druxey
Everything posted by druxey
  1. If you had asked this question 30 years ago, the answer would have been simple. Since the introduction of graphics programs on computers, Letraset became a dinosaur. I doubt if you can find any these days. In any case, old Letraset tended to craze and lose adhesive strength. Y.T's solution is an elegant one. You could start by printing off a computer-generated version of the lettering as he did. Alternatively, use a fine artist's brush and paint....
  2. Welcome here, André! As Mark said...
  3. You are having much too much fun with PhotoShop effects!
  4. Beautiful restorations, sotto voce!
  5. Looks pretty good to me, except for that one larger gap- but you've solved that issue.
  6. Enjoy your trip/vacation. Will you visit the Niagara/Toronto area? Remember the Art Gallery of Ontario Thomson ship model collection if you are up this way!
  7. Mark: I soften old hacksaw blades by heating cherry red (propane torch) and air cooling. I use escapement files and razor saw to cut the profiles I need. I don't worry about re-hardening and tempering. The softer steel cuts well and stays sharp enough for a long time. (This is on Castello.) If I do need to touch up the cutter, I simply stone it flat. Easy!
  8. I lost a lot of good photos with my last computer, but here is an example.
  9. Look on the site: https://collections.rmg.co.uk/collections.html#!cbrowse then search '26 foot pinnace plan' and '19 foot longboat plan'. You can download the plan, then re-size it using the scale on the plan to fit your scale.
  10. My method of false spice is to unravel the line for a little way, tease out the yarns on a flat surface, then cut them on a long diagonal. Take the line around the block, put a dab of white glue on the frayed end, then pinch and twirl the frayed end against the line at the end of the block to create a tapered false splice. It takes a few tries to master the technique, but gives good results quickly.
  11. Probably the fiberglass coatings actually accelerated the rot! In my experience, conservation is much more complex (also read 'expensive') when other well-meaning but non-knowledgeable folk have previously 'restored' an artefact or painting.
  12. Glad it's working out, Mark. My first attempts at making cheeks took forever with serious scrapbox contributions. Each subsequent set has become easier and quicker to make. I hope that's of some consolation!
  13. Bob Cleek: Smalt (another blue pigment) was readily available and economical prior to the invention of Prussian Blue. But we digress.
  14. Relate the thickness to the width of the cheek side arm (its moulded way) below it. That may be more a reliable guide.
  15. We feel your pain, Mark... It's going to be an awkward fix. Good luck with it.
  16. That is an interesting way to distinguish the owner that I was not aware of. Nice work seeing your version develop, Clare.
