druxey
Everything posted by druxey
  1. If showing a model as 'first launched' she would not have been coppered. After launch, if any leak were found it would be fixed on docking her before applying copper sheathing. So, as Mark said (post #7).
  2. Will you tone down the netting a bit later, dafi?
  3. Those are the nicest scale hooks I've seen, Johann. The taper is perfect!
  4. I really appreciate your comments about the function of different things, such as that central slot. Very educational!
  5. A hull only would still look nice, Greg!
  6. Either two or three seizings are appropriate.
  7. That photo is of a land carriage and land piece of ordnance. The wheels have iron 'shoes' and the gun has elevation marks on the side of the base ring.
  8. Sounds like blade damage if these are longitudinal grooves or raised lines.
  9. I understand that verdigris develops in the presence of air. Underwater, however, there is less oxygen. Scouring, as well as possible electrolytic action, takes place leaving the copper relatively bright. Only the area of copper near and above water, exposed to air, will turn green. Comparing a dry-docked copper bottom with copper submerged in water is not a good analogy.
  10. I've had success in the past by scoring clear acetate sheet and putting a little dark grey acrylic (not black!) into the scores.
  11. Gee, Eric, if you were in the neighbourhood you should have let me know and dropped by!
  12. Super work, as usual. Just ask my book-keeper, aka She Who Must Be Obeyed, whether we are a non-profit or not!
  13. That metalwork is delightful. It's interesting, seeing you use the mill as a horizontal circular saw.
  14. You have confirmed to me that traditional lofting on the drawing board is best for one's mental health!
  15. Um, a regular face mask does not protect you from volatile organic vapours. Only a respirator with suitable filters does that. Provided you have reasonable ventilation, the small quantity of these compounds should not affect you. For cleaning up square holes, use either a square section escapement file (it's a tiny version of a Swiss file) or a small broach.
  16. There are Cruizer class plans on the Royal Museums Greenwich web site. However, to interpret the framing, etc, you need to have quite a bit of knowledge of wooden ship construction for the navy of that time. See, for example: https://collections.rmg.co.uk/collections/objects/83931.html
  17. Thanks for the trip down memory lane to Vic Smeed. Takes me back a long way as well! Nice cut-out work there, Pete. As for quality ply, I don't know whether 'Baltic birch' ply is available Down Under, but it is of high quality, no voids and has many layers.
