Everything posted by druxey
I don't use a scraper holder at all, Mark. The length of hacksaw blade (teeth filed off!) is held in both hands like a spokeshave. You have much better control than the X-Acto blade in a handle approach. I also (where feasible) rubber cement the strip of molding to be shaped down on a backing board. This acts as a depth stop as well as securing the part.
If you had asked this question 30 years ago, the answer would have been simple. Since the introduction of graphics programs on computers, Letraset became a dinosaur. I doubt if you can find any these days. In any case, old Letraset tended to craze and lose adhesive strength. Y.T's solution is an elegant one. You could start by printing off a computer-generated version of the lettering as he did. Alternatively, use a fine artist's brush and paint....
Welcome here, André! As Mark said...
Intrepid (or more likely foolhardy!) newbie
druxey replied to SottoVoce's topic in New member Introductions
Beautiful restorations, sotto voce! -
Enjoy your trip/vacation. Will you visit the Niagara/Toronto area? Remember the Art Gallery of Ontario Thomson ship model collection if you are up this way!
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Mark: I soften old hacksaw blades by heating cherry red (propane torch) and air cooling. I use escapement files and razor saw to cut the profiles I need. I don't worry about re-hardening and tempering. The softer steel cuts well and stays sharp enough for a long time. (This is on Castello.) If I do need to touch up the cutter, I simply stone it flat. Easy!
My method of false spice is to unravel the line for a little way, tease out the yarns on a flat surface, then cut them on a long diagonal. Take the line around the block, put a dab of white glue on the frayed end, then pinch and twirl the frayed end against the line at the end of the block to create a tapered false splice. It takes a few tries to master the technique, but gives good results quickly.
Probably the fiberglass coatings actually accelerated the rot! In my experience, conservation is much more complex (also read 'expensive') when other well-meaning but non-knowledgeable folk have previously 'restored' an artefact or painting.
Bob Cleek: Smalt (another blue pigment) was readily available and economical prior to the invention of Prussian Blue. But we digress.
