Everything posted by druxey
On a 64 gun ship there were seven turns of line around the drum, with the center turn nailed to the drum. There were then 3 1/2 turns possible to either side. I once worked out the geometry of this arrangement and it allowed the tiller to turn almost exactly from one end of the sweep to the other, allowing maximum helm each way.
Echo by davec - FINISHED - cross-section
druxey replied to davec's topic in - Build logs for subjects built 1751 - 1800
Happy New Year to you also, Dave. Apart from practical problems making ebony treenails - I wouldn't. It would look as if your model had the pox! The contrast in tone would be much too great. As for using ebony on the wale - you're a braver man than me. Looks nice, though.- 127 replies
You are experiencing what is called cumulative error. If each 3/16" plank is slightly under width by even a few thousandths of an inch, the second strake will be off by double that amount, the third triples it, and so on. Bevelling may be part of your issue. And then it shows up and bites you! It's unfortunate, but it's happened to all of us and is part of our learning experience. You may be better off cutting your planks slightly over-width from sheet material and sanding them down to fit the edges accurately to your mark-out. Yes, more time-consuming, but it makes things right.
HMS Naiad 1797 by albert - FINISHED - 1/48
druxey replied to albert's topic in - Build logs for subjects built 1751 - 1800
Beautiful work as usual! The metalwork looks very neat indeed. -
"Gunnery notes" from William Rivers (*1755, †1817)
druxey replied to dafi's topic in Nautical/Naval History
That makes sense as the marines' red uniform coats would make very visible targets. -
until we? -
Adding the quarter deck beams makes your model look much closer to finished - assuming you are not going to spar her! Looks great, Toni.
- 1,449 replies
When in doubt, follow your Pegasus draught. The Mylar draught is based on Atalanta.
- 889 replies
May we see photos of the other completed model, please? It looks more interesting than the wall!
- 968 replies
- hahn
- oliver cromwell
Interesting looking corner joinery! I'll be interested to see the real thing, Mike.
- 968 replies
- hahn
- oliver cromwell
Some photo-processing software (such as PhotoShop) has the ability to compensate for the specific lens you are using and to correct for barrel or other distortion issues.
- 1,051 replies
- cheerful
- Syren Ship Model Company
You are making great progress, Gerald, as well as giving us insight into your thinking through the various processes you've developed. Much appreciated! Every best wish for the coming year to you.
- 281 replies
- falls of clyde
- tanker
The transoms are scored on to the sternpost and inner post. The knee is then scored on the inner faces of the transoms once they have been faired.
- 102 replies
Yes, Christian. On this draught the sternson knee (extension of the keelson), extends up to the underside of the wing transom.
- 102 replies
Thanks for the kind compliment, Dave. Glad you like the book.
- 641 replies
- greenwich hospital
- barge
An interesting strategy: I hope this works out well for you. I suppose another possibility is to not glue one side of the spacers so that the frames 'float' with any dimensional change.
- 889 replies
Good to see you back. Polish with what, Michael: pumice or rottenstone? The repairs above looks great!
- 749 replies
- albertic
- ocean liner
