druxey
Everything posted by druxey
  1. The boards are a parallogram in cross-section. If you have a saw with a tilting arbor, this should be an easy job.
  2. Do you mean the Caroll A Deering? She was a five masted schooner lost with all hands in 1921 under circumstances that have never been definitely explained.
  3. One can never have too many clamps.... Looks like you are making good progress, Maurys.
  4. Did anyone say this was easy stuff? It's a big commitment and a big learning curve. But you are obviously on your way. Those are rather large nuts/weights you are using! Or is your model smaller than I'm visualizing?
  5. The Beaver's Prize draught is contemporary and, one presumes, 'taken off' accurately for the Admiralty. Therefore rectangular (or almost rectangular) lights were representative of her as captured. Note that the timberheads above are angled inward. Therefore the counter timbers were angled at the level of the deck above the lights. For a model, these might be easier added as separate items later on. Remember that Hahn did stylize his models, this being one example.
  6. I suspect the variations in rig may be the result of these smaller vessels being built in private yards around the coast, and may reflect regional differences.
  7. Small point, Patrick: most model hull reconstructions of this time are too deep at the stern. The transom's lowest point should be just under the waterline. If it's any lower, then the rudder action is impaired as water won't flow past the upper rudder properly. Check the Baker drawings.
  8. Mark: often Seaforth and the NIP both publish the same book under their own imprint, but on different sides of the Atlantic.
  9. Very nicely rendered, but there are usually two reef points to every width of canvas.
  10. Lovely brasswork. However, it sounds like an extremely frustrating week for you. As a character in a Feydeau farce says, "A reverse today - a revenge tomorrow!" Hopefully the reassembly will go correctly and smoothly.
  11. Or proportionally re-size the spars.
  12. I see this question has been floating around a while. A similar class would be the Cruizer class. The rigging and sail details are given in Petrejus' book 'Irene', if you can get a copy on the used book market.
  13. Jason: Scuttles for removal of pump tubes would only be necessary in cases where the quarter deck extended forward of the main mast.
  14. Yes, this would be a feature needed to haul heavy items up above the lower mast. These might include the tops and any higher item.
  15. I hesitate to push the 'like' button on seeing the damage caused by the errant mast. Presumably the owner of said mast will compensate you for this. Look forward to more from the Mott Shop.
