Everything posted by druxey
Hmm. Toni, you have potential for a second-hand instrument business there!
- 209 replies
- cheerful
- Syren Ship Model Company
Cutter Cheerful 1806 by rafine - FINISHED
druxey replied to rafine's topic in - Build logs for subjects built 1801 - 1850
Yes, 3D parts are more tricky for sure. The strategy I use is to cut the profile according to my card pattern from wood that is slightly too thick, shape the (inner) mating surface to fit, then the outer one. If I try to shape all surfaces at the same time, the scrap box opens its mouth!- 525 replies
- cheerful
Neat result, though, Bob. Do you make card patterns for tricky pieces? I find that strategy keeps the scrap box hungry.- 525 replies
- cheerful
Lathe - ZHOUYU Model Z20002
druxey replied to t5956ws's topic in Modeling tools and Workshop Equipment
Ask yourself what you will use the lathe for before you start. Defining your needs will help you focus on the machine you actually need. Wood turning? Metal turning? Both? What is the longest item you may need to turn? What is the largest diameter? These are starter questions even before considering budget. -
Frégate d'18 par Sané , la Cornélie
druxey replied to JohnE's topic in CAD and 3D Modelling/Drafting Plans with Software
Thank you, John. So, if I understand correctly, the lower part of l'estain is like a cant frame, and the upper part twists to become parallel to the couples. -
HMS VICTORY 1759 by isalbert
druxey replied to isalbert's topic in - Build logs for subjects built 1751 - 1800
The meant the mast bands or hoops, not the mast itself! The 'made mast' was of many, many pieces of wood. -
Old question (April 30!): the mast bands were made and driven on in one piece. Just caught up with your build log, isalbert. -
Bava: it's not puzzling when you realize that the lines (that appear straight on the half-breadth plan) are their projected shapes on the sheer plan. They would only be straight if the ship were a rectangular block. Cut a loaf of bread straight down, but at an angle to its long axis, and view it from the side. Then you'll get it. -
Looks like she's fully laden: that bow goes deep in the water on the down pitch! Very effective animation, Magnus.
So, if I understand you correctly, the line of l'estain in the body plan is the projected view of this element? -
Gluing 101
druxey replied to CPT_D's topic in Building, Framing, Planking and plating a ships hull and deck
Yes, isopropanol breaks down PVA. However, it will reset if not cleaned off the joint. Isopropanol should be available at a drug store (chemists). -
how to create rope of different thickness?
druxey replied to Soren's topic in Masting, rigging and sails
Three (or four) right hand lay ropes spun up left-handed will make a cable, not just thicker rope. -
Echo by Maury S - FINISHED - Cross-Section
druxey replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
Actually, after a while, those joints will 'read' through the paint or dye. Just give it time and seasonal wood movement!- 324 replies
For really thin line, rather than use a two-strand (which never looks right), start with three thinner threads. If thinner thread isn't available, turn three-stranded thread in such a way as to un-spin it. You will find it consists of three yarns. Carefully pick up one yarn at one end with tweezers and cut it. Don't let the long end go! Now strip out this yarn, leaving two intact. Do this to the other two strands, then make up your line in the usual way. On a planetary style ropewalk this technique may not be possible. I've only done this on a conventional style machine. -
Well, that was a good save without disassembling the axletrees and cranks!- 324 replies
wood filler
druxey replied to wilspaul49's topic in Building, Framing, Planking and plating a ships hull and deck
Then best kind of filler is no wood filler! However, if the gaps are very small, sawdust and white glue do a good job. -
Nice, clean work there, Mick. Those other 40 frames? Slow and steady does it. You'll get there.
- 504 replies
- washington
- galley
