogged, no dust is spread inside. Its guts are clean as new, and dust bags are cheap and readily available. I also used if for small-scale woodworking, from cutting quite a lot of wood on a table saw to thickness planing. It's way cheaper than a shop vac (100-120 EUR/USD), way smaller and quieter. Since it's quiet - you can easily run it on a low or medium-low rpm during the entire modelling session. I use it all the time when sanding by hand, which actually produces quite a lot of fine dust right next to your mouth. Would you run the shop vac all the time while working on some parts? Unlikely, since it is ungodly loud. This gently kitty can be run all the time. And if I'm wrong and you really need a massive shop vac and a cyclone - it can be always repurposed as a regular household vac, no loss P.S.: the hose of this vac has the right diameter to fit Proxxon tools with no special adapters. I hope that the US version is not using a different hose though... -
Yep, these days not sending a short mail "your order is shipped, tracking number is XYZ" is so strange, since literally 95% of the shops do that. It's like ordering a pizza with no order confirmation. Maybe it's coming, maybe it's not. But please enjoy the surprise, eventually your parcel will suddenly show up (assuming your post office is reliable enough, otherwise you are out of luck with no tracking). P.S.: still love SeaWatchBooks and will order more from Bob, just this one particular nuance is so frustrating for some Imagine ordering things to business address with no tracking? Maybe it was delivered to somebody on reception 3 weeks ago, but that person forgot to pass the package. P.P.S.: best wishes to Bob and thanks for providing a very vital service for the community!
Help for the Noobies
Mike Y replied to drjeckl's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
Just a few cents The best way to think about it is "put yourself into others shoes". First problem is simple and technical: it's impossible to find your build log link. Even in this topic, where some may be encouraged to have a look - there is no link in your signature. I honestly thought "oh, sure, let's have a look and maybe I can help a bit" - but no, it would take too much clicks just to find it. See https://modelshipworld.com/topic/23663-how-do-you-add-links-to-your-build-logs-under-your-signature/ Second - make sure your question is asked clearly, and preferably with photos. Keeping correct terminology is pretty hard, especially for a beginner, so just using words is not the best idea. For example - I found your topic on deck cutouts, but it's pretty hard to really understand without any pictures. What are these "cutouts"? How are they located in relation to masts and so on? A lot of people would either guess what you mean or just move over to another question, because it takes too much efforts to decode. Third consideration is a bit harsh, and I am not sure how to put it in a very neat terms - but first big heap of initial modelling knowledge is acquired mostly by reading other logs. Majority of newbie questions were already asked bajillion times, there are FAQs, manuals, tutorials and so on spread over MSW. Even with best intentions, it slowly gets old to explain the very same thing for a dozen times, so people loose motivation to help. I cringe when I read some of my first questions, I want to travel back in time and slap myself "just read the manual one more time before asking!". Using this moment to thank everybody who was helping! Ignore the particular vessel, just pick the build log where the build process is shown, not just the end result. Some logs are very educating, you will learn a lot from reading them. Basic techniques are the same. Do not hesitate to go to scratch build logs - there are fewer of those, but often they are very detailed and educating. The balance is delicate. Please do not be shy to post your updates and your logs! Everybody is welcome. But think about it like a giant dance event. You come through the doors and you are in a crowd with thousands of people. They are open and a lot are keen to teach you and dance with you. But first you need to watch a few tutorials on basics, and then just start a small talk to get familiar with some of them. Make yourself friendly and available (see - build log signature). They are under no obligation to help you, but also there is physically no time to dance with everybody. You need to stand out of the crowd just a little bit, to make sure you will be noticed. Good luck, and hope you will find your way and join one of the friendliest and constructive communities in the internet! -
JP, hope your build progresses nicely! Just a small word of caution in that critical moment - check the alignment of the top part of your frames, next to the cutoff sections. These areas are thin, and would be very visible once the hull is flipped over. Luckily cutoff sections can be moved around a bit to compensate for it, but it needs to be done before frames are glued to the jig. Some strip of wood would help to check the alignment. I was not so careful during that step and still see the results of that mistake..
- 50 replies
- rattlesnake
- brig
Be gentle with the clamping force though, if overtightened - the guide rods will bend, and jaws would not be parallel anymore, vice will start to wobble. Don't ask me how I know Great value for money anyway!
Pat, very interesting idea, thanks for sharing the link! Heard about the dental tools, but always postponed the purchase due to their price. Maybe it's time to go for another ebay hunt Carl, thanks for the generous offer, I'll keep it in mind! No need so far, and it mounts to the full-size Dremel, which is too bulky and aggressive to be brought close to the model, I'm a bit scared of it after using the mini dremel tool.. I've now realised what made my life more difficult than it should be - it's a small downside of the Hahn building method. The top of the hull is higher and narrower than it should be due to dummy parts that attach it to the jig, so it really limits the angle of the tool that you can use inside the hull. (The photo is quite old) It would not be an issue once the hull is cut free, but that would happen way further down the road. At the moment my handmade drill seems to work just fine, already drilled and treenailed a quarter of the inner planks. To be on the safe side and avoid overheating I simply switch it off after every row of holes and move over to drawing bamboo through a drawplate for a few minutes. That way I keep a roughly 1:1 ratio of holes-to-treenailing-stock, and switch tasks to break the monotony - otherwise it's too easy to phase out and make some dumb mistake
- 969 replies
- hahn
- oliver cromwell
Hm, sorry, I did not know it's so hard to get it in US With Hobbymill and Crown closed, I thought you can buy Pear, Alaskan Cedar and Castello Boxwood sheets from Syren, but now when I check the site - it looks like it's down to Cedar only. Well, maybe ordering from Europe is not such a bad idea, on a large enough order the shipping cost would not be so significant, and there are no import fees into US, right?
It's quite impressive, would benefit from some walkthrough video!
