druxey
Everything posted by druxey
  1. Superb joinery, especially at the forefoot.
  2. Very impressive models, Greg! But please think about protective cases for such lovely pieces of work.
  3. The only possibility I can think of is a custom carving or sculpture. This might be an expensive proposition, though!
  4. I agree with Wayne's assessment, that the tackle could be used to blow off steam when required, by-passing the relief. Two single blocks would be sufficient.
  5. Welcome back, Ed. Very nice whiskers indeed!
  6. Nice to read that you are taking good care of yourself, Chris. After a certain age it's all too easy for extra weight to silently incorporate itself.... Also nice to read that there's still excitement over your latest creation for Amati.
  7. Glad the paper shim version worked out, Alan! And I get how you misread the rule. Well, you won't do that again ever, will you?
  8. How can one read a scale rule wrongly, Alan? I'm a bit puzzled. The idea of using paper towel as spacers is a bit dodgy: they can compress. I'd recommend wood slips for the job.
  9. Just came across your log, Giorgio. That is one beautiful model you are building. Looking forward to more progress reports.
  10. If the frames are square to the keel, you can clamp the keelson piece to one side of the keel on the inside. Then you can use the marking knife from the outside without the keel getting in the way.
  11. I think, on close inspection, that I see a line parallel to the painted(?) top of the dark area. Is that the top of what could be the copper?
  12. Your take on this is the same as mine, wefalck (see post #10).
  13. Hmm. Yet another reason for not using CA in future. I feel your pain at having to revise your work, but when you do, the gap between upper and lower deadeyes look far too wide. Look at photos of other examples to see what i mean.
  14. Jaager: if the frame is bevelled, then the scarph (or chock) would also be bevelled to the same angle, otherwise strength would be compromised.
  15. Take a look at the planking articles that are 'pinned' on this site, David. In reality, planks were generally 24' 0" to 28' 0" long. There were a number of rules about where the plank butts occured - it wasn't a random thing. Kits have their quirks and shortcomings, among which is simplifying. It will be easier to plank in shorter lengths, but read up on things first!
  16. Good luck with this, E&T as you figure out your best strategy. Pear is certainly amenable to bending.
  17. Nice lapstrake model you have there, Vaddoc! What is she?
