druxey
Everything posted by druxey
  1. You cut the letters of the name out and glued them on? Well done!
  2. Well, those were good saves, Frank! Did you sweat a bit when revising the waterway?
  3. You have a load of suggestions already, but I'll add two cents anyway. If you want to build models that have the appearance of POF, many of the above such as the Cheerful kit will be great. However, if you want to understand actual prototype framed construction, may I suggest you look at Admiralty Models' Echo cross-section offering? It' s good way to ease into this type of model. (Link to AM is on the home page, right side.) Welcome to this merry band of modelers!
  4. Actually, below waterline bolts are copper! Nice work on the rabbet.
  5. I agree with Carl, but the log has already been sawn up
  6. Pipe clamps are a snare an delusion: wood will move to where it wants to be. The cut through the center of the log will stay flat(tish), but slabs on either side will progressively cup once the clamps are off. Better to sticker the planks, let them air dry and then plane flat.
  7. Depth of field becomes an issue unless you stop well down and use longer exposure - and a tripod....
  8. You are doing very well for your first planking job: you can't expect perfection instantly! Every model is a learning experience.
  9. Allan: The keel is boat-shaped, but that photo is misleading. You can see better pictures of this model on Vaddoc's build log page. I think he has solved the problems since that post on June 11.
  10. Very adroitly done, Ed! I like that lashing technique.
  11. Just stumbled on to this log: beautiful fittings work, Keith!
  12. Very impressive work. The photos make the model look much larger than it really is.
  13. Sometimes 'Frankenpatterns' work very well! Looks like you are getting the rhythm of it now.
  14. Somehow your updates have been below my radar for a while, so just catchng up with you, Clare. Some of the work is obviously not for the faint-hearted, but it looks really good so far!
  15. I just happened to check here and see several requests for Mihail's e-address. Some of you have since PM'd me and I've responded. Please PM me for his contact info, as I'm reluctant to post this to the world at large.
  16. Great solution if one does't own a drill press or it won't reach! Well done, Mike.
  17. Well done, Toni. I know you would never have been happy with wonky aft ends to those head rails the way they were. Plus, they would always have reproached you every time you looked at the completed model. Great recovery!
  18. Well, that was very kind of him! Glad that worked out for you.
