Everything posted by druxey
Even a shallow bowl of water in the shop might help things, Ben. Ideally a humidifier is best, but it's better than nothing. Varying humidity due to seasonal change is the enemy of wooden models. Try to keep things relatively stable year round.
- 889 replies
This will be the last update for a few days: the frames have now all been bent in. I'll be back in a week or so. Thank you all for following and liking this log.
- 641 replies
- greenwich hospital
- barge
Remo: I've seen your beautiful work and you are under-selling yourself. I'm trying to be in your league!
- 641 replies
- barge
Cutter Cheerful 1806 by rafine - FINISHED
druxey replied to rafine's topic in - Build logs for subjects built 1801 - 1850
Looking good, Bob!- 525 replies
- cheerful
- Syren Ship Model Company
That sounds very convincing, Glenn. The discussion and process of arriving at this conclusion I found most interesting.
I have no idea, as it will depend on the specie of wood you will be using, Steven. You will need to experiment with both moisture and heat.
- 641 replies
- barge
Frégate d'18 par Sané , la Cornélie
druxey replied to JohnE's topic in CAD and 3D Modelling/Drafting Plans with Software
John: did you receive my PM from the other day? -
Beautiful work, as ever. Thanks for the early treat on Friday instead of Saturday! Enjoy your family weekend. Still working on the assumption of quadruple boilers?
Excellent method and result, Mike. Well done!
- 452 replies
- cheerful
Aft frames are now in, with some fine adjustment still required. A ruler is included in the photos as requested.
- 641 replies
- barge
Glue 'em damp, and clean up any excess glue with a damp brush, Ed.
- 641 replies
- barge
Ed, have you tried bending frames using moisture and a thermostatically controlled iron?
- 3,618 replies
- young america
- clipper
Ed: The frames are bent in wet, without any heat necessary. They are of such small dimension that this is easily accomplished under slight compression to 'spring' them into place.
- 641 replies
- barge
If it's of any assistance, when I've cut frames, generally I cut to the outside line, or no more than 1/64" outside it. Bevelling (except for bollard, hawse timbers and transoms) is left until fairing a complete section of the hull. If you are going to bevel each frame, would it not make sense to paste the pattern on the 'narrow' side, cut to the 'wide' line, then bevel back to the 'narrow' line of the pattern, rather than try to align patterns on both sides?
Sounds like a very effective method, Gerald.
- 281 replies
- falls of clyde
- tanker
HMS Naiad 1797 by albert - FINISHED - 1/48
druxey replied to albert's topic in - Build logs for subjects built 1751 - 1800
Lovely work in progress there, Alberto. Inspirational. -
Thank you, one and all. The frames butt to the keelson in the model, Joel. It might, in hindsight, have been easier to notch the keelson to locate the floor ends. I'll include a rule in the next batch of photos, Chuck.
- 641 replies
- barge
Started bending in the frames today. They are spaced at 18" intervals and, as previously mentioned, are ¾" square. In the real boat, there were floors and futtocks united by a side overlap. However, as this will be completely invisible in the finished boat, I will omit this detail. As I have other work on hand, the next update will be a few days away.
- 641 replies
- barge
For some reason I missed seeing this thread until this morning. Fascinating research and interpretation, Woodrat! You are doing a terrific job in these rather poorly charted waters.
Next is to cut stock a scale ¾" square. This is next to impossible without a zero-clearance table and a slitting saw blade. So I made an insert of aluminum sheet and raised the saw blade through this, as shown (upper left). Note that, on this saw, I have an Accuriser II fence. I attached a secondary scale measuring in inches at 1/48 scale. This avoids having to translate from thousandths of an inch (actual) to scale inches. I cut several sheets of 1/64" Castello stock and rubber cemented them to a sacrificial piece of softwood. In this case it was simply a paint stir-stick (upper right). This was then run through the saw and the pieces separated and cleaned up, giving the 1/64" square section required for the frames (below).
- 641 replies
- barge
Thanks, Michael. I use white PVA, slightly thinned, applied with a small watercolour brush. The outside is washed down with a damp brush immediately, and the inside is cleaned up afterwards with a dental elevator (looks like a bent mini-chisel). If there is a stubborn bit of glue, a drop of water on a brush does the trick. Should a little of the joint give way, I run more dilute glue into the crack and clamp it shut with one or more of those mini-clips. This rarely happens, as the bevelled land creates a tight joint.
- 641 replies
- barge
