Adrieke
Everything posted by Adrieke
  1. @tophog thanks i think Sjors is selling them on his bus together with the ones for Johns kom @TMC it was my only option to make them fit . that or remove all the windows and remake them smaller . so i went to easiest way . yeah i actualy printed that one out to hang at my desk at work although its bothering me now was i can see soemthing i forgot and that one of the railings isnt aligned properly so more work todo there . i am learning fast that the main skill to learn is patience. @garward. all pieces already have been sanded before fitting but my procedure is to sand with the finest paper i have then use a slightly damp cloth to wipe of the dust then varnish then redo again. wil be a challenge to get to all bits around the staircase though but i ll do my best
  2. there are several options for bending. my preferrred method is soaking in water then use soldering iron to bend . this works great on baswood. using a steambox like in real is a good option too
  3. planking is usualy a slow one plank at a time process thats why some of us are doign 2 builds at a time
  4. as long as they dont bite the pilots . remember anything here in oz is poisonois
  5. yup glue does reinforce the wood. that was actualy a good tip by "drumroll" Artesania Latina in the instructiosn for my stagecoach paint some glue on the back of thin veneerstrips to make it less like they split when cutting complex forms in it
  6. thanks robbyn and yes i am pleased with them as soon as i fix the little error , glue on the strip i forgot i took off to install it and paint the dowel in the glass beads thanks Wayne thanks Anja was going to put the first coat of varnish on but didnt have time . hopefuly tonight
  7. good job on all teh little benches and the staircase. it looks fine and natural to me
  8. almost made a big mistake. i decided to glue the rest of the decks on. during drying i had a check and noticed that the deck had a bit of a dip between 2 bulkheads. further investigation showed that the deck didnt even touch agisnt the false keel there. then it dawned on me that i actualy never finished fairing the top of the bulkheads. i gently tried lifting the decks off. all came off wiht no damage. just need to clean off the glue. i should have checked.
  9. she looks realy beautiful also lookign forward to your stagecoach buildlog
  10. just caught up with this build ( so may logs to go through ) looks really nice Wayne
  11. i have seen this kit at my local hobby store. looks like a nice build. first advice i can give you is to check everythign and go thorugh the instructions and plans.
  12. hello Don its good to know someone else is building her i wont be starting her too soon either as i stil have the kom and the endeavour
  13. yup unfortunately . see its if i only been here a bit and its already an hour later and i need to start work
  14. hello Anja thanks for looking in it wil be slow as the idea is to work on this when i cant work on the others. i have done a bit moe on her but i misplaced the picture somehow . wil update soon
  15. wow still going strong. its really comming together i think we have all had that happen we think all is good then you take the pic and put on here and then you notice the little bits that need a bit of tidying up. just for yourself because like John said most wont even be noticable
  16. thanks Jim, Sjors,Wim and John for the comments and for the encouragement . dont think it would have turned out liek this without you guys on here
  17. thanks Wim and Carl. i l be slowly working on her now . hopefuly get to stage of plankign by the time the kom is alomsot finished
  18. thanks Randy finishing more of the railing near the stairs. need to check but i think thats the last bit so now i cna varnish the second deck and then glue the third one on
  19. hi crackers no leverage poles included in this kit so there wil be none. i would have a beer on it if i had one John anyway i feel like a huge weight has lifted of me. after this nothign can stop me from finishing her the way i wanted
  20. Tom . i have never done this but if you put the sheet between 2 plieable sheets of lets say thin cardboard theuprights should hold
